用數(shù)碼管顯示四相異步電動(dòng)機(jī)的步數(shù),為什么會(huì)亂顯示?正反轉(zhuǎn)和停止都沒有問題。
程序如下:
#include <reg51.h>
uchar code zixingma[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
sbit key1=P3^0; //正轉(zhuǎn)
sbit key2=P3^1; //反轉(zhuǎn)
sbit key3=P3^2; //停止
sbit a=P2^0;
sbit b=P2^1;
sbit c=P2^2;
sbit d=P2^3;
sbit P10=P1^0;
sbit P11=P1^1;
uchar num1=0;
uchar num2=0;
uchar bushu,flag;
void zheng(void);
void fan(void);
void ting(void);
void key_scan(void);
void delay1m(uint x)
uint i,j;
for(i=0;i<x;i++)
for(j=0;j<200;j++);
void delay5ms(void)
unsigned char i,j;
for(i=10;i>0;i--)
for(j=248;j>0;j--);
flag=0;
key_scan();
switch(flag)
case 1:zheng();break;
case 2:fan();break;
case 3:ting();break;
void zheng()
switch(num1)
case 0:a=1;b=0;c=0;d=0;delay1m(100);break;
case 1:a=1;b=1;c=0;d=0;delay1m(100);break;
case 2:a=0;b=1;c=0;d=0;delay1m(100);break;
case 3:a=0;b=1;c=1;d=0;delay1m(100);break;
case 4:a=0;b=0;c=1;d=0;delay1m(100);break;
case 5:a=0;b=0;c=1;d=1;delay1m(100);break;
case 6:a=0;b=0;c=0;d=1;delay1m(100);break;
case 7:a=1;b=0;c=0;d=1;delay1m(100);break;
P0=0xff;
P10=1;
P11=0;
P0=zixingma[bushu/10];
delay5ms();
P0=0xff;
P10=0;
P11=1;
P0=zixingma[bushu%10];
delay5ms();
num1++;
bushu++;
delay1m(200);
if(num1==8)
num1=0;
void fan()
switch(num2)
case 0:a=1;b=0,c=0,d=0;delay1m(100);break;
case 1:a=1;b=0,c=0,d=1;delay1m(100);break;
case 2:a=0;b=0,c=0,d=1;delay1m(100);break;
case 3:a=0;b=0,c=1,d=1;delay1m(100);break;
case 4:a=0;b=0,c=1,d=0;delay1m(100);break;
case 5:a=0;b=1,c=1,d=0;delay1m(100);break;
case 6:a=0;b=1,c=0,d=0;delay1m(100);break;
case 7:a=1;b=1,c=0,d=0;delay1m(100);break;
P0=0xff;
P10=1;
P11=0;
delay5ms();
P0=0xff;
P10=0;
P11=1;
delay5ms();
num2++;
bushu++;
delay1m(200);
if(num2==8)
num2=0;
void ting()
P1=0;
P2=0;
num1=0;
num2=0;
flag=0;
P0=0xff;
bushu=0;
delay1m(200);
void key_scan()
if(key1==0)
delay5ms();
if(key1==0)
flag=1;
bushu=0;
while(key1==1)
delay5ms();
if(key2==0)
delay5ms();
if(key2==0)
flag=2;
bushu=0;
while(key2==1)
delay5ms();
if(key3==0)
delay5ms();
if(key3==0)
flag=3;
while(key3==1)
delay5ms();
