只需一步,快速開(kāi)始
查看: 3393|回復(fù): 1
這個(gè)直流電機(jī)PID怎么調(diào)節(jié)轉(zhuǎn)速誤差,讓進(jìn)度達(dá)到1位?
#include <REGX51.H>#include<stdio.h>
#define THC0 0xf8
#define TLC0 0x50   //2ms,0x30,含中斷處理時(shí)間時(shí),0x50
#include "LCD.H"
#include "delay.h"
unsigned char aa[]={'T','a','r','g','e','t',' ',' ',' ',' ',' ','r','/','m','i','n'};  //目標(biāo)轉(zhuǎn)速。Target            r/min
unsigned char cc[]={'A','c','t','u','a','l',' ',' ',' ',' ',' ','r','/','m','i','n'};           //實(shí)測(cè)轉(zhuǎn)速: Actual      r/min
uchar flag;
uchar i=0;
sbit PWM_FC=P3^3;
sbit IN1=P3^0;
sbit IN2=P3^1;
int e ,e1 ,e2 ;//pid 偏差
float uk ,uk1 ,duk ;//pid輸出值
float Kp=0.36,Ki=0.05,Kd=0.016;//pid控制系數(shù)        0.1 0.05 0.016
PID的參數(shù)設(shè)置可以參照以下來(lái)進(jìn)行:
     參數(shù)整定找最佳,從小到大順序查;
         先是比例后積分,最后再把微分加;
         曲線振蕩很頻繁,比例度盤(pán)要放大;
         曲線漂浮繞大灣,比例度盤(pán)往小扳;
         曲線偏離回復(fù)慢,積分時(shí)間往下降;
         曲線波動(dòng)周期長(zhǎng),積分時(shí)間再加長(zhǎng);
         曲線振蕩頻率快,先把微分降下來(lái);
         動(dòng)差大來(lái)波動(dòng)慢。微分時(shí)間應(yīng)加長(zhǎng);
         理想曲線兩個(gè)波,前高后低4比1 ;
         一看二調(diào)多分析,調(diào)節(jié)質(zhì)量不會(huì)低;
int out=0;
uint SpeedSet=2000;
uint cnt=0;
uint Inpluse=0,num=0,zs;//脈沖計(jì)數(shù)
uint PWMTime=100;//脈沖寬度
void PIDControl();
void SystemInit();
void delay(uchar x);
void PWMOUT();
void SetSpeed();
/**************主函數(shù)************/
        SystemInit();
        init();
        LCD_Write_String(0,0,aa);
        zs=1;
            if(flag==1)
                 flag=0;
                if(zs==1)
                    zs=0;
                        cc[7]=num/1000+'0';
                        cc[8]=num/100%10+'0';
                        cc[9]=num/10%10+'0';
                        cc[10]=num%10+'0';
                        LCD_Write_String(0,1,cc);
void PIDControl()        //pid偏差計(jì)算
        e=SpeedSet-num;
        duk=(Kp*(e-e1)+Ki*e+Kd*(e-2*e1+e2));
        uk=uk1+duk;
        out=(int)uk;
        if(out>1000)
                out=1000;
        else if(out<0)
                out=0;
        uk1=uk;
        e2=e1;
        e1=e;
        PWMTime=out;
void delay(uchar x)
        uint i,j;
        for(i=x;i>0;i--)
                for(j=50;j>0;j--);
void PWMOUT()
        if(cnt<PWMTime)
                PWM_FC=1;
                PWM_FC=0;
        if(cnt>1000) cnt=0;
void SystemInit()
        TMOD=0X21;    //t1用來(lái)串口t2定時(shí)
        TH0=THC0;
        TL0=TLC0;
        TH1=0xC0;
        TL1=0XC0;
        ET1=1;
        ET0=1;
        TR0=1;
        TR1=1;
        EX0=1;     //中斷0用來(lái)測(cè)量轉(zhuǎn)速
        IT0=1;
        EA=1;
        e =0;
        e1=0;
        e2=0;
        IN1=1;
        IN2=1;
uchar Key_Scan(void)
        static uchar State_Cnt=0;//靜態(tài)變量,用于改變狀態(tài)過(guò)程
       uchar Key_State = 0;//用于存儲(chǔ)鍵值碼
       switch(State_Cnt)
                case 0x00:P1 = 0x1f;//先往P3(1到4獨(dú)立按鍵)口送0001 1111
               if(P1 != 0x1f)//有無(wú)按鍵被按下
                       State_Cnt = 0x01;//改變狀態(tài)
                        break;
               case 0x01:
                if(P1 != 0x1f)//經(jīng)過(guò)定時(shí)器延時(shí)后,再次判斷按鍵是否按下
                        State_Cnt = 0x02;//改變狀態(tài)
                       Key_State = P1;//把鍵值保存下來(lái)
                        P1 = 0x1f;//恢復(fù)P3,以便下次按下重新保存鍵值
                        break;
                        State_Cnt = 0x00;//改變狀態(tài)
                       break;
                case 0x02:
               if(P1 == 0x1f)//判斷按鍵釋放
                       break;
                default:break;
       return Key_State;//返回鍵值
void Display_Key(uchar key_value)
       switch(key_value)
               case 0x1e:
                           IN1=0;
                   IN2=1;break;//鍵值改變時(shí),做出相應(yīng)的動(dòng)作(用戶自定義動(dòng)作)
               case 0x1d:
                           IN1=1;
                   IN2=1;break;
               case 0x1b:
                           IN1=~IN1;
                   IN2=~IN2;
                   break;
               case 0x17:
                                   SpeedSet+=10;
                        if(SpeedSet>3500)
                                SpeedSet=3500;
                           break;
                           case 0x0f:
                          SpeedSet-=10;
                        if(SpeedSet<0) SpeedSet=0;
                           break;
void int0() interrupt 0
        Inpluse++;
void t0() interrupt 1
        static unsigned int time=0,time1=0;
        TH0=THC0;
        TL0=TLC0;
        time++;  //轉(zhuǎn)速測(cè)量周期
        time1++;
        if(time1>=5)
                time1=0;
                flag=1;
                Display_Key(Key_Scan());//按鍵按下,鍵值碼送入函數(shù),以便做相應(yīng)動(dòng)作
                   aa[7]=SpeedSet/1000+'0';
        aa[8]=SpeedSet/100%10+'0';
        aa[9]=SpeedSet/10%10+'0';
        aa[10]=SpeedSet%10+'0';
        if(time>500)
                zs=1;
                time=0;
                num=Inpluse;         //計(jì)算式中是仿真時(shí),碼盤(pán)數(shù)60時(shí)的情況,如果碼盤(pán)數(shù)n=10時(shí),num=Inpluse*60/n=Inpluse*6;
                Inpluse=0;
                PIDControl();
        PWMOUT();
void timer_1()  interrupt 3
           cnt++;        //cnt越大占空比越高2.5Khz
ID:342451 發(fā)表于 2020-4-27 00:02 | 只看該作者
增大轉(zhuǎn)速上限,還有就是設(shè)置編碼器電機(jī)的一圈脈沖個(gè)數(shù),以及轉(zhuǎn)速計(jì)算周期,使得正好可以計(jì)算達(dá)到奇偶轉(zhuǎn)速數(shù)都可以出現(xiàn),然后就是PID參數(shù)了,這個(gè)慢慢挑
