查看: 5290|回復: 1
基于51單片機pid調節的直流電機pwm控制
ID:738241 發表于 2020-4-26 09:56 | 顯示全部樓層 |閱讀模式
#include <REGX51.H>
#include<intrins.h>
#include<stdio.h>
#define THC0 0xf8
#define TLC0 0x50   //2ms,0x30,含中斷處理時間時,0x50
#define RS_CLR RS=0
#define RS_SET RS=1
#define RW_CLR RW=0
#define RW_SET RW=1
#define EN_CLR EN=0
#define EN_SET EN=1
sbit RS = P2^0;   //定義端口
sbit RW = P2^1;
sbit EN = P2^2;
unsigned char aa[]={'T','a','r','g','e','t',' ',' ',' ',' ',' ','r','/','m','i','n'};  //目標轉速。Target            r/min
unsigned char cc[]={'A','c','t','u','a','l',' ',' ',' ',' ',' ','r','/','m','i','n'};           //實測轉速: Actual      r/min
uchar i=0;
sbit k1=P3^3;
sbit k2=P3^4;
sbit k3=P3^5;
sbit k4=P3^6;
sbit k5=P3^7;
sbit PWM_FC=P1^0;
sbit IN1=P1^1;
sbit IN2=P1^2;
int out=0;
uint SpeedSet=3000;
uint cnt=0;
uint Inpluse=0,num=0,zs;//脈沖計數
uint PWMTime=100;//脈沖寬度
int e ,e1 ,e2 ;//pid 偏差
float uk ,uk1 ,duk ;//pid輸出值
float Kp=0.36,Ki=0.05,Kd=0.016;//pid控制系數        0.1 0.05 0.016
PID的參數設置可以參照以下來進行:
     參數整定找最佳,從小到大順序查;
         先是比例后積分,最后再把微分加;
         曲線振蕩很頻繁,比例度盤要放大;
         曲線漂浮繞大灣,比例度盤往小扳;
         曲線偏離回復慢,積分時間往下降;
         曲線波動周期長,積分時間再加長;
         曲線振蕩頻率快,先把微分降下來;
         動差大來波動慢。微分時間應加長;
         理想曲線兩個波,前高后低4比1 ;
         一看二調多分析,調節質量不會低;
void PIDControl();
void SystemInit();
void delay(uchar x);
void PWMOUT();
void SetSpeed();
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s);
void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data);
void init();
void write_com(unsigned char com);
void write_data(unsigned char date);
uS延時函數,含有輸入參數 unsigned char t,無返回值
unsigned char 是定義無符號字符變量,其值的范圍是
0~255 這里使用晶振12M,精確延時請使用匯編,大致延時
長度如下 T=tx2+5 uS
void DelayUs2x(unsigned char t);
mS延時函數,含有輸入參數 unsigned char t,無返回值
void DelayMs(unsigned char t);
        while(--t);
          while(t--)                 //大致延時1mS
             DelayUs2x(245);
void write_com(unsigned char com) //寫命令
        RS_CLR;
        RW_CLR;
        P0=com;
        DelayMs(3);
        EN_SET;
        DelayMs(3);
        EN_CLR;
void write_data(unsigned char date)         //寫一個字符
        RS_SET;
        RW_CLR;
        P0=date;
        DelayMs(3);
        EN_SET;
        DelayMs(3);
        EN_CLR;
void init()                        //初始化
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
              寫入字符串函數
        if (y == 0)
                 write_com(0x80 + x);
                write_com(0xC0 + x);
        while (*s)
                write_data( *s);
                s ++;
/**************主函數************/
        SystemInit();
        init();
        LCD_Write_String(0,0,aa);
        zs=1;
                SetSpeed();
                if(zs==1)
                    zs=0;
                        cc[7]=num/1000+'0';
                        cc[8]=num/100%10+'0';
                        cc[9]=num/10%10+'0';
                        cc[10]=num%10+'0';
                        LCD_Write_String(0,1,cc);
void PIDControl()        //pid偏差計算
        e=SpeedSet-num;
        duk=(Kp*(e-e1)+Ki*e+Kd*(e-2*e1+e2));
        uk=uk1+duk;
        out=(int)uk;
        if(out>1000)
                out=1000;
        else if(out<0)
                out=0;
        uk1=uk;
        e2=e1;
        e1=e;
        PWMTime=out;
void delay(uchar x)
        uint i,j;
        for(i=x;i>0;i--)
                for(j=50;j>0;j--);
void PWMOUT()
        if(cnt<PWMTime)
                PWM_FC=1;
                PWM_FC=0;
        if(cnt>1000) cnt=0;
void SystemInit()
        TMOD=0X21;    //t1用來串口t2定時
        TH0=THC0;
        TL0=TLC0;
        TH1=0xC0;
        TL1=0XC0;
        ET1=1;
        ET0=1;
        TR0=1;
        TR1=1;
        EX0=1;     //中斷0用來測量轉速
        IT0=1;
        EA=1;
        e =0;
        e1=0;
        e2=0;
        IN1=1;
        IN2=1;
void SetSpeed()
        if(k1==0)
                delay(100);
                if(k1==0)
                   IN1=0;
                   IN2=1;
        if(k2==0)
                delay(100);
                if(k2==0)
                   IN1=1;
                   IN2=1;
        if(k3==0)
                delay(100);
                if(k3==0)
                   IN1=~IN1;
                   IN2=~IN2;
                while(k3==0);
        if(k4==0)
                delay(100);
                if(k4==0)
                        SpeedSet+=10;
                        if(SpeedSet>3500)
                                SpeedSet=3500;
        if(k5==0)
                delay(100);
                if(k5==0)
                        SpeedSet-=10;
                        if(SpeedSet<0) SpeedSet=0;
        aa[7]=SpeedSet/1000+'0';
        aa[8]=SpeedSet/100%10+'0';
        aa[9]=SpeedSet/10%10+'0';
        aa[10]=SpeedSet%10+'0';
void int0() interrupt 0
        Inpluse++;
void t0() interrupt 1
        static unsigned int time=0;
        TH0=THC0;
        TL0=TLC0;
        time++;  //轉速測量周期
        if(time>500)
                zs=1;
                time=0;
                num=Inpluse;         //計算式中是仿真時,碼盤數60時的情況,如果碼盤數n=10時,num=Inpluse*60/n=Inpluse*6;
                Inpluse=0;
                PIDControl();
        PWMOUT();
void timer_1()  interrupt 3
           cnt++;        //cnt越大占空比越高2.5Khz
ID:1 發表于 2020-4-26 16:05 | 顯示全部樓層
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
