自己設(shè)計(jì)了一款基于51單片機(jī)的16*128大屏點(diǎn)陣顯示文字,如效果如下圖:
2020-4-25 12:55 上傳
單片機(jī)源程序如下:
- #include<reg51.h>
- #include<intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit sclk=P1^1;
- sbit rclk=P1^2;
- sbit sdin=P1^0;
- sbit s1=P3^6;
- sbit s2=P3^7;
- bit fangxiang;
- uint alt,net,s3=30*25.5;
- int d1,d2;
- bit mode;
- uchar code tab[]={
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",0*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",1*/
- 0x00,0x80,0x01,0x02,0x06,0x02,0x78,0x82,0x08,0x82,0x08,0x82,0x08,0x82,0x08,0x82,
- 0xFF,0xFE,0x48,0x82,0x08,0x82,0x08,0x82,0x19,0x82,0x08,0x86,0x00,0x02,0x00,0x00,/*"生",2*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFC,0x42,0x08,0x42,0x08,0x42,0x08,0x42,0x08,
- 0x42,0x08,0x42,0x08,0x42,0x08,0x7F,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"日",3*/
- 0x0E,0x00,0x00,0x00,0xFF,0xFF,0x10,0x00,0x0D,0x01,0x11,0x02,0x11,0x0C,0x11,0x70,
- 0xFF,0x80,0x11,0x60,0x11,0x10,0x11,0x0C,0x1F,0x06,0x01,0x03,0x01,0x02,0x00,0x00,/*"快",4*/
- 0x00,0x00,0x00,0x04,0x02,0x18,0x3F,0x30,0x22,0xE0,0x22,0x48,0x22,0x04,0x62,0x02,
- 0x5F,0xFC,0x42,0x00,0xC2,0x00,0xC2,0x40,0x42,0x30,0x02,0x1C,0x00,0x08,0x00,0x00,/*"樂",5*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFA,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"!",6*/
- /*-- 文字: 點(diǎn) --*/
- /*-- 宋體12; 此字體下對應(yīng)的點(diǎn)陣為:寬x高=16x16 --*/
- 0x00,0x01,0x00,0x02,0x03,0xEC,0x02,0x20,0x02,0x20,0x02,0x28,0xFE,0x26,0x12,0x20,
- 0x12,0x28,0x12,0x26,0x12,0x20,0x13,0xE0,0x10,0x08,0x10,0x07,0x00,0x00,0x00,0x00,
- /*-- 文字: 陣 --*/
- 0x00,0x00,0x7F,0xFF,0x40,0x10,0x44,0x08,0x5B,0x10,0x60,0xE0,0x10,0x10,0x13,0x10,
- 0x1D,0x10,0xF1,0x10,0x17,0xFF,0x11,0x10,0x11,0x10,0x11,0x10,0x10,0x10,0x00,0x00,
- /*-- 文字: 顯 --*/
- 0x00,0x02,0x00,0x42,0x00,0x22,0x7F,0x1A,0x49,0x02,0x49,0xFE,0x49,0x02,0x49,0x02,
- 0x49,0x02,0x49,0xFE,0x49,0x02,0x7F,0x0A,0x00,0x12,0x00,0x62,0x00,0x02,0x00,0x00,
- /*-- 文字: 示 --*/
- 0x02,0x04,0x02,0x08,0x42,0x10,0x42,0x60,0x42,0x00,0x42,0x02,0x42,0x01,0x43,0xFE,
- 0x42,0x00,0x42,0x00,0x42,0x00,0x42,0x40,0x42,0x20,0x02,0x10,0x02,0x0C,0x00,0x00,
- /*-- 文字: 屏 --*/
- 0x00,0x02,0x00,0x0C,0x7F,0xF0,0x48,0x20,0x49,0x21,0x4D,0x26,0x4B,0xF8,0x49,0x20,
- 0x49,0x20,0x49,0x20,0x4B,0xFF,0x4D,0x20,0x79,0x20,0x00,0x20,0x00,0x00,0x00,0x00,
- /*-- 文字: 程 --*/
- 0x24,0x10,0x24,0x60,0x25,0x80,0x7F,0xFF,0xC4,0x80,0x44,0x60,0x00,0x02,0x7C,0x92,
- 0x44,0x92,0x44,0x92,0x44,0xFE,0x44,0x92,0x44,0x92,0x7C,0x92,0x00,0x82,0x00,0x00,
- /*-- 文字: 序 --*/
- 0x00,0x02,0x00,0x0C,0x3F,0xF0,0x20,0x00,0x20,0x80,0x20,0x80,0x28,0x80,0xA8,0x82,
- 0x6A,0x81,0x29,0xFE,0x2A,0x80,0x2C,0x80,0x28,0x80,0x20,0xA0,0x20,0xC0,0x00,0x00,
- /*-- 文字: 設(shè) --*/
- 0x02,0x00,0x02,0x00,0x42,0x00,0x33,0xFC,0x00,0x09,0x02,0x11,0x05,0x02,0x79,0xC2,
- 0x41,0x34,0x41,0x08,0x41,0x14,0x79,0x62,0x05,0x82,0x04,0x01,0x04,0x01,0x00,0x00,
- /*-- 文字: 計(jì) --*/
- 0x02,0x00,0x02,0x00,0x42,0x00,0x33,0xFE,0x00,0x04,0x02,0x08,0x02,0x00,0x02,0x00,
- 0x02,0x00,0xFF,0xFF,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x00,0x00,
- /*-- 文字: 與 --*/
- 0x00,0x10,0x00,0x10,0x07,0x10,0xF9,0x10,0x11,0x10,0x11,0x10,0x11,0x10,0x11,0x10,
- 0x11,0x10,0x11,0x12,0x11,0x01,0x11,0x02,0x11,0xFC,0x10,0x00,0x00,0x00,0x00,0x00,
- /*-- 文字: 仿 --*/
- 0x00,0x80,0x01,0x00,0x06,0x00,0x1F,0xFF,0xE0,0x01,0x10,0x02,0x10,0x0C,0x1F,0xF0,
- 0x91,0x00,0x71,0x02,0x11,0x01,0x11,0x02,0x11,0xFC,0x10,0x00,0x10,0x00,0x00,0x00,
- /*-- 文字: 真 --*/
- 0x00,0x08,0x20,0x08,0x20,0x09,0x2F,0xFA,0x2A,0xAC,0x2A,0xA8,0x2A,0xA8,0xFA,0xA8,
- 0x2A,0xA8,0x2A,0xA8,0x2A,0xAC,0x2F,0xFA,0x20,0x09,0x20,0x08,0x00,0x08,0x00,0x00,
- 0x10,0x04,0x1F,0xFC,0x00,0x84,0x01,0x00,0x01,0x00,0x01,0x04,0x00,0xFC,0x00,0x04,/*"h",7*/
- 0x00,0x00,0x00,0x98,0x01,0x24,0x01,0x44,0x01,0x44,0x01,0x44,0x00,0xFC,0x00,0x04,/*"a",8*/
- 0x01,0x01,0x01,0xFF,0x00,0x85,0x01,0x04,0x01,0x04,0x00,0x88,0x00,0x70,0x00,0x00,/*"p",9*/
- 0x01,0x01,0x01,0xFF,0x00,0x85,0x01,0x04,0x01,0x04,0x00,0x88,0x00,0x70,0x00,0x00,/*"p",10*/
- 0x01,0x01,0x01,0x81,0x01,0x71,0x00,0x0E,0x00,0x18,0x01,0x60,0x01,0x80,0x01,0x00,/*"y",11*/
- 0x00,0x00,0x00,0x0C,0x00,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*".",12*/
- 0x10,0x00,0x1F,0xFC,0x00,0x88,0x01,0x04,0x01,0x04,0x00,0x88,0x00,0x70,0x00,0x00,/*"b",13*/
- 0x00,0x00,0x01,0x04,0x19,0x04,0x19,0xFC,0x00,0x04,0x00,0x04,0x00,0x00,0x00,0x00,/*"i",14*/
- 0x01,0x04,0x01,0x04,0x01,0xFC,0x00,0x84,0x01,0x04,0x01,0x00,0x01,0x80,0x00,0x00,/*"r",15*/
- 0x00,0x00,0x01,0x00,0x01,0x00,0x07,0xF8,0x01,0x04,0x01,0x04,0x00,0x00,0x00,0x00,/*"t",16*/
- 0x10,0x04,0x1F,0xFC,0x00,0x84,0x01,0x00,0x01,0x00,0x01,0x04,0x00,0xFC,0x00,0x04,/*"h",17*/
- 0x00,0x00,0x00,0x70,0x00,0x88,0x01,0x04,0x01,0x04,0x11,0x08,0x1F,0xFC,0x00,0x04,/*"d",18*/
- 0x00,0x00,0x00,0x98,0x01,0x24,0x01,0x44,0x01,0x44,0x01,0x44,0x00,0xFC,0x00,0x04,/*"a",19*/
- 0x01,0x01,0x01,0x81,0x01,0x71,0x00,0x0E,0x00,0x18,0x01,0x60,0x01,0x80,0x01,0x00,/*"y",20*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xCC,0x00,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,/*"!",21*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",22*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",23*/
- void delay(uint z) //延時(shí)子函數(shù)
- uchar x;
- for(;z>0;z--)
- for(x=110;x>0;x--);
- void writedata(uchar dat1,uchar dat2,uchar dat3,uchar dat4,uchar dat5,uchar dat6,uchar dat7,uchar dat8,uchar dat9,uchar dat10,uchar dat11,uchar dat12,uchar dat13,uchar dat14,uchar dat15,uchar dat16) //595顯示子函數(shù)
- uchar i;
- for(i=0;i<8;i++) //循環(huán)八次
- dat1=dat1>>1; //數(shù)據(jù)左移
- sdin=CY;
- sclk=1;
- sclk=0;
- dat2=dat2>>1; //數(shù)據(jù)左移
- sdin=CY;
- sclk=1;
- sclk=0;
- dat3=dat3>>1; //數(shù)據(jù)左移
- sdin=CY;
- sclk=1;
- sclk=0;
- dat4=dat4>>1; //數(shù)據(jù)左移
- sdin=CY;
- sclk=1;
- sclk=0;
- dat5=dat5>>1; //數(shù)據(jù)左移
- sdin=CY;
- sclk=1;
- sclk=0;
- dat6=dat6>>1; //數(shù)據(jù)左移
- sdin=CY;
- sclk=1;
- sclk=0;
- dat7=dat7>>1; //數(shù)據(jù)左移
- sdin=CY;
- sclk=1;
- sclk=0;
- dat8=dat8>>1; //數(shù)據(jù)左移
- sdin=CY;
- sclk=1;
- sclk=0;
- dat9=dat9>>1; //數(shù)據(jù)左移
- sdin=CY;
- sclk=1;
- sclk=0;
- dat10=dat10>>1; //數(shù)據(jù)左移
- sdin=CY;
- sclk=1;
- sclk=0;
- dat11=dat11>>1; //數(shù)據(jù)左移
- sdin=CY;
- sclk=1;
- sclk=0;
- dat12=dat12>>1; //數(shù)據(jù)左移
- sdin=CY;
- sclk=1;
- sclk=0;
- dat13=dat13>>1; //數(shù)據(jù)左移
- sdin=CY;
- sclk=1;
- sclk=0;
- dat14=dat14>>1; //數(shù)據(jù)左移
- sdin=CY;
- sclk=1;
- sclk=0;
- dat15=dat15>>1; //數(shù)據(jù)左移
- sdin=CY;
- sclk=1;
- sclk=0;
- dat16=dat16>>1; //數(shù)據(jù)左移
- sdin=CY;
- sclk=1;
- sclk=0;
- rclk=0; //輸出顯示
- rclk=1;
- rclk=0;
- void xianshi() //顯示
- char aa;
- P2=P2+1; //列掃描
- writedata(tab[net+aa],tab[net+aa+1],tab[net+aa+32],tab[net+aa+33],tab[net+aa+64],tab[net+aa+65],tab[net+aa+96],tab[net+aa+97],tab[net+aa+128],tab[net+aa+129],tab[net+aa+160],tab[net+aa+161],tab[net+aa+192],tab[net+aa+193],tab[net+aa+224],tab[net+aa+225]); //顯示數(shù)據(jù)
- delay(1); //延時(shí)
- writedata(0,0,0,0); //清屏
- aa+=2; //數(shù)據(jù)加 實(shí)現(xiàn)掃描
- if(aa>30) aa=0; //循環(huán)16次 清零
- void main() //主函數(shù)
- sclk=0;
- rclk=1;
- ET0=1; //使能定時(shí)器0
- EA=1; //開啟總中斷
- TR0=1; //開始計(jì)數(shù)
- while(1) //無限循環(huán)
- xianshi(); //顯示
- if(s1==0) //檢測按鍵
2020-4-25 15:20 上傳
51單片機(jī)16X128點(diǎn)陣顯示.rar
(204.22 KB, 下載次數(shù): 62)
2020-4-25 12:58 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
