查看: 1755|回復: 0
單片機+ds1302為什么不動? 求幫助
代碼如下秒為什么不動
  1. #include<reg51.h>
  2. #include<intrins.h>
  3. #define uint unsigned int
  5. sbit RS=P2^0;
  6. sbit RW=P2^1;
  7. sbit E=P2^2;
  8. sbit RST=P2^5;
  9. sbit CLK=P2^6;
  10. sbit IO=P2^7;
  11. sbit ACC0=ACC^0;
  12. sbit ACC7=ACC^7;
  13. void delay();                       //延時程序
  14. void lcd1602_write_DAT(uchar DAT);          //寫數據
  15. void lcd1602_write_CMD(uchar CMD);         //寫指令
  16. void lcd1602_init();                           //初始話顯示屏
  17. void dis_char(uchar h,uchar l,uchar dat);   //顯示位置程序
  18. void dis_str(uchar h,uchar l,uchar *p);     //顯示字符串
  19. void dis_num(uchar h,uchar l,uchar num);    //顯示數字
  20. void write_bit(uchar dat);                  //位操作寫
  21. void ds1302_write(uchar add,uchar dat);    //寫1302
  22. void ds1302_init();                //初始值
  23. void init();
  24. uchar read_bit();                        //位操作讀
  25. uchar ds1302_read(uchar add);              //讀取1302
  26. uchar BCD_Decimal(uchar bcd);
  27. uchar miao,fen,shi,ri,yue,nian,zhou;
  28. void main()
  29. {
  30.         lcd1602_init();
  31.         ds1302_init();
  32.         //init();
  33.         while(1)
  34.         {
  35.                 dis_str(1,1,"20");
  36.                 dis_char(1,5,'-');
  37.                 dis_char(1,8,'-');
  38.                 dis_char(2,7,':');
  39.                 dis_char(2,10,':');
  40.                 dis_num(1,3,22);
  41.                 miao=ds1302_read(0x81);
  42.                 dis_num(2,11,miao);
  43.         }
  44. }
  45. void delay()
  46. {
  47.         uchar x,y;
  48.         for(x=0;x<=10;x++)
  49.         for(y=0;y<=20;y++);
  50. }
  51. void lcd1602_write_DAT(uchar DAT)
  52. {
  53.         P0=DAT;
  54.         RS=1;
  55.         RW=0;
  56.         E=0;
  57.         delay();
  58.         E=1;
  59.         delay();
  60.         E=0;
  61. }
  62. void lcd1602_write_CMD(uchar CMD)
  63. {
  64.         P0=CMD;
  65.         RS=0;
  66.         RW=0;
  67.         E=0;
  68.         delay();
  69.         E=1;
  70.         delay();
  71.         E=0;
  72. }
  73. void lcd1602_init()
  74. {
  75.         lcd1602_write_CMD(0x38);//顯示模式設置(16*2)顯示,5*7點陣
  76.         lcd1602_write_CMD(0x01);//顯示清零
  77.         lcd1602_write_CMD(0x06);//顯示光標移動設置
  78.         lcd1602_write_CMD(0x0c);//顯示開關,光標設置
  79. }
  80. void dis_char(uchar h,uchar l,uchar DAT)
  81. {
  82.         if(h==1)
  83.         {
  84.                 lcd1602_write_CMD(0x7F+l);
  85.         }
  86.         if(h==2)
  87.         {
  88.                 lcd1602_write_CMD(0xBF+l);
  89.         }
  90.                 lcd1602_write_DAT(DAT);
  91. }
  92. void dis_str(uchar h,uchar l,uchar *p)
  93. {
  94.         if(h==1)
  95.         {
  96.                 lcd1602_write_CMD(0x7F+l);
  97.         }
  98.         if(h==2)
  99.         {
  100.                 lcd1602_write_CMD(0xBF+l);
  101.         }
  102.         while(1)
  103.         {
  104.                 if(*p=='\0')break;
  105.                 lcd1602_write_DAT(*p);
  106.                 p++;
  107.         }
  108. }
  109. void dis_num(uchar h,uchar l,uchar num)
  110. {
  111.         dis_char(h,l,num/10%10+'0');
  112.         dis_char(h,l+1,num%10+'0');
  113. }
  114. void write_bit(uchar dat)
  115. {
  116.         uchar a;
  117.         ACC=dat;
  118.         RST=1;
  119.         for(a=1;a<=8;a++)
  120.         {
  121.                  IO=ACC^0;
  122.                  CLK=0;
  123.                  CLK=1;
  124.                  ACC=ACC>>1;
  125. }
  126. }
  127. uchar read_bit()
  128. {
  129.         uchar a;
  130.         RST=1;
  131.         for(a=1;a<=8;a++)
  132.         {
  133.                  ACC7=IO;
  134.                  CLK=1;
  135.                  CLK=0;
  136.                  ACC=ACC>>1;
  137.         }
  138. return (ACC);
  139. }
  140. void ds1302_write(uchar add,uchar dat)
  141. {
  142.          RST=0;
  143.         CLK=0;
  144.         RST=1;
  145.         write_bit(add);
  146.         write_bit(dat);
  147.         CLK=1;
  148.         RST=0;
  149. }
  150. uchar ds1302_read(uchar add)
  151. {
  152.         uchar temp;
  153.         RST=0;
  154.         CLK=0;
  155.         RST=1;
  156.         write_bit(add);
  157.         temp=read_bit();
  158.         CLK=1;
  159.         RST=0;
  160.         return(temp);
  161. }
  162. void ds1302_init()
  163. {
  164.         RST=0;
  165.         CLK=0;
  166.         ds1302_write(0x8e,0x00);
  167.         ds1302_write(0x80,0x00);
  168.         ds1302_write(0x82,0x00);
  169.         ds1302_write(0x84,0x12);
  170.         ds1302_write(0x86,0x22);
  171.         ds1302_write(0x88,0x04);
  172.         ds1302_write(0x8a,0x01);
  173.         ds1302_write(0x8c,0x20);
  174.         ds1302_write(0x8e,0x80);
  175. }
