查看: 2001|回復: 1
熱電偶 配置 STM32F103
ID:730478 發表于 2020-4-16 13:38 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
spi通訊模式的熱電偶,采集溫度通過OLED顯示
#include "temper.h"
#include "delay.h"
#define         MAX6675_CS                         GPIO_Pin_12
#define         MAX6675_CSL()                GPIOB->BRR = MAX6675_CS;
#define         MAX6675_CSH()                GPIOB->BSRR = MAX6675_CS;
//void SPI_MAX6675_Init(void)
//        GPIO_InitTypeDef GPIO_InitStructure;
//        SPI_InitTypeDef  SPI_InitStructure;
//        /* 使能 SPI1 時鐘 */
//        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB1Periph_SPI2, ENABLE);
//        RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
//        /* ---------通信I/O初始化----------------
//         * PA5-SPI1-SCK :MAX6675_SCK
//         * PA6-SPI1-MISO:MAX6675_SO
//         * PA7-SPI1-MOSI:MAX6675_SI
//        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15 | GPIO_Pin_13 | GPIO_Pin_14;
//        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
//        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                        // 復用輸出
//        GPIO_Init(GPIOB, &GPIO_InitStructure);
//        /* ---------控制I/O初始化----------------*/
//        /* PA4-SPI1-NSS:MAX6675_CS */                                                        // 片選
//        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
//        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                // 推免輸出
//        GPIO_SetBits(GPIOB, GPIO_Pin_12);                                                // 先把片選拉高,真正用的時候再拉低
//        /* SPI1 配置 */
//        SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
//        SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
//        SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
//        SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
//        SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
//        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
//        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;
//        SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
//        SPI_InitStructure.SPI_CRCPolynomial = 7;
//        SPI_Init(SPI2, &SPI_InitStructure);
//        /* 使能 SPI1  */
//        SPI_Cmd(SPI2, ENABLE);
unsigned char MAX6675_ReadByte(void)
        /* Loop while DR register in not emplty */
        while(SPI_I2S_GetFlagStatus(SPI2,SPI_I2S_FLAG_TXE) == RESET);
        /* Send byte through the SPI1 peripheral */
        SPI_I2S_SendData(SPI2, 0xff);
        /* Wait to receive a byte */
        while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET);
        /* Return the byte read from the SPI bus */
        return SPI_I2S_ReceiveData(SPI2);
unsigned int t,i;
unsigned char c;
unsigned char flag;
float temper=5;
float temper_point=0;
void temper_get(void)
    MAX6675_CSL();
                c = MAX6675_ReadByte();
                i = c;
                i = i<<8;
                MAX6675_CSH();
                i = i|((unsigned int)c);                        //i是讀出來的原始數據
                flag = i&0x04;                                                    //flag保存了熱電偶的連接狀態
                t = i<<1;
                t = t>>4;
                temper = t*0.25;
          temper_point=(int)(temper*100)%100;
          delay_ms(200);
ID:1 發表于 2020-4-19 15:13 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
