查看: 3267|回復: 0
正反轉可控的步進電機 單片機源程序
主要代碼
/***************   writer:shopping.w   ******************/
#include <reg52.h>
uchar code FFW[]=
         0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x09
uchar code REV[]=
         0x09,0x08,0x0c,0x04,0x06,0x02,0x03,0x01
sbit K1 = P3^0;
sbit K2 = P3^1;
sbit K3 = P3^2;
void DelayMS(uint ms)
         uchar i;
        while(ms--)
                 for(i=0;i<120;i++);
void SETP_MOTOR_FFW(uchar n)
         uchar i,j;
        for(i=0;i<5*n;i++)
                 for(j=0;j<8;j++)
                         if(K3 == 0)        break;
                        P1 = FFW[j];
                        DelayMS(25);
void SETP_MOTOR_REV(uchar n)
         uchar i,j;
        for(i=0;i<5*n;i++)
                 for(j=0;j<8;j++)
                         if(K3 == 0)        break;
                        P1 = REV[j];
                        DelayMS(25);
         uchar N = 3;
                 if(K1 == 0)
                         P0 = 0xfe;
                        SETP_MOTOR_FFW(N);
                        if(K3 == 0) break;
                else if(K2 == 0)
                         P0 = 0xfd;
                        SETP_MOTOR_REV(N);
                        if(K3 == 0) break;
                         P0 = 0xfb;
                        P1 = 0x03;
源碼
源碼
27 正反轉可控的步進電機.zip
31.32 KB, 下載次數: 26, 下載積分: 黑幣 -5
文件下載
