只需一步,快速開(kāi)始
查看: 2502|回復(fù): 4
單片機(jī)紅外防盜加時(shí)鐘,兩個(gè)程序的整合問(wèn)題
本人新手,C語(yǔ)言基礎(chǔ)較差,最近設(shè)計(jì)一個(gè)紅外防盜系統(tǒng),要求加時(shí)鐘顯示時(shí)間和報(bào)警時(shí)段,然后自己通過(guò)仿真分別實(shí)現(xiàn)了紅外防盜和時(shí)鐘顯示(報(bào)警時(shí)段還有紕漏),但是整合成一個(gè)的時(shí)候1602顯示屏無(wú)法顯示,因?yàn)樗捷^差,自己一個(gè)人難有進(jìn)展,下面貼程序和仿真情況,請(qǐng)教各位大佬,希望能得到指導(dǎo)。
下面是兩個(gè)程序的整合,希望大佬稍微指導(dǎo)一下
#include<reg52.h>
sbit huang=P2^0;//??
sbit lv=P2^2;//??
sbit hong=P2^4;//??
sbit hongwai=P1^0;//???
sbit butter=P2^6;//??????????
sbit baojing=P1^2;//??????;
sbit bufang=P1^3;//????
sbit quxiao=P1^4;//????
sbit lcdrs=P1^5;
sbit lcden=P1^6;
uchar tt=0;//?????
uchar num=0;//???????
uchar flag=0;//???
uchar count,s1num,s4num;
char miao,shi,fen;
void timer1init(void)//???1,16???2
{        EA=0;
  TMOD=0x11;//?????0?????1
        TH0=(65536-10000)/256;
        TL0=(65536-10000)%256;
        ET0=1;//????0??
        TR0=1;//?????0
        tt=0;//
        EA=0;//????
void delay(uint z)//????
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void main()//???
     huang=0;//?????
                 lv=0;//?????
                 hong=0;//?????
                 timer1init();//??????
            if(!baojing)//??????????
                                        delay(5);//????
                                        if(!baojing)//???????????
            hong=1;//???
                                          lv=0;        //???
                                          flag=7;//?????7
                                          butter=0;//????
                                          EA=0;//???
                                        while(!baojing);//?????????
                                        delay(5);//????????
             if((!bufang)&&(flag<4))//????????????????????
                                        delay(5);//????
                                        if(!bufang)//???????
                                           EA=1;   //????
                                           flag=2;//?=2
                                        while(!bufang);//????????
                                        delay(5);//??
                        if(!quxiao)//???????
                                        delay(5);//????
                                        if(!quxiao)//????????
                                          flag=3;//FLAG??3
                                          butter=1;//?????
                                          tt=0;//
                                          num=0;//????0
                                          EA=0;//???
                                          lv=0;//???
                                          hong=0;//???
                                        while(!quxiao);//??????
                                        delay(5);//????
                    if(flag==4)//???????
                           tt=0;//????0
                           EA=0;//???
                           num=0;//??????
                           lv=1;//???
                           flag=5;//flag??5
                        if(hongwai)//?????????
                           huang=1;
                        else  huang=0;//????????
                        if(flag==5)//??flag??5
                             if(hongwai)//??????
                                    butter=0;//????
                                    EA=1;//???
void write_com(uchar com)//???????
       lcdrs=0;
       lcden=0;
       P0=com;
       delay(5);
       lcden=1;
       delay(5);
       lcden=0;
void write_date(uchar date)//???????
       lcdrs=1;
       lcden=0;
       P0=date;
       delay(5);
       lcden=1;
       delay(5);
       lcden=0;
void write_alarm(uchar add1,uchar date1)//??????
       uchar shi,ge;
       shi=date1/10;//????2????????
       ge=date1%10;
       write_com(0x80+add1);//??????
       write_date(0x30+shi);//????????
       write_date(0x30+ge);//????????
void write_sfm(uchar add,uchar date)//??????
       uchar shi,ge;
       shi=date/10;//????2????????
       ge=date%10;
       write_com(0x80+0x40+add);//??????
void init()//?????
       lcden=0;
       shi=21;
       fen=59;
       miao=58;
       count=0;
       s1num=0;
       s4num=0;
       write_com(0x38);//???1602??
       write_com(0x0c);
       write_com(0x06);
       write_com(0x01);
       write_com(0x80);//????????
       delay(5);
       write_com(0x80+0x40+6);//???????????":"
       write_date(':');
       delay(5);
       write_com(0x80+0x40+9);
       write_date(':');
       delay(5);
                         write_sfm(10,miao);//????????
       write_sfm(7,fen);
       write_sfm(4,shi);
                         TMOD=0x01;//?????0????
       TH0=(65536-50000)/256;//??????
       TL0=(65536-50000)%256;
       EA=1;     //????
       ET0=1;   //????0??
       TR0=1;   //?????0
void printer()//???
       init();//????????
       while(1)//????????
                                 if(hongwai==1)
                                                   delay(5);
                                write_com(0x80+3);
              write_date('*');
                                             delay(5);
              write_com(0x80+6);
              write_date(':');
                                            delay(5);
              write_com(0x80+9);
              write_date(':');
                                             delay(5);
                                write_com(0x80+12);
              write_date('*');
              delay(5);
                                      write_alarm(4,shi);//????????
              write_alarm(7,fen);
              write_alarm(10,miao);
void timer0() interrupt 1
        tt++;
        if(tt==10)
          {tt=0; num++;}
        if((flag==5)&&(num%2==0))//??15????flag=5 ,num?????
            hong=1;
        if((flag==5)&&(num%2==1))//??15????flag=5 ,num?????
            hong=0;
        if((flag==2)&&(num%2==0))//??????flag??2,num?????
              lv=1;
        if((flag==2)&&(num%2==1)) // ??????flag??2,num?????
              lv=0;
        if((flag==2)&&(num==30))//????,num=30?15?,?????????????
           flag=4;
void timer1() interrupt 3
  TH1=(65536-50000)/256;
        TL1=(65536-50000)%256;
        count++;        //??????
       if(count==20)//20?50???1?
              count=0;
              miao++;
              if(miao==60)//???60?????
                     miao=0;//??????
                     fen++;
                     if(fen==60)//????60?????
                            fen=0;//???????
                            shi++;
                            if(shi==24)//????24?????
                                   shi=0;
                            write_sfm(4,shi);//24?????????????
                     write_sfm(7,fen);//??????????
              write_sfm(10,miao);//?????????
估計(jì)是中斷這一塊出了問(wèn)題,但是小白看不出來(lái)問(wèn)題,望指教。
1602時(shí)鐘源程序是這個(gè)
#include<reg51.h>
sbit lcdrs=P1^5;  //??1602??RS?
sbit lcden=P1^6;//??1602??LCDEN?
sbit hw=P1^0;
char miao,shi,fen;
void delay(uint z)  //????
       uint x,y;
       for(x=z;x>0;x--)
              for(y=110;y>0;y--);
       lcdrs=0;
       lcden=0;
       P0=com;
       delay(5);
       lcden=1;
       delay(5);
       lcden=0;
       lcdrs=1;
       lcden=0;
       P0=date;
       delay(5);
       lcden=1;
       delay(5);
       lcden=0;
       uchar shi,ge;
       ge=date1%10;
       uchar shi,ge;
       ge=date%10;
void init()//?????
       lcden=0;
       shi=21;
       fen=59;
       miao=58;
       count=0;
       s1num=0;
       s4num=0;
       write_com(0x0c);
       write_com(0x06);
       write_com(0x01);
       delay(5);
       write_date(':');
       delay(5);
       write_date(':');
       delay(5);
       write_sfm(7,fen);
       write_sfm(4,shi);
       EA=1;     //????
       ET0=1;   //????0??
       TR0=1;   //?????0
void main()//???
       init();//????????
       while(1)//????????
                                 if(hw==0)
                                                   delay(5);
                                write_com(0x80+3);
              write_date('*');
                                             delay(5);
              write_com(0x80+6);
              write_date(':');
                                            delay(5);
              write_com(0x80+9);
              write_date(':');
                                             delay(5);
                                write_com(0x80+12);
              write_date('*');
              delay(5);
              write_alarm(7,fen);
void timer0() interrupt 1//???0??????
       TH0=(65536-50000)/256;//????????
       count++;        //??????
       if(count==17)//20?50???1?
              count=0;
              miao++;
                     miao=0;//??????
                     fen++;
                            fen=0;//???????
                            shi++;
                                   shi=0;
按下按鈕可以顯示報(bào)警時(shí)間
望指教,十分感謝
整合之后的仿真圖,1602不亮
整合之后的仿真圖,1602不亮
1602時(shí)鐘顯示仿真
1602時(shí)鐘顯示仿真
1602顯示問(wèn)題
1602顯示問(wèn)題
ID:691780 發(fā)表于 2020-4-12 21:05 | 只看該作者
man1234567 發(fā)表于 2020-4-12 18:14
在時(shí)鐘程序里插入防盜模塊就可以了,調(diào)試要有耐心一步步地搞。
謝謝您,但是能稍微具體一點(diǎn)點(diǎn)嗎,麻煩您了
ID:691780 發(fā)表于 2020-4-12 21:02 | 只看該作者
xxpp2011 發(fā)表于 2020-4-12 17:37
先把keil里面的中文調(diào)好吧,configuration-editor-encoding-Chinese GB2312
好的
ID:584814 發(fā)表于 2020-4-12 18:14 | 只看該作者
ID:452950 發(fā)表于 2020-4-12 17:37 | 只看該作者
