查看: 36972|回復: 1
Proteus8.9 仿真STM32407ZGT6系列004_獨立看門狗
一,打開文件(可以隨文下載放置在文檔中打開)。(如下圖1所示)
1
二,調整虛擬器件,另存工程文件。(如下圖23所示)
2
3
三,點擊Source Code標簽。(如下圖4所示)
4
四,編輯main.c iwdg.ciwdg.hkey.c key.hled.c led.h 代碼如Proteus8.9 仿真STM32407ZGT6系列001(如下圖5所示)
5
五,Main.c 代碼:
#include "stm32f4xx_conf.h"
#include "sys.h"
#include "delay.h"
#include "usart.h"
#include "led.h"
#include "key.h"
#include "iwdg.h"
int main(void)
       NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
       delay_init(168);
       LED_Init();
       KEY_Init();
    delay_ms(500);
       IWDG_Init(4,1000);
       LED0=0;
       LED1=1;
              if(KEY0 ==1)
                     IWDG_Feed();
              delay_ms(10);
iwdg.c代碼:
#include "iwdg.h"
#include "led.h"
void IWDG_Init(u8 prer,u16 rlr)
       IWDG_WriteAccessCmd(IWDG_WriteAccess_Enable);
       IWDG_SetPrescaler(prer);
       IWDG_SetReload(rlr);
       IWDG_ReloadCounter();//reload
       IWDG_Enable();
void IWDG_Feed(void)
       LED0=~PBin(6);
    LED1=0;
iwdg.h代碼:
#ifndef _IWDG_H
#define _IWDG_H
#include "sys.h"
void IWDG_Init(u8 prer,u16 rlr);
void IWDG_Feed(void);
#endif
led.c代碼:
#include "led.h"
void LED_Init(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);//使能GPIOB時鐘
  //GPIOF9,F10初始化設置
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6| GPIO_Pin_8;//LED對應引腳
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//普通輸出模式
  GPIO_InitStructure.GPIO_OType= GPIO_OType_PP;//推挽輸出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉
  GPIO_Init(GPIOB,&GPIO_InitStructure);//初始化
led.h代碼:
#ifndef __LED_H
#define __LED_H
#include "sys.h"
//LED端口定義
#define LED0 PBout(6) // LED0
#define LED1 PBout(8) // LED1
void LED_Init(void);//初始化
#endif
key.c代碼:
#include "key.h"
#include "delay.h"
void KEY_Init(void)
       RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE);//使能GPIOB時鐘
       GPIO_InitStructure.GPIO_Pin= GPIO_Pin_3; //KEY0 對應引腳
       GPIO_InitStructure.GPIO_Mode= GPIO_Mode_IN;//普通輸入模式
       GPIO_InitStructure.GPIO_Speed= GPIO_Speed_100MHz;//100M
       GPIO_InitStructure.GPIO_PuPd= GPIO_PuPd_DOWN ;//下拉
       GPIO_Init(GPIOB,&GPIO_InitStructure);//初始化GPIOE4
key.h代碼:
#ifndef __KEY_H
#define __KEY_H
#include "sys.h"
#define KEY0              PBin(3)        //PB3
void KEY_Init(void);    //IO初始化
#endif
六,點擊構建工程按鈕,編譯工程(如下圖6所示)
6
七,點擊窗口左下方仿真按鈕,可見黃燈點亮仿真,按下按鈕,進行喂狗,開始跳閃仿真。 (如下圖789所示)
7
8
9
八,選擇release,點擊構建工程按鈕,編譯工程生成Hex文件(如下圖10所示)
10
九, 系列的001-003虛擬仿真與開發板對應已證明:虛擬仿真程序對于開發板有效,之后不再➕上下載到開發板的介紹。
需要進一步了解,請加入QQ群:976235464
Proteus8.9 仿真STM32407ZGT6系列004_獨立看門狗.rar
255.46 KB, 下載次數: 43, 下載積分: 黑幣 -5
附件Proteus8.9 仿真STM32407ZGT6系列004_獨立看門狗在已安裝Proteus8.9的計算機文件夾中打開即可
ID:842164 發表于 2022-1-3 15:16 | 只看該作者
直接卡掉兄弟
