查看: 2551|回復: 1
單片機軟件模擬串口接收字符串,發送字符串 源程序
ID:67274 發表于 2020-4-11 18:55 | 顯示全部樓層 |閱讀模式
部分內容借鑒別人的,stc12c5a60s2通過,如   Delay1_1us(88);  是通過單獨另外寫一個定時器程序,測出來的,需要注意 。
#define    uchar    unsigned char
#define uint    unsigned int
#define MAIN_Fosc      22118400 // 11059200
#define   ci_1us  (double)MAIN_Fosc/12000000
void Delay1_1us(uint b)        //@22.1184MHz
    unsigned char i;
       do{
    _nop_();
    _nop_();
    i = 2;
    while (--i);
        } while (--b);
void Delay1ms(uint b)        //@22.1184MHz
    unsigned char i, j;
    i = 22;
    j = 128;
    do{
                do
                    while (--j);
                } while (--i);
    } while (--b);
sbit    P_TXD1  = P3^1;
void    Tx1Send(uchar dat)        //9600,N,8,1        發送一個字節
{   uint i,m;
    uchar    j;
     EA = 0;
       m =90*ci_1us  ;
    P_TXD1 = 0;
      i=m;              //  i=165;       //stc12 165  104us
       while(--i) ;
    for(j=0; j<8; j++)
        if(dat & 1)        P_TXD1 = 1;
        else            P_TXD1 = 0;
        dat >>= 1; i=m;
        while(--i) ;
    P_TXD1 = 1;
     i=m;
     while(--i) ;
      EA = 1;
    Delay1ms(1);
sbit    p30  = P3^0;
unsigned char Content = 0x00;
bit r()
{unsigned int i;
unsigned char uContent = 0x00;
if(p30 == 0){Delay1_1us(44);
                   if(p30 == 0)
                                        for(i=0;i<8;i++)
                                        uContent = uContent >> 1;
                                        Delay1_1us(88);
                                        if(p30 == 1) uContent |=  0x80;
                              Delay1_1us(88);
                                         Content=uContent;
                              return(1);
else   return(0);
unsigned char sz[6] ;
bit ReceiveString()
    char num=0  ;
    unsigned char count=0;
    loop:
                               if(num<6)
                                         {        while( r()==0)
        count++;
        if(count>280)
        return 0;
                                                     sz[num]=Content;
                                                        count=0;
                                                        num++;
                                                        goto loop;
                                        sz[num]='\0';
                                     return 1;
void PrintString(unsigned char  *puts)
{for (; *puts != 0;    puts++)  Tx1Send(*puts);
ID:213173 發表于 2020-4-11 20:57 | 顯示全部樓層
現在單片機大多數內置硬件串口,用軟件模擬串口沒有多少實際意義,平白占用資源。
