stc 8a或8f硬件iic驅動0.96oled
圖片就不上了 通過stc8f2k16s2實驗(晶振22.1184) 驅動正常
scl接P32,sda接P33(P_SW2 = 0xb0;)
寄存器P_SW2 可更改io口
程序有問題歡迎留言
- #include "STC8A.h"
- #include "oled.h"
- #include "oledfont.h"
- #include "intrins.h"
- void iicInit()
- P_SW2 = 0xb0; // SCL(3.2) SDA(3.3)
- I2CCFG = 0xe0; //開啟iic 主機模式 最高速度
- I2CMSST = 0x00; //關中斷 待機模式
- void delay_ms(unsigned int ms) //晶振22.1184
- while(ms)
- unsigned char i=29, j=183;
- do
- {while (--j);}
- while (--i);
- ms--;
- return;
- void Wait() //等待
- while (!(I2CMSST & 0x40));
- I2CMSST &= ~0x40;
- void IIC_Start()
- I2CMSCR = 0x01; //發(fā)送START命令
- Wait();
- void IIC_Stop()
- I2CMSCR = 0x06; //發(fā)送STOP命令
- Wait();
- void IIC_Wait_Ack()
- I2CMSST = 0x00; //設置ACK信號
- I2CMSCR = 0x05; //發(fā)送ACK命令
- Wait();
- void Write_IIC_Byte(unsigned char dat)
- I2CTXD = dat; //寫數據到數據緩沖區(qū)
- I2CMSCR = 0x02; //發(fā)送SEND命令
- Wait();
- void Write_IIC_Command(unsigned char IIC_Command)
- IIC_Start();
- Write_IIC_Byte(0x78); //Slave address,SA0=0
- IIC_Wait_Ack();
- Write_IIC_Byte(0x00); //write command
- IIC_Wait_Ack();
- Write_IIC_Byte(IIC_Command);
- IIC_Wait_Ack();
- IIC_Stop();
- void Write_IIC_Data(unsigned char IIC_Data)
- IIC_Start();
- Write_IIC_Byte(0x78); //D/C#=0; R/W#=0
- IIC_Wait_Ack();
- Write_IIC_Byte(0x40); //write data
- IIC_Wait_Ack();
- Write_IIC_Byte(IIC_Data);
- IIC_Wait_Ack();
- IIC_Stop();
- void OLED_WR_Byte(unsigned dat,unsigned cmd)
- if(cmd)
- Write_IIC_Data(dat);
- else {
- Write_IIC_Command(dat);
- // fill_Picture
- //void fill_picture(unsigned char fill_Data)
- // unsigned char m,n;
- // for(m=0;m<8;m++)
- // OLED_WR_Byte(0xb0+m,0); //page0-page1
- // OLED_WR_Byte(0x00,0); //low column start address
- // OLED_WR_Byte(0x10,0); //high column start address
- // for(n=0;n<128;n++)
- // OLED_WR_Byte(fill_Data,1);
- ///***********************Delay****************************************/
- //void Delay_50ms(unsigned int Del_50ms)
- // unsigned int m;
- // for(;Del_50ms>0;Del_50ms--)
- // for(m=6245;m>0;m--);
- //void Delay_1ms(unsigned int Del_1ms)
- // unsigned char j;
- // while(Del_1ms--)
- // for(j=0;j<123;j++);
- //坐標設置
- void OLED_Set_Pos(unsigned char x, unsigned char y)
- { OLED_WR_Byte(0xb0+y,OLED_CMD);
- OLED_WR_Byte(((x&0xf0)>>4)|0x10,OLED_CMD);
- OLED_WR_Byte((x&0x0f),OLED_CMD);
- ////開啟OLED顯示
- //void OLED_Display_On(void)
- // OLED_WR_Byte(0X8D,OLED_CMD); //SET DCDC命令
- // OLED_WR_Byte(0X14,OLED_CMD); //DCDC ON
- // OLED_WR_Byte(0XAF,OLED_CMD); //DISPLAY ON
- ////關閉OLED顯示
- //void OLED_Display_Off(void)
- // OLED_WR_Byte(0X10,OLED_CMD); //DCDC OFF
- // OLED_WR_Byte(0XAE,OLED_CMD); //DISPLAY OFF
- //清屏函數,清完屏,整個屏幕是黑色的!和沒點亮一樣!!!
- void OLED_Clear(void)
- u8 i,n;
- for(i=0;i<8;i++)
- OLED_WR_Byte (0xb0+i,OLED_CMD); //設置頁地址(0~7)
- OLED_WR_Byte (0x00,OLED_CMD); //設置顯示位置—列低地址
- OLED_WR_Byte (0x10,OLED_CMD); //設置顯示位置—列高地址
- for(n=0;n<128;n++)OLED_WR_Byte(0,OLED_DATA);
- } //更新顯示
- //void OLED_On(void)
- // u8 i,n;
- // for(i=0;i<8;i++)
- // OLED_WR_Byte (0xb0+i,OLED_CMD); //設置頁地址(0~7)
- // OLED_WR_Byte (0x00,OLED_CMD); //設置顯示位置—列低地址
- // OLED_WR_Byte (0x10,OLED_CMD); //設置顯示位置—列高地址
- // for(n=0;n<128;n++)OLED_WR_Byte(1,OLED_DATA);
- // } //更新顯示
- //在指定位置顯示一個字符,包括部分字符
- //x:0~127
- //y:0~63
- //mode:0,反白顯示;1,正常顯示
- //size:選擇字體 16/12
- void OLED_ShowChar(u8 x,u8 y,u8 chr,u8 Char_Size)
- unsigned char c=0,i=0;
- c=chr-' ';//得到偏移后的值
- if(x>Max_Column-1){x=0;y=y+2;}
- if(Char_Size ==16)
- OLED_Set_Pos(x,y);
- for(i=0;i<8;i++)
- OLED_WR_Byte(F8X16[c*16+i],OLED_DATA);
- OLED_Set_Pos(x,y+1);
- for(i=0;i<8;i++)
- OLED_WR_Byte(F8X16[c*16+i+8],OLED_DATA);
- else {
- for(i=0;i<6;i++)
- OLED_WR_Byte(F6x8[c][i],OLED_DATA);
- //顯示單個數字
- void OLED_Showm(u8 x,u8 y,u32 num,u8 size2)
- u8 i,f,g;
- if(num>>15)//負溫度
- num=num&0x7fff;//高位清零
- i=num/100;
- f=num%100/10;
- g=num%10;
- OLED_ShowChar(x,y,'-',size2);
- OLED_ShowChar(x+size2/2,y,f+'0',size2);
- OLED_ShowChar(x+size2,y,'.',size2);
- OLED_ShowChar(x+size2+4,y,g+'0',size2);
- else
- i=num/100;
- f=num%100/10;
- g=num%10;
- OLED_ShowChar(x,y,i+'0',size2);
- //m^n函數
- //u32 oled_pow(u8 m,u8 n)
- // u32 result=1;
- // while(n--)result*=m;
- // return result;
- //顯示2個數字
- //x,y :起點坐標
- //len :數字的位數
- //size:字體大小
- //mode:模式 0,填充模式;1,疊加模式
- //num:數值(0~4294967295);
- //void OLED_ShowNum(u8 x,u8 y,u32 num,u8 len,u8 size2)
- // u8 t,temp;
- // u8 enshow=0;
- // for(t=0;t<len;t++)
- // temp=(num/oled_pow(10,len-t-1))%10;
- // if(enshow==0&&t<(len-1))
- // if(temp==0)
- // OLED_ShowChar(x+(size2/2)*t,y,' ',size2);
- // continue;
- // }else enshow=1;
- // OLED_ShowChar(x+(size2/2)*t,y,temp+'0',size2);
- //顯示一個字符號串
- void OLED_ShowString(u8 x,u8 y,u8 *chr,u8 Char_Size)
- unsigned char j=0;
- while (chr[j]!='\0')
- { OLED_ShowChar(x,y,chr[j],Char_Size);
- x+=8;
- if(x>120){x=0;y+=2;}
- j++;
- //顯示漢字
- void OLED_ShowCHinese(u8 x,u8 y,u8 no)
- u8 t,adder=0;
- for(t=0;t<16;t++)
- OLED_WR_Byte(Hzk[2*no][t],OLED_DATA);
- adder+=1;
- for(t=0;t<16;t++)
- OLED_WR_Byte(Hzk[2*no+1][t],OLED_DATA);
- adder+=1;
- /***********功能描述:顯示顯示BMP圖片128×64起始點坐標(x,y),x的范圍0~127,y為頁的范圍0~7*****************/
- //void OLED_DrawBMP(unsigned char x0, unsigned char y0,unsigned char x1, unsigned char y1,unsigned char BMP[])
- // unsigned int j=0;
- // unsigned char x,y;
- // if(y1%8==0) y=y1/8;
- // else y=y1/8+1;
- // for(y=y0;y<y1;y++)
- // OLED_Set_Pos(x0,y);
- // for(x=x0;x<x1;x++)
- // OLED_WR_Byte(BMP[j++],OLED_DATA);
- //初始化SSD1306
- void OLED_Init(void)
程序如果不好用,請看2樓和4樓的修改方案:
0.96OLED硬件iic.zip
(113.51 KB, 下載次數: 235)
2020-4-10 23:33 上傳
