只需一步,快速開(kāi)始
查看: 1505|回復(fù): 0
為什么我的dspic30f4011上LCD就是不能顯示?
ID:654913 發(fā)表于 2020-4-6 21:01 | 只看該作者 回帖獎(jiǎng)勵(lì) |正序?yàn)g覽 |閱讀模式
為什么我的dspic30f4011上LCD就是不能顯示,以下是程序。
#include<p30f4011.h>
_FOSC(CSW_FSCM_OFF&XT_PLL4);      //4倍頻晶振,F(xiàn)ailsafe時(shí)鐘關(guān)閉
_FWDT(WDT_OFF);                   //關(guān)閉看門(mén)狗定時(shí)器
_FBORPOR(PBOR_OFF&MCLR_EN);       //掉電復(fù)位禁止,MCLR復(fù)位時(shí)能
_FGS(CODE_PROT_OFF);              //代碼保護(hù)禁止
#define RS LATFbits.LATF4
#define RW LATFbits.LATF5
#define E  LATBbits.LATB6
#define out LATD    //4位輸入--RD0-4
void LCD_initialize();//初始化函數(shù)
void check_busy();//查忙函數(shù),但是這次沒(méi)有用到
void write_command(uchar com);//寫(xiě)命令函數(shù)
void write_data(uchar dat);//寫(xiě)數(shù)據(jù)函數(shù)
void string(uchar ad,uchar*p,uchar n);//使Lcd顯示字符的函數(shù)
void delay(uchar i);//延時(shí)函數(shù)
void delay(uchar i)//延時(shí)函數(shù)
  uchar t;
  while(i--)
    for(t=0;t<120;t++);
void write_command(uchar com)//寫(xiě)命令函數(shù)
        delay(1);
        E=0;
        RS=0;
        RW=0;
        out=com;
        delay(1);
        E=1;
        delay(1);
        E=0;
        out=com <<4;
        delay(1);
        E=1;
        delay(1);
        E=0;
void write_data(uchar dat)//寫(xiě)數(shù)據(jù)函數(shù)
        delay(1);
        E=0;
        RS=1;
        RW=0;
        out=dat;
        delay(1);
        E=1;
        delay(1);
        E=0;
        out=dat <<4;
        delay(1);
        E=1;
        delay(1);
        E=0;
void LCD_initialize()//初始化函數(shù)
        //RW=0;
        write_command(0x32);
        write_command(0x28);
        write_command(0x0c);
        write_command(0x06);
        write_command(0x01);
        write_command(0x80);
void string(uchar ad,uchar *p,uchar n)//顯示字符函數(shù)
        uchar i;
        write_command(ad);
        for(i=0;i<n;i++)
                write_data(*p++);
                delay(100);
                     delay(1);
        LCD_initialize();//LCD初始化
                string(0x85,"welcome",7);//寫(xiě)入welcome
                string(0xc2,"Harbin China",12);//寫(xiě)入Harbin China
                delay(100);
                write_command(0x01);//清屏
                delay(100);
