查看: 1098|回復: 0
有沒有大佬幫我把這程序注釋一下啊,看不懂啊 求幫助
ID:696647 發表于 2020-4-6 12:58 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include"main.h"
#include"delay.h"
#include"keypad.h"
#include"display.h"
        INT0_Initial();
        Time0_Initial();
        delay_ms(10);
        LED = 0;
                switch(key_value)
                        case 12:
                                num1 ++;key_value = 0;
                                flag1 = 0;
                                if(num1>255)
                                        num1 = 0;
                                break;
                        case 13:
                                num1 --;key_value = 0;
                                flag1 = 0;
                                if(num1>255)
                                        num1 = 255;
                                break;
                        case 14:
                                num2 ++;key_value = 0;
                                flag1 = 0;
                                if(num2>255)
                                        num2 = 0;
                                break;
                        case 15:
                                num2 --;key_value = 0;
                                flag1 = 0;
                                if(num2>255)
                                        num2 = 255;
                                break;
                        case 1:
                                TR0 = 1;
                                key_value = 0;
                                break;
                        case 2:
                                num1 = 0;num2 = 0;
                                num = 4;
                                secs = 0;minutes = 12;
                                m_secs = 24;
                                key_value = 0;
                                TR0 = 1;
                                break;
                        case 3:
                                TR0 = 0;
                                key_value = 0;
                                break;
                        default:
                                break;
                HEXTOBCD();
                delay_us(10);
                Display(table);
                delay_us(10);
