有需要的可以下載- //利用超聲波測距傳感器實(shí)現(xiàn)小車平衡
- char val='z'; //調(diào)節(jié)與控制命令字
- double Kp=0.01, Kd=0.02; //PID系數(shù)
- unsigned int PB_ad=0, KP_ad=0, KD_ad=0, i; //平衡點(diǎn)調(diào)整,PID各調(diào)整設(shè)定系數(shù)
- unsigned int Len_Echo = 0; //回波時(shí)間
- int E_0 = 0, E_1 = 0, PWM_Out; //誤差,PWM輸出
- double Len_filter = 0, Len_0 = 100; //測距濾波,機(jī)械平衡距離
- unsigned int TrigPin = 4; //HC-SR04觸發(fā)信號
- unsigned int EchoPin = 5; //HC-SR04回波檢測
- unsigned int M_IN1 = 6; // L298-IN1
- unsigned int M_IN2 = 7; // L298-IN2
- unsigned int M_IN3 = 8; // L298-IN3
- unsigned int M_IN4 = 9; // L298-IN4
- unsigned int M_ENA = 10; // L298-ENA
- unsigned int M_ENB = 11; // L298-ENB
- //初始化
- void setup() {
- Serial.begin(115200);
- pinMode(M_ENA, OUTPUT); //電機(jī)控制
- pinMode(M_IN1, OUTPUT);
- pinMode(M_IN2, OUTPUT);
- pinMode(M_ENB, OUTPUT);
- pinMode(M_IN3, OUTPUT);
- pinMode(M_IN4, OUTPUT);
- pinMode(EchoPin, INPUT); //超聲波測距
- pinMode(TrigPin, OUTPUT);
- digitalWrite(TrigPin, LOW);
- for(i=0; i<64; i++) {
- PB_ad += analogRead(A0); //讀取平衡點(diǎn)電位器設(shè)定值
- KP_ad += analogRead(A1); //讀取PID-P電位器設(shè)定值
- KD_ad += analogRead(A2); //讀取PID-D電位器設(shè)定值
- Kp *= KP_ad/64; //Kp = 3.23;
- Kd *= KD_ad/64; //Kd = 8.14;
- Len_0 += PB_ad/640; //Len_0 = 189;
- i = 0;
- //主循環(huán)程序
- void loop() {
- if (Serial.available() > 0) {
- val = Serial.read();
- if(val == 'F') {
- Serial.print(Len_0); Serial.print("\t"); Serial.print(Kp); Serial.print("\t"); Serial.println(Kd);//查看設(shè)置參數(shù)
- if(val == 'L') {
- Serial.print(Len_Echo); Serial.print("\t"); Serial.println(Len_filter); //查看傳感器實(shí)測值,濾波值
- digitalWrite(TrigPin, HIGH); //發(fā)送超聲波測量觸發(fā)脈沖
- delayMicroseconds(10);
- Len_Echo = pulseIn(EchoPin, HIGH); //回波時(shí)間測量
- if((Len_Echo < 300) && (Len_Echo > 70)) {
- Len_filter *= 0.7; //一階互補(bǔ)濾波
- Len_filter += 0.3*Len_Echo;
- i ++;
- if(i > 50){
- E_0 = Len_0 - Len_filter;
- PWM_Out = Kp * E_0 + Kd * (E_0 - E_1);
- E_1 = E_0;
- i = 100;
- SetMotorVoltage(PWM_Out);
- }else {
- SetMotorVoltage(0); //超出平衡范圍,停止PWM輸出
- delay(5); //延時(shí)5毫秒,保證超聲測距可靠工作
- //電機(jī)輸出
- void SetMotorVoltage(int MotorVol) {
- if(MotorVol >=0) {
- digitalWrite(M_IN1, LOW);
- digitalWrite(M_IN2, HIGH);
- digitalWrite(M_IN3, LOW);
- digitalWrite(M_IN4, HIGH);
- }else {
- digitalWrite(M_IN1, HIGH);
- digitalWrite(M_IN2, LOW);
- digitalWrite(M_IN3, HIGH);
- digitalWrite(M_IN4, LOW);
- MotorVol = -MotorVol;
- if(MotorVol > 255) MotorVol = 255; //防止PWM值超過255
- analogWrite(M_ENA, MotorVol);
- analogWrite(M_ENB, MotorVol);
超聲自平衡小車程序.zip
2020-4-4 17:10 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
1.51 KB, 下載次數(shù): 6, 下載積分: 黑幣 -5
自行下載
