#include "config.h"
extern void delay(unsigned long uldata);
extern uint8 nAsrStatus;
uint8 nLD_Mode=LD_MODE_IDLE;
uint8 ucRegVal;
void ProcessInt0(void);
void LD_Reset()
RSTB=1;
delay(5);
RSTB=0;
delay(5);
RSTB=1;
delay(5);
SCS=0;
delay(5);
SCS=1;
delay(5);
void LD_Init_Common()
LD_ReadReg(0x06);
LD_WriteReg(0x17, 0x35);
delay(5);
LD_ReadReg(0x06);
LD_WriteReg(0x89, 0x03);
delay(5);
LD_WriteReg(0xCF, 0x43);
delay(5);
LD_WriteReg(0xCB, 0x02);
/*PLL setting*/
LD_WriteReg(0x11, LD_PLL_11);
if (nLD_Mode == LD_MODE_MP3)
LD_WriteReg(0x1E,0x00);
LD_WriteReg(0x19, LD_PLL_MP3_19);
LD_WriteReg(0x1B, LD_PLL_MP3_1B);
LD_WriteReg(0x1D, LD_PLL_MP3_1D);
LD_WriteReg(0x19, LD_PLL_ASR_19);
LD_WriteReg(0x1B, LD_PLL_ASR_1B);
LD_WriteReg(0x1D, LD_PLL_ASR_1D);
delay(5);
LD_WriteReg(0xCD, 0x04);
LD_WriteReg(0x17, 0x4c);
delay(5);
LD_WriteReg(0xB9, 0x00);
LD_WriteReg(0xCF, 0x4F);
LD_WriteReg(0x6F, 0xFF);
void LD_Init_ASR()
nLD_Mode=LD_MODE_ASR_RUN;
LD_Init_Common();
LD_WriteReg(0xBD, 0x00);
LD_WriteReg(0x17, 0x48);
delay( 10 );
LD_WriteReg(0x3C, 0x80);
LD_WriteReg(0x3E, 0x07);
LD_WriteReg(0x38, 0xff);
LD_WriteReg(0x3A, 0x07);
LD_WriteReg(0x40, 0);
LD_WriteReg(0x42, 8);
LD_WriteReg(0x44, 0);
LD_WriteReg(0x46, 8);
delay( 5 );
uint8 nAsrResCount=0;
EX0=0;
ucRegVal = LD_ReadReg(0x2B);
LD_WriteReg(0x29,0) ;
LD_WriteReg(0x02,0) ;
if((ucRegVal & 0x10)&&LD_ReadReg(0xb2)==0x21&&LD_ReadReg(0xbf)==0x35) /*ʶ±ð³É¹¦*/
nAsrResCount = LD_ReadReg(0xba);
if(nAsrResCount>0 && nAsrResCount<=4)
nAsrStatus=LD_ASR_FOUNDOK;
nAsrStatus=LD_ASR_FOUNDZERO;
} /*ûÓÐʶ±ð½á¹û*/
LD_WriteReg(0x2b, 0);
LD_WriteReg(0x1C,0);/*д0:ADC²»¿ÉÓÃ*/
LD_WriteReg(0x29,0);
LD_WriteReg(0x02,0);
LD_WriteReg(0x2B,0);
LD_WriteReg(0xBA,0);
LD_WriteReg(0xBC,0);
LD_WriteReg(0x08,1); /*Çå³ýFIFO_DATA*/
LD_WriteReg(0x08,0); /*Çå³ýFIFO_DATAºó ÔÙ´Îд0*/
EX0=1;
uint8 LD_Check_ASRBusyFlag_b2()
uint8 j,i;
uint8 flag = 0;
for (j=0; j<5; j++)
i=LD_ReadReg(0xb2);
if ( i== 0x21)
flag = 1;
break;
delay(10);
return flag;
void LD_AsrStart()
LD_Init_ASR();
uint8 LD_AsrRun()
EX0=0;
LD_WriteReg(0x35, MIC_VOL);
LD_WriteReg(0x1C, 0x09);
LD_WriteReg(0xBD, 0x20);
LD_WriteReg(0x08, 0x01);
delay( 5 );
LD_WriteReg(0x08, 0x00);
delay( 5 );
if(LD_Check_ASRBusyFlag_b2() == 0)
return 0;
LD_WriteReg(0xB2, 0xff);
LD_WriteReg(0x37, 0x06);
delay( 10 );
delay( 30 );
LD_WriteReg(0x1C, 0x0b);
LD_WriteReg(0x29, 0x10);
EX0=1;
return 1;
uint8 LD_AsrAddFixed()
uint8 k, flag;
uint8 nAsrAddLength;
#define DATE_A 14 //Êý×é¶þάÊýÖµ
#define DATE_B 20 //Êý×éһάÊýÖµ
uint8 code sRecog[DATE_A][DATE_B] = {
"xiao jie",\
"dai ma ce shi",\
"ce shi wan bi",\
"bei jing",\
"shang hai",\
"kai deng",\
"guan deng",\
"guang zhou",\
"shen zhen",\
"xiang zuo zhuan",\
"xiang you zhuan",\
"da kai kong tiao",\
"guan bi kong tiao",\
"hou tui",\
}; /*Ìí¼Ó¹Ø¼ü´Ê£¬Óû§ÐÞ¸Ä*/
uint8 code pCode[DATE_A] = {
CODE_CMD,\
CODE_DMCS,\
CODE_CSWB,\
CODE_1KL1,\
CODE_1KL2,\
CODE_1KL3,\
CODE_1KL4,\
CODE_2KL1,\
CODE_2KL2,\
CODE_2KL3,\
CODE_2KL4,\
CODE_3KL1,\
CODE_3KL2,\
CODE_5KL1,
}; /*Ìí¼Óʶ±ðÂ룬Óû§ÐÞ¸Ä*/
flag = 1;
for (k=0; k<DATE_A; k++)
flag = 0;
break;
LD_WriteReg(0xc1, pCode[k] );
LD_WriteReg(0xc3, 0 );
LD_WriteReg(0x08, 0x04);
delay(1);
delay(1);
for (nAsrAddLength=0; nAsrAddLength<DATE_B; nAsrAddLength++)
if (sRecog[k][nAsrAddLength] == 0)
break;
LD_WriteReg(0x5, sRecog[k][nAsrAddLength]);
LD_WriteReg(0xb9, nAsrAddLength);
LD_WriteReg(0xb2, 0xff);
LD_WriteReg(0x37, 0x04);
return flag;
uint8 LD_GetResult()
return LD_ReadReg(0xc5 );
LD3320并行串行讀寫輔助說明.pdf
2020-4-2 19:05 上傳
下載積分: 黑幣 -5
349.8 KB, 下載次數: 18, 下載積分: 黑幣 -5
LD3320開發手冊.pdf
2020-4-2 19:05 上傳
下載積分: 黑幣 -5
771.39 KB, 下載次數: 24, 下載積分: 黑幣 -5
LD3320數據手冊.pdf
2020-4-2 19:05 上傳
下載積分: 黑幣 -5
681.43 KB, 下載次數: 20, 下載積分: 黑幣 -5
LD3320芯片簡明調試步驟.pdf
2020-4-2 19:05 上傳
下載積分: 黑幣 -5
135.58 KB, 下載次數: 22, 下載積分: 黑幣 -5
可編輯語音識別芯片LD3320介紹.pdf
2020-4-2 19:05 上傳
下載積分: 黑幣 -5
286.85 KB, 下載次數: 19, 下載積分: 黑幣 -5
語音識別芯片LD3320高階秘籍.pdf
2020-4-2 19:05 上傳
下載積分: 黑幣 -5
332.02 KB, 下載次數: 17, 下載積分: 黑幣 -5
