這是小單采集到關于如何在LCD1602上顯示日歷表的一個51小程序,在這里和大家分享下,希望能幫助到有需要的師兄。LCD1602可以簡單的顯示一些字母數字,但是對于漢字來說,顯示起來還是不太好,不怎么好顯示,畢竟像素比較低,所以這次我們的程序里面用的是英文字母來代替漢字。
- /*******lcd.h*******/
- #ifndef _LCD_H_
- #define _LCD_H_
- #include <reg51.h>
- #include <intrins.h>
- sbit RS = P2^6;
- sbit RW = P2^5;
- sbit EN = P2^7;
- #define RS_CLR RS = 0
- #define RS_SET RS = 1
- #define RW_CLR RW = 0
- #define RW_SET RW = 1
- #define EN_CLR EN = 0
- #define EN_SET EN = 1
- #define dataport P0
- #define uchar unsigned char
- extern void DelayUs2x(uchar t);
- extern void DelayMs(uchar t);
- extern void LCD_Write_COM(uchar com); //寫指令
- extern void LCD_Write_Data(uchar Data);
- extern void LCD_Clear();
- extern void LCD_Write_String(uchar x, uchar y, uchar* s);
- extern void LCD_Write_Char(uchar x, uchar y, uchar c);
- extern void LCD_Init();
- #endif
- /*****lcd.c********/
- #include "lcd.h"
- void DelayUs2x(uchar t)
- while(--t);
- void DelayMs(uchar t)
- while(t--)
- DelayUs2x(245);
- DelayUs2x(245);
- /* bit LCD_Check_busy(void)
- dataport = 0xff;
- RS_CLR;
- RW_SET;
- EN_CLR;
- _nop_();
- EN_SET;
- return (bit)(dataport&0x80);
- //寫指令
- void LCD_Write_COM(uchar com)
- DelayMs(5);
- RS_CLR;
- RW_CLR;
- EN_SET;
- dataport = com;
- _nop_();
- EN_CLR;
- //寫數據
- void LCD_Write_Data(uchar Data)
- DelayMs(5);
- RS_SET;
- RW_CLR;
- EN_SET;
- dataport = Data;
- _nop_();
- EN_CLR;
- //清屏
- void LCD_Clear()
- LCD_Write_COM(0x01);
- DelayMs(5);
- //輸入字符,x為橫坐標,y為縱坐標
- void LCD_Write_String(uchar x, uchar y, uchar* s)
- if(y == 0)
- LCD_Write_COM(0x80+x);
- else
- LCD_Write_COM(0xC0+x);
- while(*s)
- LCD_Write_Data(*s);
- s++;
- void LCD_Write_Char(uchar x, uchar y, uchar c)
- if(y == 0)
- else
- LCD_Write_Data(c);
- void LCD_Init() //LCD初始化子程序
- EN_CLR;
- LCD_Write_COM(0x38); //設置顯示模式
- DelayMs(5);
- DelayMs(5);
- DelayMs(5);
- DelayMs(5);
- LCD_Write_COM(0x0c); //開顯示不顯示光標,光標閃爍
- LCD_Write_COM(0x06); //寫一個指針加一
- LCD_Write_COM(0x01); //清屏
- LCD_Write_COM(0x80); //設置數據指針起點
- /*****main.c*******/
- #include "lcd.h"
- uchar hour = 21, min = 43, sec = 0, count, date = 28, monse = 4;
- unsigned int year = 2017;
- void init_T0()
- EA = 1;
- ET0 = 1;
- TMOD = 0X01;
- TH0 = 0X3C;
- TL0 = 0XB0;
- TR0 = 1;
- void main()
- init_T0();
- LCD_Init();
- LCD_Clear();
- while(1)
- LCD_Write_String(0, 0, "Date:");
- LCD_Write_Char(5, 0, year/1000+48);
- LCD_Write_Char(6, 0, year%1000/100+48);
- LCD_Write_Char(7, 0, year%100/10+48);
- LCD_Write_Char(8, 0, year%10+48);
- LCD_Write_Char(9, 0, '-');
- LCD_Write_Char(10, 0, monse/10+48);
- LCD_Write_Char(11, 0, monse%10+48);
- LCD_Write_Char(12, 0, '-');
- LCD_Write_Char(13, 0, date/10+48);
- LCD_Write_Char(14, 0, date%10+48);
- LCD_Write_String(0, 1, "Time:");
- LCD_Write_Char(5, 1, hour/10+48);
- LCD_Write_Char(6, 1, hour%10+48);
- LCD_Write_Char(7, 1, '-');
- LCD_Write_Char(8, 1, min/10+48);
- LCD_Write_Char(9, 1, min%10+48);
- LCD_Write_Char(0xa, 1, '-');
- LCD_Write_Char(0xb, 1, sec/10+48);
- LCD_Write_Char(0xc, 1, sec%10+48);
- void inter() interrupt 1
- TH0 = 0X3C;
- TL0 = 0XB0;
- count++;
- if(count >= 20)
- count = 0;
- sec++;
- if(sec >= 60)
- sec = 0;
- min++;
- if(min >= 60)
- min = 0;
- hour++;
- if(hour >= 24)
- hour = 0;
- date++;
- if(date > 31)
- date = 0;
- monse++;
- if(monse > 13)
- monse = 0;
- year++;
新建 ZIP 壓縮文件.zip
(1.38 KB, 下載次數: 14)
2020-4-1 16:28 上傳
下載積分: 黑幣 -5
