查看: 2882|回復: 1
96LED貼片焊接測試電路及單片機源程序
ID:210588 發(fā)表于 2020-3-31 14:17 | 顯示全部樓層 |閱讀模式
電路原理圖如下:
  1. #include "STC89C5X.h"
  2. #include "intrins.h"
  3. sbit AB1 = P0^0;
  4. sbit AB2 = P0^1;
  5. sbit AB3 = P0^2;
  6. sbit AB4 = P0^3;
  7. sbit AB5 = P0^4;
  8. sbit AB6 = P0^5;
  9. sbit AB7 = P0^6;
  10. sbit AB8 = P0^7;
  11. sbit AB9 = P1^0;
  12. sbit AB10 = P1^1;
  13. sbit AB11 = P1^2;
  14. sbit AB12 = P1^3;
  15. sbit CLK1 = P2^0;
  16. sbit CLK2 = P2^1;
  17. sbit CLK3 = P2^2;
  18. sbit CLK4 = P2^3;
  19. sbit CLK5 = P2^4;
  20. sbit CLK6 = P2^5;
  21. sbit CLK7 = P2^6;
  22. sbit CLK8 = P2^7;
  23. sbit CLK9 = P4^0;
  24. sbit CLK10 = P4^1;
  25. sbit CLK11 = P4^2;
  26. sbit CLK12 = P4^3;
  27. sbit LE1 = P3^0;
  28. sbit LE2 = P3^1;
  29. sbit LE3 = P3^2;
  30. sbit LE4 = P3^3;
  31. sbit LE5 = P3^4;
  32. sbit LE6 = P3^5;
  33. sbit LE7 = P3^6;
  34. sbit LE8 = P3^7;
  35. sbit LE9 = P1^4;
  36. sbit LE10 = P1^5;
  37. sbit LE11 = P1^6;
  38. sbit LE12 = P1^7;
  39. void Delay500ms()                //@8.000MHz
  40. {
  41.         unsigned char i, j, k;
  42.         i = 3;
  43.         j = 137;
  44.         k = 123;
  45.         do
  46.         {
  47.                 do
  48.                 {
  49.                         while (--k);
  50.                 } while (--j);
  51.         } while (--i);
  52. }
  53. void disp_led(unsigned char d)
  54. {
  55.         unsigned char i;
  56.
  57.         LE1=LE2=LE3=LE4=LE5=LE6=LE7=LE8=LE9=LE10=LE11=LE12 = 0;
  58.         for(i=0;i<8;i++)
  59.         {
  60.                 if((d&1) == 0)
  61.                 {
  62.                         AB1=AB2=AB3=AB4=AB5=AB6=AB7=AB8=AB9=AB10=AB11=AB12=0;
  63.                 }
  64.                 else
  65.                 {
  66.                         AB1=AB2=AB3=AB4=AB5=AB6=AB7=AB8=AB9=AB10=AB11=AB12=1;
  67.                 }
  68.
  69.                 CLK1=CLK2=CLK3=CLK4=CLK5=CLK6=CLK7=CLK8=CLK9=CLK10=CLK11=CLK12=1;
  70.                 _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
  71.                 CLK1=CLK2=CLK3=CLK4=CLK5=CLK6=CLK7=CLK8=CLK9=CLK10=CLK11=CLK12=0;
  72.                 d=d>>1;
  73.         }
  74.
  75.         LE1=LE2=LE3=LE4=LE5=LE6=LE7=LE8=LE9=LE10=LE11=LE12 = 1;
  76. }
  77. void main(void)
  78. {
  79.
  80.         disp_led(0);
  81.         while(1)
  82.         {
  83.
  84.                 disp_led(1);
  85.                 Delay500ms();
  86.
  87.                 disp_led(1<<1);
  88.                 Delay500ms();
  89.
  90.                 disp_led(1<<2);
  91.                 Delay500ms();
  92.
  93.                 disp_led(1<<3);
  94.                 Delay500ms();
  95.
  96.                 disp_led(1<<4);
  97.                 Delay500ms();
  98.
  99.                 disp_led(1<<5);
  100.                 Delay500ms();
  101.
  102.                 disp_led(1<<6);
  103.                 Delay500ms();
  104.
  105.                 disp_led(1<<7);
  106.                 Delay500ms();
  107.
  108.                 disp_led(0xff);
  109.                 Delay500ms();
  110.
  111.         }
  112.
  113.
  114. }
96LED 貼片焊接.rar (332.77 KB, 下載次數(shù): 7)
參與人數(shù) 1黑幣 +50 收起 理由
ID:328014 發(fā)表于 2020-3-31 14:39 | 顯示全部樓層
好東東 有用啊 大神能介紹下工作原理嗎?
