查看: 2645|回復: 3
單片機串口如何輸入兩位數字進行判斷?
ID:715844 發表于 2020-3-26 23:08 | 顯示全部樓層 |閱讀模式
我使用STC89C52單片機,晶振為12MHz,串口通訊,工作方式為1,SMOD=1,波特率為4800,當接收到一位數字的時候,在一個數碼管上顯示這個數字,如果不是一位數字,則在數碼管上顯示一個“點”符號。我的代碼實現了從串口輸入0-9時,再數碼管上顯示對應數字,但是當輸入兩位數時,由于char是一位字節的限制,只能顯示第一位數字,要如何修改我的代碼才能進行判斷后當從串口輸入兩位數字時在數碼管上顯示點?
求論壇里各位大神幫助!
  1. #include "reg52.h"
  2. #include "intrins.h"
  3. typedef unsigned char u8;
  4. typedef unsigned int u16;
  5. sbit LSA = P2^2; //define the input pins for 74HC138
  6. sbit LSB = P2^3;
  7. sbit LSC = P2^4;
  8. u8 code display_digit[10] = {0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07,
  9.         0x7f, 0x6f};
  10. u8 saved_data[8];
  11. void delay(u16 i)
  12. {
  13.         while(i--);
  14. }
  15. u8 char2hex(u8 chr)
  16. {
  17.         if(chr>='0'&&chr<='9')
  18.                 return (chr-'0');
  19.         else
  20.                 return ('a');
  21. }
  22. void display()
  23. {
  24.         u8 counter;
  25.         for(counter=0; counter<8; counter++)
  26.         {
  27.                 switch(counter)
  28.                 {
  29.                         case 0:
  30.                                 LSA = 0; LSB = 0; LSC = 0;
  31.                                 break; // exit from switch loop
  32.                         case 1:
  33.                                 LSA = 1; LSB = 0; LSC = 0;
  34.                                 break;
  35.                         case 2:
  36.                                 LSA = 0; LSB = 1; LSC = 0;
  37.                                 break;
  38.                         case 3:
  39.                                 LSA = 1; LSB = 1; LSC = 0;
  40.                                 break;
  41.                         case 4:
  42.                                 LSA = 0; LSB = 0; LSC = 1;
  43.                                 break;
  44.                         case 5:
  45.                                 LSA = 1; LSB = 0; LSC = 1;
  46.                                 break;
  47.                         case 6:
  48.                                 LSA = 0; LSB = 1; LSC = 1;
  49.                                 break;
  50.                         case 7:
  51.                                 LSA = 1; LSB = 1; LSC = 1;
  52.                                 break;
  53.                 }
  54.                 P0 = saved_data[counter];
  55.                 delay(100);
  56.                 P0 = 0x00; // erase shoadows
  57.         }
  58. }
  59. void serial_init()
  60. {
  61.         TMOD = 0x20;
  62.         TH1 = 0xf3;
  63.         TL1 = 0xf3;
  64.         PCON = 0x80;
  65.         TR1 = 1;
  66.         SCON = 0x50;
  67.         ES = 1;
  68.         EA = 1;
  69. }
  70. void main()
  71. {
  72.         serial_init();
  73.         while(1);
  74. }
  75. void serial() interrupt 4
  76. {
  77.         u8 received_data;
  78.         if(RI==1)
  79.         {
  80.                 received_data = SBUF;
  81.                 RI = 0;
  82.                 SBUF = received_data;
  83.                 while(!TI);
  84.                 received_data = char2hex(received_data);
  85.                 if (received_data!='a')
  86.                 {
  87.                         saved_data[0] = 0x00;
  88.                         saved_data[1] = 0x00;
  89.                         saved_data[2] = 0x00;
  90.                         saved_data[3] = 0x00;
  91.                         saved_data[4] = 0x00;
  92.                         saved_data[5] = 0x00;
  93.                         saved_data[6] = 0x00;
  94.                         saved_data[7] = display_digit[received_data];
  95.                 }
  96.                 else
  97.                 {
  98.                         saved_data[0] = 0x80;
  99.                         saved_data[1] = 0x80;
  100.                         saved_data[2] = 0x80;
  101.                         saved_data[3] = 0x80;
  102.                         saved_data[4] = 0x80;
  103.                         saved_data[5] = 0x80;
  104.                         saved_data[6] = 0x80;
  105.                         saved_data[7] = 0x80;
  106.                 }
  107.         }
  108.         display();
  109. }
ID:65956 發表于 2020-3-27 08:33 | 顯示全部樓層
開串口接收緩沖區,先把接收數據緩存下來,接收完后再去判斷接收到的數據,根據數據再去判斷要用還是不用,取有用的信息給顯示就可以了
ID:697917 發表于 2020-3-27 09:03 | 顯示全部樓層
數字都顯示的原理是利用余暉動態顯示,實際是不同位的數字來回切換,你的代碼中只有接收中斷進行過接收數字顯示。即每位只顯示1次100ms,之后停留在最新的那條中。當然顯示不了全部的內容。
終端中不要進行太多內容操作。設個標志,外面查詢標志去做處理。
ID:715844 發表于 2020-3-27 14:47 | 顯示全部樓層
黎明初至 發表于 2020-3-27 09:03
數字都顯示的原理是利用余暉動態顯示,實際是不同位的數字來回切換,你的代碼中只有接收中斷進行過接收數字 ...
謝謝回復,但是我不是想顯示兩位數字,我是想在輸入兩位數字的時候數碼管顯示一個點(即'.')。但是數碼管上顯示的都是數字。
