只需一步,快速開(kāi)始
查看: 3896|回復(fù): 1
基于51單片機(jī)樓宇對(duì)講系統(tǒng)程序
原理圖
程序
#include<reg51.h>
#define DUAN P0
#define WEI P1
#define KEYMATRIX P3
sbit ON=P1^0;//開(kāi)關(guān)標(biāo)志燈
sbit sure=P0^7;        //通話鍵
sbit KA=P1^7;
sbit KB=P1^6;
sbit KC=P1^5;
sbit INH=P1^4;
sbit OpenD=P3^7;        //開(kāi)鎖鍵
sbit Beep=P3^0;                //呼叫響鈴
uchar dispbuf[8],dispcount;
uchar Key,result,password;
uint sum=0,temp;
uint num;        //等待變量
uchar code dispbitcode[]=
{0xfd,0xfb,0xf7,}; //共陽(yáng)位碼表
unsigned char code dispcode[]=
        0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0xbf,0xff
}; //共陽(yáng)段碼表
//0,1,2,3,4,5,6,7,8,9,A,b,C,c,d,E,F,-;NULL
void delay(uint z)//延時(shí)1ms子函數(shù)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void ledinit()/***初始化子函數(shù),定時(shí)器0刷新顯示內(nèi)容***/
        TMOD|=0x01;  //  定時(shí)器0方式1
        TH0=(65536-5000)/256;
        TL0=(65536-5000)%256;
        TR0=1;
        ET0=1;
        EA=1;
/***顯示子函數(shù)**/
void leddisp(uint x)
        dispbuf[0]=x%10;
        dispbuf[1]=x/10%10;
        dispbuf[2]=x/100;
unsigned char Keyscan(void) //按鍵掃描程序 P2.0--P2.3為行線 P2.4--P2.7為列線
        unsigned char rcode, ccode;
        KEYMATRIX = 0xF1;      // 發(fā)全0行掃描碼,列線輸入
        Beep=1;
        if((KEYMATRIX & 0xF1) != 0xF1) // 若有鍵按下
                delay(5);// 延時(shí)去抖動(dòng)
                Beep=1;
                        rcode = 0xFd;         // 逐行掃描初值
                        while((rcode & 0x10) != 0)
                                KEYMATRIX = rcode;         // 輸出行掃描碼
                                if((KEYMATRIX & 0xF1) != 0xF1) // 本行有鍵按下
                                        ccode = (KEYMATRIX & 0xF0) | 0x0F;
                                        while((KEYMATRIX & 0xF1) != 0xF1); //等待鍵釋放
                                        Beep=1;
                                        return ((~rcode) + (~ccode)); // 返回鍵編碼
                                        rcode = (rcode<<1)|0x01; // 行掃描碼左移一位
        Beep=1;
        return 0; // 無(wú)鍵按下,返回值為0
Keyresult(unsigned char key)
   switch(key)
/*   case 0x11: return(7); break;
   case 0x21: return(8); break;
   case 0x41: return(9); break;                  */
//  case 0x81: return(?); break;
   case 0x12: return(4); break;
   case 0x22: return(5); break;
   case 0x42: return(6); break;
//   case 0x82: return(7); break;
   case 0x14: return(1); break;
   case 0x24: return(2); break;
   case 0x44: return(3); break;
//  case 0x84: return(11); break;
   case 0x18: return(12); break;//*
   case 0x28: return(0); break;
   case 0x48: return(14); break;//#
//  case 0x88: return(15); break;
   default: break;
void alarm()
        for(temp=0;temp<5;temp++)
                P2=0X00;
                delay(200);
                P2=0XFF;
                delay(200);
void hujiao()         //呼叫聲
        uchar a;
        for(a=0;a<5;a++)
                Beep=!Beep;
                delay(50);
void open()
        P2=0xbf;
        delay(100);
        P2=0xef;
        delay(100);
        P2=0xfb;
        delay(100);
        P2=0xfe;
        delay(100);
        delay(100);
        P2=0x7f;
        delay(100);
        P2=0xdf;
        delay(100);
        P2=0xf7;
        delay(100);
        P2=0xfd;
        delay(100);
        P2=0XFf;
start:
        ledinit();
//P1=0x40;
                Key = Keyscan();
                if(Key)
                        result = Keyresult(Key);
                        if(result==14)//#密碼鎖狀態(tài)
                                dispbuf[0]=15;
                                dispbuf[1]=15;
                                dispbuf[2]=15;
                                password=sum=0;
                                do
                                        Key = Keyscan(); //檢測(cè)鍵盤
                                        if(Key)//有按鍵按下
                                                result = Keyresult(Key);//讀入按鍵值
                                                if(result>=0&&result<=9)//屬于數(shù)字的輸入
                                                        sum=sum*10+result;//計(jì)算累計(jì)數(shù)
                                                if(result==12)//清零按鍵按下?
                                                        sum=0;//結(jié)果清零
                                                leddisp(sum);//顯示結(jié)果
                                                if(sum>100)//已經(jīng)輸入三位數(shù)了,但是密碼錯(cuò)
                                                        delay(1000);//延時(shí)并且報(bào)警
                                                        password=sum;//讀入密碼值
                                                        sum=0;//結(jié)果清零
                                                        if(password!=123)
        alarm();//密碼錯(cuò)誤,報(bào)警
                                }while(password!=123);//等待密碼正確
                                ON=0;//開(kāi)鎖
                                for(temp=0;temp<3;temp++)
                                        open();
                                delay(2000);
                                ON=1;
                                sum=0;
                                        sum=0;//結(jié)果為零
                                if(result>=0&&result<=9)//屬于數(shù)字輸入?
                                        sum=sum*10+result;//將結(jié)果計(jì)算出
                }//以上是矩陣鍵盤操作
                if(sum>100)
                        switch(sum)//輸入正確,點(diǎn)亮對(duì)應(yīng)的住戶指示燈
                        {                //否則報(bào)警,重新輸入
                                case  101:P2=0xbf;KC=0;KB=0;KA=0;hujiao();break;//對(duì)應(yīng)八種結(jié)果
                                case  102:P2=0x7f;KC=0;KB=0;KA=1;hujiao();break;
                                case  201:P2=0xef;KC=0;KB=1;KA=0;hujiao();break;
                                case  202:P2=0xdf;KC=0;KB=1;KA=1;hujiao();break;
                                case  301:P2=0xfb;KC=1;KB=0;KA=0;hujiao();break;
                                case  302:P2=0xf7;KC=1;KB=0;KA=1;hujiao();break;
                                case  401:P2=0xfe;KC=1;KB=1;KA=0;hujiao();break;
                                case  402:P2=0xfd;KC=1;KB=1;KA=1;hujiao();break;
                                default : P2=0XFf;alarm();sum=0;hujiao();break;
//                sure=1;
                if(sure==0)        //一旦按下通話鍵
                        Beep=1;
                        num=0;
                        if(sum==0)
                                INH=1;//關(guān)閉4051
                        if(sum>100)                //接通對(duì)應(yīng)的攝像頭。
                                INH=~INH;//開(kāi)啟4051
                                if(!INH)
                                        P2=0xff;//關(guān)閉報(bào)警燈
                                        sum=0;//結(jié)果清零
//                        ON=~ON;
                        while(!sure);//松開(kāi)鍵盤檢測(cè)
                        if(sum>100)
                                num++;
                                if(num>40)
                                        num=0;
                                        P2=0XFf;
                                        sum=0;
                                        Beep=1;
                                        goto start;
                if(OpenD==0)        //開(kāi)鎖鍵
                        delay(10);
                        if(OpenD==0)
                                ON=0;
                        while(!OpenD);
                        delay(2000);
                                ON=1;
/***定時(shí)器0刷新顯示內(nèi)容**/
void t0(void) interrupt 1 //using 0
        WEI|=0x0e;//關(guān)位選
        DUAN=dispcode[dispbuf[dispcount]]; //段選
        WEI&=dispbitcode[dispcount]; //開(kāi)位選
        dispcount++;
        if(dispcount==3)
           dispcount=0;
1.C語(yǔ)言程序.zip
48.84 KB, 下載次數(shù): 36, 下載積分: 黑幣 -5
程序
3.Protel99se圖.zip
114.82 KB, 下載次數(shù): 36, 下載積分: 黑幣 -5
原理圖
ID:1112461 發(fā)表于 2024-3-9 15:19 | 只看該作者
大佬這個(gè)有仿真嗎?想學(xué)習(xí)
