查看: 1836|回復: 2
stc12c2052串口通信接收PWM控制信號的程序問題,偶爾能用
ID:508562 發表于 2020-3-26 08:38 | 顯示全部樓層 |閱讀模式
利用12寫了個串口通信接收PWM控制信號的程序,可是通過串口調試,單片機能收到串口發送的數據但是不能將數據用作控制信號的變量,但是偶爾又可以控制,不知為什么下面是代碼:
#include <reg52.h>
#include "intrins.h"
/*************定義PCA特殊功能寄存器**************/
sfr        CCON = 0xd8;
sfr CMOD = 0xd9;
sfr CL = 0xe9;
sfr CH = 0xF9;
sfr CCAPM0 = 0xda;
sfr CCAP0L = 0xea;
sfr CCAP0H = 0xfa;
sfr CCAPM1 = 0xdb;
sfr CCAP1L = 0xeb;
sfr CCAP1H = 0xfb;
sfr CCAPM2 = 0xdc;
sfr CCAP2L = 0xec;
sfr CCAP2H = 0xfc;
sfr CCAPM3 = 0xdd;
sfr CCAP3L = 0xed;
sfr CCAP3H = 0xfd;
sfr PCAPWM0 = 0xf2;
sfr PCAPWM1 = 0xf3;
sfr PCAPWM2 = 0xf4;
sfr PCAPWM3 = 0xf5;
sfr        P3M1=0xb1;
sfr        P3M0=0xb2;
sfr        P1M1=0x91;
sfr        P1M0=0x92;
sbit CCF0 = CCON^0;
sbit CCF1 = CCON^1;
sbit CR = CCON^6;
sbit CF = CCON^7;
sbit LED1 = P1^7;
sbit LED2 = P1^6;
sbit LED3 = P1^5;
sbit rs485dir = P1^0;
uchar a, b, c, d;
//uchar addr = 0x01;
uchar ld;
uchar pl;
uchar status1;
uchar status2;
uchar omode = 0x01;
bit flag = 1;
uint fre[]={12000,6000,4000,3000,2400,2000,1714,1500,1200,1000};
uchar bri[]={0x19,0x32,0x4b,0x64,0x7d,0x96,0xaf,0xc8,0xe1,0xfa};
void delay(uint i);
void delayus(uchar a);
void Serial_communication();
void SerialInit();
        P3M0 = 0;                                                          //******************//
        P3M1 = 1;                                                          //*設定IO口工作模式*//
        P1M0 = 0;
        P1M1 = 0;
        ld = 0;
        pl = 9;
        status1 = 0x00;
        status2 = 0x03;
        SerialInit();
                delay(1000);
                LED1 = 1;
                LED2 = 1;
                LED3 = 1;
                CCON = 0;                                                          //關閉PCA寄存器CF中斷//
                CL = 0;        //初始化PCA16位寄存器值//
                CH = 0;        //***PWM功能使能****//
                CMOD = 0x00;                                                 //*確定時鐘頻率模式*//
                CCAPM1 = 0x42;                                                //****PWM輸出使能****//
                if(a==0x01)
                        switch(b)
                                case 0x02:
                                        switch(c)
                                                case 0:        ld = 0;        break;
                                                case 1:        ld = 1;        break;
                                                case 2:        ld = 2;        break;
                                                case 3:        ld = 3;        break;
                                                case 4: ld = 4;        break;
                                                case 5:        ld = 5;        break;
                                                case 6:        ld = 6;        break;
                                                case 7:        ld = 7; break;
                                                case 8:        ld = 8;        break;
                                                case 9: ld = 9;        break;
                                                default:        break;
                                case 0x03:
                                        switch(c)
                                                default:        break;
                                case 0x04:
                                        switch(c)
                                                case 0:        status1 = 0;        break;
                                                case 1:        status1 = 0x03;        break;
                                                default:        break;
                                default:        break;
                CCAP1L = bri[ld];                                        //****調節占空比*****//
                CCAP1H = bri[ld];                                         //****無縫傳輸下一個占空比值給CCAPL*****//
                CR = 1;        //***啟動PCA計數器***//
                   flag = 1;
                while(flag)
        //                if(flag==1)
        //                        delay(fre[pl]);
                        PCAPWM1 = status1;                                        //EPC0H與EPC0L為低PWM輸出高//
                        delay(fre[pl]);
                        PCAPWM1 = status2;                                        //EPC0H與EPC0L為高PWM輸出低//
                        delay(fre[pl]);
void delay(uint i)
        uint a,c;
        for(a=399;a>0;a--)
                        for(c=0;c<i;c++);
    uchar i,j;
    for(i=0;i<120;i++)
            for(j=0;j<a;j++);
void SerialInit()
        SCON = 0xf0;
        PCON = 0x00;
        TMOD = 0x20;
        TH1 = 0xf9;
        TH1 = 0xf9;
        TR1 = 1;
        ES = 1;
        EA = 1;
                rs485dir = 0;
void Serial_communication()        interrupt 4
        while(!RI);
        RI = 0;
        a = SBUF;
        flag = 0;
        if(RB8==1)
                switch(a)
                        case 0x01:
                                SM2 = 0;
                                rs485dir = 1;
                                delayus(50);
                                TI = 0;
                                TB8 = 1;
                                SBUF = a;
                                while(!TI);
                                TI = 0;
                                LED1 = 0;
                                LED2 = 1;
                                LED3 = 1;
                                rs485dir = 0;
                                RI = 0;
                                while(!RI);
                                RI = 0;
                                delayus(30);
                                b = SBUF;
                                rs485dir = 1;
                                delayus(50);
                                SBUF = b;
                                TI = 0;
                                TB8 = 1;
                                while(!TI);
                                TI = 0;
                                LED1 = 1;
                                LED2 = 0;
                                LED3 = 1;
                                rs485dir = 0;
                                while(!RI);
                                RI = 0;
                                delayus(30);
                                c = SBUF;
                                rs485dir = 1;
                                delayus(50);
                                SBUF = c;
                                TI = 0;
                                TB8 = 1;
                                while(!TI);
                                TI = 0;
                                rs485dir = 0;
                                LED1 = 1;
                                LED2 = 1;
                                LED3 = 0;
                                while(!RI);
                                RI = 0;
                                delayus(30);
                                d = SBUF;
                                rs485dir = 1;
                                delayus(50);
                                SBUF = d;
                                TI = 0;
                                TB8 = 1;
                                while(!TI);
                                TI = 0;
                                rs485dir = 0;
                                SM2 = 1;
                                break;
                        case 0xfe:
                                SM2 = 0;
                                rs485dir = 1;
                                LED1 = 0;
                                LED2 = 1;
                                LED3 = 1;
                                delayus(50);
                                TI = 0;
                                TB8 = 1;
                                SBUF = a;
                                while(!TI);
                                TI = 0;
                                LED1 = 1;
                                LED2 = 0;
                                LED3 = 1;
                                rs485dir = 0;
                                RI = 0;
                                while(!RI);
                                RI = 0;
                                b = SBUF;
                                LED1 = 1;
                                LED2 = 1;
                                LED3 = 0;
                                while(!RI);
                                RI = 0;
                                c = SBUF;
                                SM2 = 1;
                                break;
                        default:        SM2 = 1;        break;
        if(RB8==0)
                SM2 = 1;
ID:508562 發表于 2020-3-26 08:43 | 顯示全部樓層
串口調試 12返回的數據也沒問題
ID:508562 發表于 2020-3-26 15:28 | 顯示全部樓層
問題已解決是 波特率太高 導致通信可靠性下降
