#include <stc15f2k60s2.h>
#include <I2C.h>
sbit S7 = P3^0;
sbit S6 = P3^1;
unsigned char code LedChar[] = {
0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,
0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E,0xBF,0x7F
unsigned char LedBuff[8] = {
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF
unsigned char dat_rd1;
unsigned char money;
unsigned int shui_L = 0; //出水量
unsigned int flag_ns = 0;
bit shui = 0; // 0停止出水 1打開出水
void InitSystem();
void Timer0Init(void); //1毫秒@12.000MHz
void ConfigSMG();
void ConfigWorking();
void ScanKeys();
void ScanSMG();
extern unsigned char ReadRd1();
InitSystem();
Timer0Init();
ConfigWorking();
ConfigSMG();
ScanKeys();
ScanSMG();
/******HC573選擇函數*******/
void SeceltHC573(unsigned char channel)
switch(channel)
case 4:P2 = (P2&0x1F)|0x80;break;
case 5:P2 = (P2&0x1F)|0xA0;break;
case 6:P2 = (P2&0x1F)|0xC0;break;
case 7:P2 = (P2&0x1F)|0xE0;break;
case 0:P2 = (P2&0x1F)|0x00;break;
/*******關閉LED和蜂鳴器、繼電器******/
void InitSystem()
SeceltHC573(5);
P0 = 0x00;
SeceltHC573(4);
P0 = 0xFF;
SeceltHC573(0);
/******工作模式配置******/
dat_rd1 = ReadRd1(); //采集光敏電阻電壓
SeceltHC573(4);
if(dat_rd1>125) //判斷LED1亮滅
P0 = 0xFE;
P0 = 0xFF;
SeceltHC573(0);
shui_L = flag_ns;
money = shui_L*0.5;
if(shui_L>=999)
shui = 0;
flag_ns = 0;
if(shui)
EA = 0;
SeceltHC573(5); //打開繼電器
P0 = 0x10;
SeceltHC573(0);
EA = 1;
EA = 0;
SeceltHC573(5); //關閉繼電器
P0 = 0x00;
SeceltHC573(0);
EA = 1;
/******數碼管動態顯示*******/
void ConfigSMG()
if(shui)
LedBuff[0] = 0xFF;
LedBuff[1] = (LedChar[0]&LedChar[17]);
LedBuff[2] = LedChar[5];
LedBuff[3] = LedChar[0];
LedBuff[4] = LedChar[shui_L/100];
LedBuff[5] = (LedChar[shui_L/10%10]&LedChar[17]);
LedBuff[6] = LedChar[shui_L%10];
LedBuff[7] = LedChar[0];
LedBuff[0] = 0xFF;
LedBuff[4] = LedChar[money/100];
LedBuff[5] = (LedChar[money/10%10]&LedChar[17]);
LedBuff[6] = LedChar[money%10];
/******按鍵相關函數******/
void Delay1ms() //@12.000MHz
unsigned char i, j;
i = 12;
j = 169;
do
while (--j);
} while (--i);
void ScanKeys()
if(S7==0)
Delay1ms();
if(S7==0)
flag_ns = 0;
shui = 1;
while(S7==0)
ScanSMG();
if(S6==0)
Delay1ms();
if(S6==0)
shui = 0;
while(S6==0)
ScanSMG();
/******數碼管動態刷新*****/
void ScanSMG()
static unsigned char i = 0;
// P0 = 0xFF;
SeceltHC573(6);
P0 = 0x01<<i;
SeceltHC573(7);
P0 = LedBuff[i++];
if(i>=8)
i = 0;
SeceltHC573(0);
P0 = 0xFF;
Delay1ms();
/******配置定時器0******/
void Timer0Init(void) //1毫秒@12.000MHz
AUXR &= 0x7F; //定時器時鐘12T模式
TMOD &= 0xF0; //設置定時器模式
TL0 = 0x18; //設置定時初值
TH0 = 0xFC; //設置定時初值
TF0 = 0; //清除TF0標志
TR0 = 1; //定時器0開始計時
ET0 = 1;
EA = 1;
void InterruptTimer0() interrupt 1
static unsigned int cnt = 0;
if(shui)
cnt++;
if(cnt>=1000)
cnt = 0;
flag_ns++;
cnt = 0;
省賽試題-第4屆-自動售水機.pdf
2020-3-24 18:58 上傳
下載積分: 黑幣 -5
546.02 KB, 下載次數: 14, 下載積分: 黑幣 -5
第4屆自動售水機_1.rar
2020-3-24 18:57 上傳
下載積分: 黑幣 -5
43.1 KB, 下載次數: 20, 下載積分: 黑幣 -5
