#include <stc15f2k60s2.h>
sbit S7 = P3^0;
sbit S6 = P3^1;
sbit S5 = P3^2;
sbit S4 = P3^3;
unsigned char code LedChar[] = {
0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,
0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E,0xBF,0x7F
unsigned char LedBuff[8] = {
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF
unsigned char InitTime[7] = {
0x50,0x59,0x23,0x07,0x03,0x06,0x20
unsigned char clock[7] = {
0x00,0x00,0x00,0x07,0x03,0x06,0x20
unsigned char set_time[7] = {0,0,0,0,0,0,0};
unsigned int temp;
unsigned char time[7];
unsigned char mode_time = 0; //設置時間標志位
unsigned char mode_clock = 0; //設置鬧鐘標志位
unsigned char mode_SMG = 1; // 1 顯示時間 2 設置時間 3 設置鬧鐘 4 顯示溫度
bit mode_T = 0; //溫度顯示標志位
bit flag5s = 0;
bit share_Led = 0;
void InitSystem();
void Timer0Init(void); //1毫秒@12.000MHz
void SMGWroking();
void ScanKeyS();
void InitDS1302();
void SetClock();
extern unsigned char Get18B20Temp();
extern bit Start18B20();
extern void DS1302SingWrite(unsigned char addr,unsigned char dat);
extern unsigned char DS1302ByteRead(unsigned char addr);
InitSystem();
Timer0Init();
InitDS1302();
SMGWroking();
ScanKeyS();
SetClock();
/******HC573選擇函數*******/
void Select74HC573(unsigned char channel)
switch(channel)
case 4:P2 = (P2&0x1F)|0x80;break;
case 5:P2 = (P2&0x1F)|0xA0;break;
case 6:P2 = (P2&0x1F)|0xC0;break;
case 7:P2 = (P2&0x1F)|0xE0;break;
default:P2 = (P2&0x1F)|0x00;break;
/*******關閉LED和蜂鳴器、繼電器******/
void InitSystem()
Select74HC573(5);
P0 = 0x00;
Select74HC573(4);
P0 = 0xFF;
Select74HC573(0);
/*********DS1302********/
void DS1302SingRead()
unsigned char i,addr = 0x81;
DS1302SingWrite(0x8E,0x00);
for(i=0;i<7;i++)
time[i] = DS1302ByteRead(addr);
addr = addr + 2;
DS1302SingWrite(0x8E,0x80);
void InitDS1302() //初始化時鐘芯片
unsigned char i,addr = 0x80;
for(i=0;i<7;i++)
DS1302SingWrite(addr,InitTime[i]);
addr = addr + 2;
/*******DS18B20*********/
void Config18B20()
Start18B20();
temp = Get18B20Temp();
/********數碼管********/
void SMGWroking()
switch(mode_SMG)
case 1:DS1302SingRead(); //顯示時間
LedBuff[0] = LedChar[time[2]>>4];
LedBuff[1] = LedChar[time[2]&0x0F];
LedBuff[2] = LedChar[16];
LedBuff[3] = LedChar[time[1]>>4];
LedBuff[4] = LedChar[time[1]&0x0F];
LedBuff[5] = LedChar[16];
LedBuff[6] = LedChar[time[0]>>4];
LedBuff[7] = LedChar[time[0]&0x0F];
break;
case 2:LedBuff[0] = LedChar[set_time[2]/10]; //設置時間
LedBuff[1] = LedChar[set_time[2]%10];
LedBuff[3] = LedChar[set_time[1]/10];
LedBuff[4] = LedChar[set_time[1]%10];
LedBuff[6] = LedChar[set_time[0]/10];
LedBuff[7] = LedChar[set_time[0]%10];
break;
case 3:LedBuff[0] = LedChar[clock[2]/10];
LedBuff[1] = LedChar[clock[2]%10];
LedBuff[3] = LedChar[clock[1]/10];
LedBuff[4] = LedChar[clock[1]%10];
LedBuff[6] = LedChar[clock[0]/10];
LedBuff[7] = LedChar[clock[0]%10];
break;
case 4:Config18B20(); //顯示溫度
LedBuff[0] = 0xFF;
LedBuff[1] = 0xFF;
LedBuff[2] = 0xFF;
LedBuff[3] = 0xFF;
LedBuff[4] = 0xFF;
LedBuff[5] = LedChar[temp/10];
LedBuff[6] = LedChar[temp%10];
LedBuff[7] = LedChar[12];
break;
/*****十進制轉BCD碼*****/
unsigned char NumToBCD(unsigned char num)
unsigned char low,high,bcd;
low = (num%10)&0x0F;
high = ((num/10)<<4)&0xF0;
bcd = low|high;
return bcd;
/*****傳遞設置時間數值*******/
void Setnum_time()
unsigned char i;
for(i=0;i<3;i++)
InitTime[i] = NumToBCD(set_time[i]);
/*******鬧鐘提示功能******/
void SetClock()
if((clock[0]==time[0])&&(clock[1]==time[1])&&(clock[2]==time[2]))
flag5s = 1;
if(flag5s)
if(share_Led)
Select74HC573(4);
P0 = 0xFE;
Select74HC573(0);
P0 = 0xFF;
Select74HC573(4);
P0 = 0xFF;
Select74HC573(0);
P0 = 0xFF;
Select74HC573(4);
P0 = 0xFF;
Select74HC573(0);
/******設置鬧鐘*******/
void SetClock_jia()
if(mode_clock==1)
clock[0]++;
if(clock[0]>=59)
clock[0] = 59;
else if(mode_clock==2)
clock[1]++;
if(clock[1]>=59)
clock[1] = 59;
else if(mode_clock==3)
clock[2]++;
if(clock[2]>=23)
clock[2] = 23;
void SetClock_jian()
if(mode_clock==1)
if(clock[0]>0)
clock[0]--;
clock[0] = 0;
if(clock[1]>0)
clock[1]--;
clock[1] = 0;
if(clock[2]>0)
clock[2]--;
clock[2] = 0;
/******設置時間*******/
void SetTime_jia()
if(mode_time==1)
set_time[0]++;
if(set_time[0]>=59)
set_time[0] = 59;
else if(mode_time==2)
set_time[1]++;
if(set_time[1]>=59)
set_time[1] = 59;
else if(mode_time==3)
set_time[2]++;
if(set_time[2]>=23)
set_time[2] = 23;
void SetTime_jian()
if(mode_time==1)
if(set_time[0]>0)
set_time[0]--;
set_time[0] = 0;
if(set_time[1]>0)
set_time[1]--;
set_time[1] = 0;
if(set_time[2]>0)
set_time[2]--;
set_time[2] = 0;
/*******按鍵處理******/
void Delay1ms() //@12.000MHz
unsigned char i, j;
i = 12;
j = 169;
do
while (--j);
} while (--i);
void ScanKeyS()
if(S7==0) //時鐘設置
Delay1ms();
if(S7==0)
flag5s = 0;
if((mode_clock==0)&&(mode_T==0))
switch(mode_time)
case 0:mode_time = 1;mode_SMG = 2;
DS1302SingWrite(0x8E,0x00);break;
case 1:mode_time = 2;mode_SMG = 2;break;
case 2:mode_time = 3;mode_SMG = 2;break;
case 3:mode_time = 0;mode_SMG = 1;
Setnum_time();
InitDS1302();break;
while(S7==0)
SMGWroking();
if(S6==0) //鬧鐘設置
Delay1ms();
if(S6==0)
flag5s = 0;
if((mode_time==0)&&(mode_T==0))
switch(mode_clock)
case 0:mode_clock = 1;mode_SMG = 3;break;
case 1:mode_clock = 2;mode_SMG = 3;break;
case 2:mode_clock = 3;mode_SMG = 3;break;
case 3:mode_clock = 0;mode_SMG = 1;break;
while(S6==0)
SMGWroking();
if(S5==0) //“加”按鍵,在“時鐘設置”或“鬧鐘設置”狀態下,
{ //每次按下該按鍵當前選擇的單元(時、分或秒)增加 1 個單位。
Delay1ms();
if(S5==0)
flag5s = 0;
SetTime_jia();
SetClock_jia();
while(S5==0)
SMGWroking();
if(S4==0) //“減”按鍵,在“時鐘設置”或“鬧鐘設置”狀態下,
{ //每次按下該按鍵當前選擇的單元(時、分或秒)減少 1 個單位。
Delay1ms();
if(S4==0)
flag5s = 0;
SetTime_jian();
SetClock_jian();
if((mode_time==0)&&(mode_clock==0)) //在 “時鐘顯示”狀態下,按下 S4 按鍵,
{ //顯示溫度數據,松開按鍵,返回“時鐘顯示”界面。
mode_T = ~mode_T;
if(mode_T)
mode_SMG = 4; //顯示溫度
mode_SMG = 1; //顯示時間
while(S4==0)
SMGWroking();
/******數碼管刷新*****/
void ScanSMG()
static unsigned char i = 0;
P0 = 0xFF;
Select74HC573(6);
P0 = 0x01<<i;
Select74HC573(7);
P0 = LedBuff[i++];
if(i>=8)
i = 0;
Select74HC573(0);
void Timer0Init(void) //1毫秒@12.000MHz
AUXR &= 0x7F; //定時器時鐘12T模式
TMOD &= 0xF0; //設置定時器模式
TL0 = 0x18; //設置定時初值
TH0 = 0xFC; //設置定時初值
TF0 = 0; //清除TF0標志
TR0 = 1; //定時器0開始計時
ET0 = 1;
EA = 1;
void IterruptTime0() interrupt 1
static unsigned int cnt = 0;
static unsigned char share = 0;
ScanSMG();
if(flag5s)
share++;
if(share>=200)
share_Led = ~share_Led;
cnt++;
share = 0;
if(cnt>=25)
flag5s = 0;
第8屆電子鐘_1.rar
2020-3-24 18:21 上傳
下載積分: 黑幣 -5
54.68 KB, 下載次數: 12, 下載積分: 黑幣 -5
省賽試題-第8屆-基于單片機的電子鐘.pdf
2020-3-24 18:21 上傳
下載積分: 黑幣 -5
150.36 KB, 下載次數: 11, 下載積分: 黑幣 -5
