#include <stc15f2k60s2.h>
sbit R1 = P3^0;
sbit R2 = P3^1;
sbit R3 = P3^2;
sbit R4 = P3^3;
sbit C1 = P4^4;
sbit C2 = P4^2;
sbit C3 = P3^5;
sbit C4 = P3^4;
unsigned char code LedChar[] = {
0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,
0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E,0xBF,0x7F
unsigned char LedBuff[8] = {
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF
unsigned int num = 3525; //接收按鍵數字
unsigned char max = 0,min = 0;
unsigned char temp; //18B20溫度接收位
unsigned char mode_temp = 0;
unsigned int delay_Led = 0; //Led閃爍時間間隔
bit mode_set = 0; // 0 顯示溫度 1 設置溫度
bit flag_Led = 0; // Led閃爍標志位
void Timer0Init(void); //1毫秒@12.000MHz
void InitSystem();
void ConfigSMG();
void ScanKeys();
void Led_light();
void Setmode_Temp();
extern bit Start18B20(); //18B20初始化
extern unsigned char Get18B20Temp(); //獲取溫度
InitSystem();
Timer0Init();
Start18B20();
Setmode_Temp();
ConfigSMG();
ScanKeys();
/******HC573選擇函數*******/
void Select74HC573(unsigned char channel)
switch(channel)
case 4:P2 = (P2&0x1F)|0x80;break;
case 5:P2 = (P2&0x1F)|0xA0;break;
case 6:P2 = (P2&0x1F)|0xC0;break;
case 7:P2 = (P2&0x1F)|0xE0;break;
default:P2 = (P2&0x1F)|0x00;break;
/*******關閉LED和蜂鳴器、繼電器******/
void InitSystem()
Select74HC573(5);
P0 = 0x00;
Select74HC573(4);
P0 = 0xFF;
Select74HC573(0);
/*******數碼管顯示******/
void ConfigSMG()
if(mode_set==0) //顯示溫度
temp = Get18B20Temp();
LedBuff[0] = LedChar[16];
LedBuff[1] = LedChar[mode_temp];
LedBuff[2] = LedChar[16];
LedBuff[3] = 0xFF;
LedBuff[4] = 0xFF;
LedBuff[5] = 0xFF;
LedBuff[6] = LedChar[temp/10];
LedBuff[7] = LedChar[temp%10];
else //設置溫度范圍
LedBuff[1] = LedChar[max/10];
LedBuff[2] = LedChar[max%10];
LedBuff[3] = 0xFF;
LedBuff[4] = 0xFF;
LedBuff[5] = LedChar[16];
LedBuff[6] = LedChar[min/10];
LedBuff[7] = LedChar[min%10];
/*******按鍵配置函數*******/
void Delay1ms() //@12.000MHz
unsigned char i, j;
i = 12;
j = 169;
do
while (--j);
} while (--i);
void ScanKeys()
R1 = 0;
R2 = R3 = R4 = 1;
C1 = C2 = C3 = C4 = 1;
if(C1==0) //按鍵0
Delay1ms();
if(C1==0)
if(mode_set)
num = num *10 + 0;
if(num>9999)
num = 0;
while(C1==0)
ConfigSMG();
else if(C2==0) //按鍵1
Delay1ms();
if(C2==0)
if(mode_set)
num = num *10 + 1;
if(num>9999)
num = 1;
while(C2==0)
ConfigSMG();
else if(C3==0) //按鍵2
Delay1ms();
if(C3==0)
if(mode_set)
num = num *10 + 2;
if(num>9999)
num = 2;
while(C3==0)
ConfigSMG();
R2 = 0;
R1 = R3 = R4 = 1;
if(C1==0) //按鍵3
Delay1ms();
if(C1==0)
if(mode_set)
num = num *10 + 3;
if(num>9999)
num = 3;
while(C1==0)
ConfigSMG();
else if(C2==0) //按鍵4
Delay1ms();
if(C2==0)
if(mode_set)
num = num *10 + 4;
if(num>9999)
num = 4;
while(C2==0)
ConfigSMG();
else if(C3==0) //按鍵5
Delay1ms();
if(C3==0)
if(mode_set)
num = num *10 + 5;
if(num>9999)
num = 5;
while(C3==0)
ConfigSMG();
R3 = 0;
R1 = R2 = R4 = 1;
if(C1==0) //按鍵6
Delay1ms();
if(C1==0)
if(mode_set)
num = num *10 + 6;
if(num>9999)
num = 6;
while(C1==0)
ConfigSMG();
else if(C2==0) //按鍵7
Delay1ms();
if(C2==0)
if(mode_set)
num = num *10 + 7;
if(num>9999)
num = 7;
while(C2==0)
ConfigSMG();
else if(C3==0) //按鍵8
Delay1ms();
if(C3==0)
if(mode_set)
num = num *10 + 8;
if(num>9999)
num = 8;
while(C3==0)
ConfigSMG();
R4 = 0;
R1 = R2 = R3 = 1;
if(C1==0) //按鍵9
Delay1ms();
if(C1==0)
if(mode_set)
num = num *10 + 9;
if(num>9999)
num = 9;
while(C1==0)
ConfigSMG();
else if(C2==0) //設置按鍵
Delay1ms();
if(C2==0)
mode_set = ~mode_set;
while(C2==0)
ConfigSMG();
else if(C3==0) //清除按鍵
Delay1ms();
if(C3==0)
if(mode_set)
num = 0;
while(C3==0)
ConfigSMG();
/******LED閃爍設置*******/
void Led_light()
Select74HC573(4);
if(mode_temp==0)
delay_Led = 800;
if(flag_Led)
flag_Led = 0;
P0 = 0xFE; //打開LED1
P0 = 0xFF; //關閉LED1
else if(mode_temp==1)
delay_Led = 400;
if(flag_Led)
flag_Led = 0;
P0 = 0xFE; //打開LED1
P0 = 0xFF; //關閉LED1
else if(mode_temp==2)
delay_Led = 200;
if(flag_Led)
flag_Led = 0;
P0 = 0xFE; //打開LED1
P0 = 0xFF; //關閉LED1
Select74HC573(0);
/******溫度區間設置******/
void Setmode_Temp()
max = num/100;
min = num%100;
if(max>min)
if(temp<min)
mode_temp = 0;
EA = 0;
Select74HC573(5);
P0 = 0x00; //關閉繼電器
Select74HC573(0);
EA = 1;
else if(temp>max)
mode_temp = 2;
EA = 0;
Select74HC573(5);
P0 = 0x10; //打開繼電器
Select74HC573(0);
EA = 1;
mode_temp = 1;
EA = 0;
Select74HC573(5);
P0 = 0x00; //關閉繼電器
Select74HC573(0);
EA = 1;
Led_light();
else //設置溫度錯誤
Select74HC573(4);
P0 = 0xFD; //LED2常亮
Select74HC573(0);
P0 = 0xFF;
/*******數碼管動態刷新*******/
void ScanSMG()
static unsigned char i = 0;
P0 = 0xFF;
Select74HC573(6);
P0 = 0x01<<i;
Select74HC573(7);
P0 = LedBuff[i++];
if(i>=8)
i = 0;
Select74HC573(0);
/*******定時器0配置******/
void Timer0Init(void) //1毫秒@12.000MHz
AUXR &= 0x7F; //定時器時鐘12T模式
TMOD &= 0xF0; //設置定時器模式
TL0 = 0x18; //設置定時初值
TH0 = 0xFC; //設置定時初值
TF0 = 0; //清除TF0標志
TR0 = 1; //定時器0開始計時
ET0 = 1;
EA = 1;
void InterruptTimer0() interrupt 1
static unsigned int cnt = 0;
ScanSMG();
cnt++;
if(cnt>=delay_Led)
flag_Led = 1;
cnt = 0;
