查看: 2169|回復(fù): 2
如何修改tft1.44寸屏幕的單片機程序?顯示9張圖片能否改成只顯示1張圖片
回帖獎勵 300 黑幣 回復(fù)本帖可獲得 100 黑幣獎勵! 每人限 1 次(中獎概率 40%)
ID:696556 發(fā)表于 2020-3-16 22:25 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
這個程序在顯示屏上是顯示9張圖片能否改成只顯示1張圖片的謝謝小白一個、
#include<reg51.h>
#include<absacc.h>
#include<intrins.h>
#include<string.h>
sbit bl        =P3^2;
sbit scl       =P1^7;
sbit sda       =P1^5;
sbit rs        =P1^2;
sbit cs        =P1^3;
sbit reset     =P3^3;
#define RED                  0xf800
#define GREEN                0x07e0
#define BLUE                 0x001f
#define WHITE                0xffff
#define BLACK                0x0000
#define YELLOW  0xFFE0
#define GRAY0   0xEF7D
#define GRAY1   0x8410
#define GRAY2   0x4208
code unsigned char gImage_qq[];
void delay_ms(uint time)
uint i,j;
  for(i=0;i<time;i++)
   for(j=0;j<250;j++);
void  SPI_WriteData(uchar Data)
        unsigned char i=0;
        for(i=8;i>0;i--)
                if(Data&0x80)
                sda=1;
                else sda=0;
                scl=0;
                scl=1;
                Data<<=1;
顯示9張圖片能否改成只顯示1張圖片
void  Lcd_WriteIndex(uchar Data)
                cs=0;
                rs=0;
                SPI_WriteData(Data);
                cs=1;
void  Lcd_WriteData(uchar Data)
                unsigned char i=0;
                cs=0;
                rs=1;
                cs=1;
void  LCD_WriteData_16Bit(unsigned int Data)
        unsigned char i=0;
        cs=0;
        rs=1;
        SPI_WriteData(Data>>8);
        cs=1;
void Reset()
    reset=0;
    delay_ms(100);
    reset=1;
    delay_ms(100);
void lcd_initial()
{        Reset();//Reset before LCD Init.
        //LCD Init For 1.44Inch LCD Panel with ST7735R.
        Lcd_WriteIndex(0x11);//Sleep exit
        delay_ms (120);
        //ST7735R Frame Rate
        Lcd_WriteIndex(0xB1);
        Lcd_WriteData(0x01);
        Lcd_WriteData(0x2C);
        Lcd_WriteData(0x2D);
        Lcd_WriteIndex(0xB2);
        Lcd_WriteIndex(0xB3);
        Lcd_WriteIndex(0xB4); //Column inversion
        Lcd_WriteData(0x07);
        //ST7735R Power Sequence
        Lcd_WriteIndex(0xC0);
        Lcd_WriteData(0xA2);
        Lcd_WriteData(0x02);
        Lcd_WriteData(0x84);
        Lcd_WriteIndex(0xC1);
        Lcd_WriteData(0xC5);
        Lcd_WriteIndex(0xC2);
        Lcd_WriteData(0x0A);
        Lcd_WriteData(0x00);
        Lcd_WriteIndex(0xC3);
        Lcd_WriteData(0x8A);
        Lcd_WriteData(0x2A);
        Lcd_WriteIndex(0xC4);
        Lcd_WriteData(0xEE);
        Lcd_WriteIndex(0xC5); //VCOM
        Lcd_WriteData(0x0E);
        Lcd_WriteIndex(0x36); //MX, MY, RGB mode
#ifdef USE_LANDSCAPE
        Lcd_WriteData(0xA8);
#else
        Lcd_WriteData(0xC8);
#endif
        //ST7735R Gamma Sequence
        Lcd_WriteIndex(0xe0);
        Lcd_WriteData(0x0f);
        Lcd_WriteData(0x1a);
        Lcd_WriteData(0x18);
        Lcd_WriteData(0x2f);
        Lcd_WriteData(0x28);
        Lcd_WriteData(0x20);
        Lcd_WriteData(0x22);
        Lcd_WriteData(0x1f);
        Lcd_WriteData(0x1b);
        Lcd_WriteData(0x23);
        Lcd_WriteData(0x37);
        Lcd_WriteData(0x10);
        Lcd_WriteIndex(0xe1);
        Lcd_WriteData(0x17);
        Lcd_WriteData(0x33);
        Lcd_WriteData(0x2c);
        Lcd_WriteData(0x29);
        Lcd_WriteData(0x2e);
        Lcd_WriteData(0x30);
        Lcd_WriteData(0x39);
        Lcd_WriteData(0x3f);
        Lcd_WriteData(0x03);
        Lcd_WriteIndex(0x2a);
        Lcd_WriteData(0x00+2);
        Lcd_WriteData(0x80+2);
        Lcd_WriteIndex(0x2b);
        Lcd_WriteData(0x00+3);
        Lcd_WriteData(0x80+3);
        Lcd_WriteIndex(0xF0); //Enable test command
        Lcd_WriteIndex(0xF6); //Disable ram power save mode
        Lcd_WriteIndex(0x3A); //65k mode
        Lcd_WriteData(0x05);
        Lcd_WriteIndex(0x29);//Display on
void Lcd_SetRegion(unsigned int x_start,unsigned int y_start,unsigned int x_end,unsigned int y_end)
        Lcd_WriteData(x_start+3);
        Lcd_WriteData(x_end+3);
        Lcd_WriteData(y_start+2);
        Lcd_WriteData(y_end+2);
#else
        Lcd_WriteData(x_start+2);
        Lcd_WriteData(x_end+2);
        Lcd_WriteData(y_start+3);
        Lcd_WriteData(y_end+3);
#endif
        Lcd_WriteIndex(0x2c);
void dsp_single_colour(int color)
         uchar i,j;
        Lcd_SetRegion(0,0,128-1,128-1);
         for (i=0;i<128;i++)
            for (j=0;j<128;j++)
                LCD_WriteData_16Bit(color);
void showimage(const unsigned char *p)
          int i,j,k;
        unsigned char picH,picL;
        dsp_single_colour(WHITE); //ÇåÆá
        for(k=0;k<3;k++)
                   for(j=0;j<3;j++)
                        Lcd_SetRegion(40*j,40*k,40*j+39,40*k+39);
                    for(i=0;i<40*40;i++)
                                 picL=*(p+i*2);
                                picH=*(p+i*2+1);
                                LCD_WriteData_16Bit(picH<<8|picL);
void main(void)
#ifdef MCU_STC12
        P3M1 &= ~(1<<2),        P3M0 |=  (1<<2);        //P3.2 set as push-pull output mode
#endif
        lcd_initial();
        bl=1;
        showimage(gImage_qq);
        delay_ms(1500);
code unsigned char gImage_qq[3200] = { /*0X00,0X10,0X28,0X00,0X28,0X00,0X01,0X1B,*/
0XDB,0XDE,0X5D,0XEF,0X5D,0XEF,0X7D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,
0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0XBE,0XF7,
0XFF,0XFF,0XDE,0XFF,0X38,0XC6,0X92,0X8C,0X8E,0X6B,0X6E,0X6B,0X10,0X7C,0X96,0XAD,
0X3C,0XE7,0XFF,0XFF,0XFF,0XFF,0X7D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,
0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,
0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X5D,0XEF,
0X15,0X9D,0X4F,0X63,0X6C,0X42,0X0A,0X32,0X88,0X29,0X46,0X19,0X25,0X19,0X45,0X21,
0XE8,0X31,0X8E,0X6B,0X18,0XBE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XF5,0X9C,0X0F,0X53,
0X10,0X4B,0X51,0X53,0X0F,0X4B,0X6C,0X3A,0XE9,0X31,0X67,0X21,0X25,0X19,0XE4,0X10,
0XA3,0X08,0X62,0X00,0X83,0X08,0X8A,0X4A,0X59,0XC6,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X1C,0XE7,0X4F,0X5B,0XB3,0X63,0XB8,0X7C,
0XF5,0X63,0X11,0X43,0X4D,0X32,0XEA,0X29,0X88,0X21,0X26,0X19,0X05,0X19,0X05,0X19,
0X04,0X11,0X04,0X11,0XE4,0X10,0X83,0X00,0XA3,0X08,0X72,0X8C,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDB,0XDE,0X4B,0X3A,0XF0,0X42,0X35,0X6C,0X54,0X4B,
0XB1,0X32,0X2E,0X2A,0XEB,0X21,0XA9,0X21,0X67,0X19,0X05,0X19,0X04,0X11,0X04,0X11,
0X04,0X11,0X04,0X11,0X04,0X11,0X05,0X19,0XE4,0X10,0X42,0X00,0XAF,0X73,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0X5D,0XEF,0X09,0X32,0X4C,0X32,0X10,0X4B,0X8F,0X32,0X4F,0X2A,
0X2E,0X2A,0XCC,0X19,0X89,0X19,0X89,0X21,0X47,0X19,0X05,0X19,0X04,0X11,0X04,0X11,
0XC4,0X10,0XC4,0X10,0X04,0X11,0X04,0X11,0X04,0X11,0XE4,0X10,0X42,0X00,0X31,0X84,
0XFF,0XFF,0XFF,0XFF,0XEC,0X52,0X47,0X19,0X4C,0X32,0X0B,0X2A,0XEC,0X21,0XEC,0X21,
0X0C,0X22,0X91,0X5B,0XEE,0X4A,0X06,0X11,0X26,0X19,0X04,0X19,0XE4,0X10,0XE4,0X10,
0XA7,0X29,0X66,0X21,0XA3,0X08,0X05,0X19,0X04,0X11,0X04,0X11,0XE4,0X10,0X82,0X00,
0XF7,0XBD,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0X35,0XA5,0X83,0X08,0X88,0X21,0X88,0X21,0X89,0X21,0XAA,0X21,0X8A,0X21,
0X6B,0X42,0X71,0X8C,0XFF,0XFF,0X72,0X8C,0X83,0X08,0X04,0X11,0XC4,0X08,0X29,0X42,
0XFB,0XDE,0X5D,0XEF,0XEC,0X5A,0X83,0X08,0X04,0X11,0X04,0X11,0X04,0X11,0X83,0X08,
0XE8,0X31,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XBE,0XF7,0XC7,0X31,0XC4,0X10,0X25,0X19,0X26,0X19,0X47,0X19,0X47,0X19,0XA8,0X29,
0X8A,0X52,0X28,0X4A,0X55,0XAD,0XFF,0XFF,0XE8,0X31,0XA3,0X08,0X05,0X19,0X4D,0X6B,
0X4D,0X6B,0XFF,0XFF,0X7D,0XEF,0X45,0X21,0XC4,0X10,0X04,0X11,0X04,0X11,0X04,0X11,
0X62,0X00,0X76,0XAD,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X96,0XB5,0X62,0X00,0X04,0X11,0X04,0X19,0X05,0X11,0X05,0X19,0XC4,0X08,0X8B,0X4A,
0XB6,0XB5,0X5D,0XEF,0XF7,0XBD,0XFF,0XFF,0X8E,0X6B,0X62,0X00,0X29,0X42,0XAA,0X5A,
0X08,0X42,0XFF,0XFF,0XFF,0XFF,0XCC,0X52,0X83,0X08,0X04,0X11,0X04,0X11,0X04,0X11,
0XA3,0X08,0XAD,0X52,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XBE,0XF7,0XFF,0XFF,0XDF,0XFF,0XDB,0XDE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X4E,0X63,0X62,0X00,0X04,0X11,0X04,0X11,0X04,0X11,0XE4,0X10,0X62,0X00,0X8E,0X63,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XCF,0X73,0X01,0X00,0XF3,0X9C,0X2C,0X63,
0X96,0XB5,0XFF,0XFF,0XFF,0XFF,0X2D,0X5B,0X83,0X00,0X04,0X11,0X04,0X11,0X04,0X11,
0XE4,0X10,0X67,0X21,0X3D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XB7,0XB5,0X76,0XAD,0X7D,0XEF,0XCB,0X52,0XB3,0X94,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,
0XE8,0X31,0XA3,0X08,0X04,0X11,0X04,0X11,0X04,0X11,0X04,0X11,0XA3,0X08,0X49,0X42,
0XFF,0XF7,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0X6A,0X4A,0X01,0X00,0X72,0X84,0XFF,0XFF,
0XFF,0XFF,0XFF,0XF7,0XDF,0XEF,0X09,0X3A,0XA3,0X08,0X04,0X11,0X04,0X11,0X04,0X11,
0X04,0X11,0X05,0X11,0X18,0XBE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XF0,0X7B,0X62,0X00,0XE8,0X31,0XC7,0X31,0X41,0X00,0X35,0XA5,0XFF,0XFF,0X5D,0XEF,
0X46,0X21,0XC4,0X10,0X04,0X11,0X04,0X11,0X04,0X11,0X04,0X11,0XE4,0X10,0XA3,0X08,
0X76,0X9D,0XFF,0XF7,0XFF,0XFF,0XB7,0XAD,0XA3,0X08,0XA3,0X08,0XC7,0X31,0X9E,0XE7,
0XFF,0XF7,0XFF,0XF7,0X76,0XA5,0XA3,0X08,0XE4,0X10,0X04,0X11,0X04,0X11,0X04,0X11,
0X05,0X11,0X05,0X11,0X35,0XA5,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XDB,0XDE,0XA7,0X29,0X83,0X00,0XC4,0X10,0XC4,0X10,0XC4,0X10,0X1C,0XE7,0X9E,0XEF,
0X05,0X11,0XE4,0X10,0X04,0X11,0X04,0X11,0X04,0X11,0X04,0X11,0X04,0X19,0XC4,0X08,
0XE5,0X10,0XD1,0X6B,0XD1,0X6B,0XC5,0X08,0X64,0X00,0XA5,0X08,0X43,0X00,0X2B,0X32,
0X77,0X9D,0XB3,0X84,0X25,0X19,0XC4,0X10,0X04,0X11,0X04,0X11,0X04,0X11,0X04,0X11,
0X25,0X19,0X26,0X09,0X35,0X9D,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XAF,0X73,0X62,0X00,0X04,0X19,0X05,0X19,0X82,0X00,0X0D,0X5B,0X8E,0X9B,
0X62,0X10,0X05,0X11,0X04,0X11,0X04,0X11,0X04,0X19,0XE4,0X10,0X85,0X00,0X05,0X11,
0XC4,0X39,0X81,0X5A,0X40,0X7B,0X22,0X9C,0X43,0XAC,0X03,0XA4,0X83,0X9B,0X82,0X72,
0X82,0X49,0XC2,0X18,0XA4,0X00,0XC5,0X00,0XE4,0X10,0X04,0X19,0X04,0X11,0X05,0X19,
0X47,0X19,0X67,0X11,0XEC,0X5A,0XBE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XDF,0XFF,0XDB,0XD6,0XC4,0X10,0XE4,0X10,0X04,0X11,0X05,0X11,0XA4,0X18,0X01,0XC0,
0X83,0X88,0XE4,0X00,0X05,0X19,0X04,0X19,0XC5,0X08,0X44,0X21,0X43,0X83,0X23,0XD5,
0X42,0XFE,0XE4,0XFE,0X27,0XFF,0X07,0XFF,0XA4,0XFE,0X64,0XFE,0X03,0XFE,0XA3,0XFD,
0XE2,0XFC,0X42,0XEC,0X83,0XB3,0X24,0X62,0XE5,0X10,0XC4,0X08,0X04,0X19,0X26,0X19,
0XA8,0X19,0X87,0X21,0X00,0X90,0XD3,0XBC,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X5D,0XEF,0XFF,0XFF,0XF0,0X7B,0X42,0X00,0X05,0X19,0X05,0X11,0X83,0X28,0X01,0XD0,
0X44,0XF8,0XA3,0X48,0XE4,0X00,0XC5,0X08,0X44,0X5A,0X02,0XED,0XE2,0XFD,0X02,0XFE,
0X66,0XFE,0X74,0XFF,0XB8,0XFF,0X73,0XFF,0XE7,0XF6,0XA6,0XF6,0X45,0XF6,0XA4,0XF5,
0XC3,0XFC,0X62,0XFC,0XC2,0XFC,0XC2,0XFC,0XE3,0XCB,0XC4,0X49,0X06,0X11,0X88,0X19,
0X87,0X01,0XA4,0X90,0X01,0XF8,0XEC,0X9A,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X5D,0XEF,0XFF,0XFF,0X9E,0XF7,0XE8,0X31,0X83,0X00,0X05,0X09,0X82,0X40,0X01,0XC0,
0X23,0XF8,0X85,0XF0,0XA3,0X48,0XA4,0X00,0X44,0X5A,0X02,0XFD,0X23,0XCC,0XC2,0XDC,
0X04,0XFE,0X28,0XFE,0X48,0XF6,0X46,0XF6,0X24,0XF6,0XE4,0XF5,0X64,0XFD,0XE3,0XFC,
0X62,0XFC,0XC2,0XFC,0X02,0XE4,0X02,0XDC,0XE2,0XFC,0XA4,0X7A,0X48,0X01,0X67,0X01,
0XC4,0X78,0X24,0XF8,0X02,0XF8,0X84,0XB0,0X7D,0XE7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XDB,0XDE,0X25,0X19,0XA3,0X00,0XC4,0X38,0X02,0XE0,
0X22,0XD8,0X44,0XF8,0XA6,0XF8,0XA4,0X78,0X63,0X00,0X43,0X21,0X83,0X72,0X83,0X39,
0X82,0X9B,0X21,0XF5,0X61,0XFD,0X22,0XFD,0XE2,0XFC,0XA2,0XFC,0X42,0XFC,0X42,0XFC,
0X42,0XFC,0X22,0XAB,0X83,0X41,0XC3,0X92,0X04,0X52,0X26,0X01,0X25,0X19,0XA4,0X98,
0X44,0XF8,0X23,0XF8,0X02,0XF8,0XA4,0XD0,0X9E,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X9A,0XD6,0X87,0X29,0XA5,0X00,0X43,0XB8,
0X22,0XF8,0X23,0XE0,0X65,0XF8,0XE8,0XF8,0X07,0XC9,0X83,0X48,0X42,0X00,0XA3,0X00,
0X84,0X00,0X63,0X29,0XA2,0X7A,0X62,0XB3,0XA2,0XCB,0X62,0XD3,0X02,0XBB,0X82,0X8A,
0X83,0X39,0XA4,0X00,0XE5,0X00,0XE5,0X00,0XE5,0X08,0XC4,0X60,0X64,0XD8,0X44,0XF8,
0X24,0XF8,0X23,0XF8,0X02,0XF8,0X83,0X88,0XDB,0XC6,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X3D,0XE7,0X50,0X5B,0X08,0X31,
0X23,0XE8,0X43,0XF8,0X44,0XF0,0X65,0XF8,0X09,0XF9,0XAB,0XF9,0X89,0XD1,0X06,0X89,
0XA3,0X48,0X42,0X18,0X02,0X00,0X42,0X00,0X61,0X00,0X82,0X00,0X62,0X00,0X62,0X00,
0X83,0X00,0XA3,0X20,0XC4,0X50,0XA5,0X88,0X85,0XD8,0X65,0XF8,0X44,0XF8,0X44,0XF8,
0X23,0XF8,0X23,0XF8,0X03,0XD0,0X82,0X10,0XC7,0X29,0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,
0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X6C,0X32,
0XA5,0X38,0X02,0XD8,0X23,0XF8,0X65,0XF8,0X66,0XF8,0XA7,0XF8,0X4A,0XF9,0X0C,0XFA,
0X4D,0XFA,0X4C,0XEA,0X0B,0XD2,0XA9,0XB9,0X68,0XB1,0X47,0XA9,0X27,0XB1,0X07,0XB9,
0X07,0XD1,0XE7,0XE8,0XC7,0XF8,0XA7,0XF8,0X65,0XF8,0X65,0XF8,0X44,0XF8,0X23,0XF8,
0X03,0XF8,0X02,0XD0,0XA3,0X28,0X05,0X09,0XC4,0X08,0XEC,0X5A,0XFF,0XFF,0XFF,0XFF,
0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFB,0XDE,0X05,0X19,
0XC4,0X00,0XA7,0X41,0XE6,0XC0,0X03,0XF8,0X86,0XF8,0XA7,0XF8,0X87,0XF8,0X86,0XF8,
0XC7,0XF8,0X29,0XF9,0X8A,0XF9,0XAB,0XF9,0XAB,0XF9,0X8B,0XF9,0X6A,0XF9,0X29,0XF9,
0X08,0XF9,0XC7,0XF8,0XA6,0XF8,0X86,0XF8,0X65,0XF8,0X64,0XF8,0X23,0XF8,0X02,0XF0,
0X06,0XB1,0X25,0X29,0XE4,0X00,0XE4,0X10,0X25,0X19,0X25,0X19,0X14,0X9D,0XFF,0XFF,
0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X96,0XAD,0X62,0X00,
0X82,0X08,0X35,0X95,0XBA,0XCE,0X8B,0XA2,0X44,0XD0,0X25,0XF8,0X87,0XF8,0XA7,0XF8,
0XC7,0XF8,0XA7,0XF8,0X87,0XF8,0X86,0XF8,0X86,0XF8,0X86,0XF8,0X87,0XF8,0XA7,0XF8,
0XA7,0XF8,0XA6,0XF8,0X85,0XF8,0X65,0XF8,0X64,0XF8,0X24,0XF0,0X64,0XB8,0X0D,0X93,
0XBB,0XB6,0XCF,0X63,0X83,0X08,0X04,0X11,0XE4,0X10,0X66,0X21,0X49,0X3A,0X5D,0XEF,
0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XD3,0X94,0X42,0X00,
0XE4,0X10,0XBB,0XCE,0XFF,0XFF,0XBE,0XE7,0X76,0XB5,0XCC,0XAA,0X07,0XC1,0X45,0XE0,
0X45,0XF8,0X46,0XF8,0X66,0XF8,0X86,0XF8,0X86,0XF8,0X86,0XF8,0X86,0XF8,0X65,0XF8,
0X45,0XF8,0X65,0XF8,0X65,0XE8,0X44,0XD0,0X43,0XA8,0X01,0X88,0X82,0X90,0X3C,0XD7,
0XFF,0XEF,0X55,0X95,0X83,0X08,0X04,0X11,0X04,0X11,0X05,0X19,0X46,0X19,0XB3,0X94,
0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XB3,0X94,0X41,0X00,
0X86,0X21,0X5D,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XE7,0X7A,0XC6,0XD3,0XB4,
0X4E,0XB3,0X2A,0XC2,0X68,0XD1,0XE6,0XE0,0XA6,0XE8,0XA5,0XE8,0XA5,0XE8,0XE6,0XD8,
0X88,0XC9,0X06,0XA9,0X22,0XA8,0X02,0XA8,0X00,0XA0,0X00,0XC8,0X00,0XD8,0XF7,0XE5,
0XFF,0XE7,0XF8,0XAD,0XC4,0X10,0XE4,0X10,0X04,0X11,0XE4,0X10,0X05,0X11,0X8B,0X4A,
0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X55,0XA5,0X41,0X00,
0XA7,0X29,0X5D,0XDF,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XEF,0X7D,0XDF,0XDB,0XCE,0X59,0XCE,0XF8,0XCD,0XD7,0XCD,0XF7,0XC5,0X79,0XCE,
0XFB,0XBE,0XAB,0XA2,0X03,0XF0,0X45,0XF8,0X42,0XD0,0X43,0XE8,0X00,0XF0,0X72,0XD4,
0XFF,0XDF,0X39,0XAE,0XE4,0X10,0XE4,0X10,0X04,0X11,0XE4,0X10,0X05,0X11,0X87,0X29,
0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X59,0XCE,0X83,0X08,
0X46,0X21,0X1C,0XD7,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XEF,0X8B,0XBA,0X04,0XF8,0X45,0XF8,0X62,0XE0,0X44,0XF0,0X00,0XF8,0X8E,0XDB,
0XFF,0XDF,0XF8,0XA5,0XC4,0X10,0XE4,0X10,0XE4,0X10,0X04,0X11,0XE4,0X10,0X25,0X19,
0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBE,0XF7,0X87,0X29,
0X83,0X08,0X39,0XB6,0XFF,0XF7,0XDF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XBE,0XE7,0X4A,0XBA,0X03,0XF8,0X45,0XF8,0X64,0XF8,0X44,0XF8,0X00,0XF8,0X6E,0XE3,
0XFF,0XD7,0XF4,0X8C,0X83,0X08,0X04,0X11,0XE4,0X10,0XE4,0X10,0XE4,0X10,0X05,0X19,
0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XEF,0X73,
0X00,0X00,0X72,0X84,0XFF,0XEF,0XBE,0XEF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XDF,0XE7,0X8B,0XBA,0X03,0XF8,0X45,0XF8,0X45,0XF8,0X23,0XF8,0X00,0XF8,0XD3,0XD4,
0XFF,0XD7,0X4E,0X5B,0X21,0X00,0X29,0X3A,0X55,0XA5,0X83,0X08,0XC4,0X10,0X25,0X19,
0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFB,0XDE,
0XA3,0X08,0XE8,0X31,0X9E,0XDF,0X9E,0XE7,0XBF,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XF7,0X51,0XBC,0X02,0XE0,0X03,0XF8,0X03,0XF0,0X43,0XE0,0XEC,0XC2,0X7E,0XCF,
0XFC,0XBE,0X46,0X21,0X21,0X00,0XD3,0X94,0XFF,0XFF,0X51,0X84,0X00,0X00,0X87,0X29,
0X51,0X84,0X00,0X00,0XF4,0X8C,0XFF,0XEF,0X9E,0XE7,0XBF,0XEF,0XDF,0XFF,0XFF,0XFF,
0XFF,0XFF,0X3D,0XDF,0X55,0XBD,0X52,0XBC,0X72,0XBC,0XB7,0XB5,0X5D,0XC7,0XFF,0XDF,
0XF0,0X6B,0X00,0X00,0X09,0X3A,0XBF,0XF7,0XFF,0XFF,0XFF,0XFF,0X14,0X9D,0X55,0XA5,
0XFF,0XFF,0XAC,0X4A,0XA4,0X08,0XBB,0XBE,0XDF,0XE7,0X7E,0XE7,0XBE,0XEF,0XDF,0XF7,
0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XDF,0XFF,0XDF,0XF7,0XFF,0XEF,0XDF,0XDF,0XBF,0XD7,0X9E,0XD7,0XDF,0XDF,0XD8,0XA5,
0X83,0X08,0X26,0X11,0XDB,0XD6,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X79,0XEE,0X8B,0XDC,0X21,0X31,0XA9,0X21,0X3D,0XCF,0XBF,0XDF,0X7E,0XDF,0X9E,0XE7,
0XBE,0XEF,0XBF,0XEF,0XDF,0XF7,0XDF,0XF7,0XDF,0XF7,0XDF,0XF7,0XDF,0XF7,0XBF,0XEF,
0XBE,0XEF,0X9E,0XE7,0X7E,0XDF,0X5E,0XD7,0X5E,0XD7,0XDF,0XDF,0X9A,0XB6,0X26,0X19,
0X42,0X08,0XED,0XA3,0XBF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X74,0XDD,
0XC0,0XDB,0X00,0XFE,0X42,0XEE,0X02,0X42,0X89,0X21,0X7B,0XB6,0XDF,0XDF,0X7E,0XD7,
0X7E,0XDF,0X7E,0XDF,0X9E,0XE7,0X9E,0XE7,0X9E,0XE7,0X9E,0XE7,0X9E,0XE7,0X7E,0XDF,
0X7E,0XDF,0X5D,0XD7,0X5D,0XD7,0X9E,0XDF,0XFF,0XE7,0XF8,0XA5,0X07,0X11,0XE3,0X18,
0X02,0XC5,0X60,0XFD,0XE6,0XD3,0XDB,0XEE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X9E,0XF7,0X84,0XBA,
0XC1,0XFC,0X42,0XFE,0X82,0XFE,0XA2,0XFE,0X81,0X83,0X45,0X21,0X74,0X74,0X5E,0XC7,
0XDF,0XDF,0X7E,0XD7,0X5E,0XD7,0X5D,0XD7,0X5E,0XD7,0X5E,0XD7,0X5D,0XD7,0X5D,0XD7,
0X5E,0XD7,0X9E,0XDF,0XFF,0XE7,0X3D,0XC7,0XF1,0X63,0X84,0X08,0X42,0X52,0X26,0XE6,
0X29,0XFF,0X86,0XFE,0XE0,0XF3,0X6A,0XC3,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X18,0XDE,0XC1,0XD2,
0XA2,0XFD,0X22,0XFE,0X42,0XFE,0X42,0XFE,0X62,0XFE,0XE2,0XD4,0X41,0X6A,0X49,0X42,
0X53,0X74,0X3B,0XA6,0X3E,0XC7,0XBF,0XD7,0XBF,0XD7,0XBF,0XD7,0XBF,0XDF,0XBF,0XD7,
0X3E,0XC7,0X1A,0XA6,0XF2,0X63,0XA7,0X29,0X82,0X41,0X22,0XB4,0X62,0XFE,0X83,0XFE,
0XAA,0XFE,0X0F,0XFF,0X67,0XFD,0X63,0XBA,0X3C,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X9A,0XE6,0X80,0XD2,
0X21,0XFD,0XC2,0XFD,0XE2,0XF5,0XC2,0XF5,0X82,0XF5,0X82,0XFD,0X62,0XFD,0X61,0XDC,
0X21,0X9B,0X84,0X6A,0XE9,0X6A,0X2C,0X63,0XAF,0X63,0X11,0X74,0X6E,0X63,0X2C,0X63,
0X89,0X5A,0X04,0X52,0X81,0X7A,0XC2,0XCB,0XE2,0XFC,0X62,0XFD,0X82,0XFD,0XC2,0XFD,
0XC2,0XFD,0XE4,0XFD,0X24,0XFD,0X62,0XCA,0X1C,0XE7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XB1,0XCC,
0X81,0XD2,0XC0,0XF3,0XC1,0XFC,0X02,0XFD,0X02,0XFD,0XE2,0XFC,0XC2,0XFC,0XC2,0XFC,
0X81,0XFC,0X80,0XFB,0XC0,0XC9,0XA4,0X81,0X35,0XAD,0X59,0XCE,0X71,0X9C,0X21,0X81,
0X00,0XDA,0XA1,0XFB,0X82,0XFC,0XA2,0XFC,0X82,0XFC,0XA2,0XFC,0X02,0XFD,0X22,0XFD,
0XE2,0XFC,0X00,0XFC,0X60,0XDA,0X90,0XCC,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X59,0XDE,0X0D,0XC4,0X06,0XCB,0XE4,0XD2,0X03,0XDB,0X03,0XDB,0XE3,0XDA,0XC3,0XD2,
0XA4,0XC2,0X09,0XB3,0XD2,0XBC,0X9E,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFB,0XE6,
0X0E,0XB4,0XA6,0XBA,0X83,0XD2,0XE3,0XE2,0X02,0XEB,0X22,0XEB,0X22,0XE3,0X03,0XDB,
0XE4,0XD2,0X6A,0XC3,0XB6,0XD5,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
ID:584814 發(fā)表于 2020-3-19 16:45 | 只看該作者
改void showimage(const unsigned char *p) 函數(shù),如果是9可能是3*3的循環(huán),停下試試。
ID:372579 發(fā)表于 2020-3-19 20:02 | 只看該作者
這么多代碼,我要寫幾天,過來學(xué)習(xí)經(jīng)驗的
