查看: 3233|回復: 0
利用XPT2046芯片轉換電位器模擬值為數碼管顯示數值的項目工程
本帖最后由 51黑電子會員 于 2020-3-17 09:46 編輯
  1. /***實驗現象:下載程序后四位數碼管顯示XPT2046芯片轉換電位器模擬值,范圍是0-4096,一般達不到最大4096,這個受你供電電壓的影響。還有就是數碼管個位出現數字跳動,是源于程序中編寫了每50下讀取XPT2046芯片轉換電位器模擬值,一是避免XPT2046芯片轉換電位器模擬量為數字跳動太快,二是體現了XPT2046芯片在進行轉換電位器模擬值。***/
  2. #include <reg52.h>
  3. #include<intrins.h>
  4. #define uint unsigned int
  5. #define uchar unsigned char
  6. #define GPIO_DUAN P3
  7. uchar table[]={0x3f, 0x06, 0x5b, 0x4f,0x66, 0x6d, 0x7d, 0x07,0x7f, 0x6f, 0x77, 0x7c,0x39, 0x5e, 0x79, 0x71};
  8. uchar DisplayData[5];
  9. sbit HCA = P2^2;//HCA,HCB,HCC是利用了74HC138譯碼器來進行位選,我們動態位選了4位
  10. sbit HCB = P2^3;
  11. sbit HCC = P2^4;
  12. sbit CLK  = P1^0;
  13. sbit CS   = P1^1;
  14. sbit DIN  = P1^2;
  15. sbit DOUT = P1^3;
  16. void DisplayDS();
  17. void delayms(uint xms);
  18. uint Read_AD_Data(uchar moshi);
  19. void SPI_Write(uchar moshi);
  20. uint GetValue();
  21.   void main()
  22. {
  23.    uint temp, cnt = 50;
  24.    while(1)
  25.   {
  26.     if(cnt == 50)//每50下讀取轉換值,避免數字跳動太快
  27.    {
  28.      temp = Read_AD_Data(0x94);
  29.      cnt = 0;
  30.     }
  31.     cnt++;
  32.     DisplayData[0] = table[temp/1000];
  33.     DisplayData[1] = table[temp%1000/100];
  34.     DisplayData[2] = table[temp%100/10];
  35.     DisplayData[3] = table[temp%10];
  36.     DisplayDS();
  37.    }
  38. }
  39.   void DisplayDS()//動態掃描函數
  40. {
  41.    uint i;
  42.    for(i = 0; i < 4; i++)
  43. {
  44.     GPIO_DUAN = 0x00;
  45.     switch(i)
  46.   {
  47.      case 0 :
  48.                  HCC = 0; HCB = 0; HCA = 0;
  49.                          break;
  50.      case 1 :
  51.                  HCC = 0; HCB = 0; HCA = 1;
  52.                          break;
  53.      case 2 :
  54.                  HCC = 0; HCB = 1; HCA = 0;
  55.                          break;
  56.      case 3 :
  57.                  HCC = 0; HCB = 1; HCA = 1;
  58.                          break;
  59.     }
  60.     GPIO_DUAN = DisplayData[i];
  61.     delayms(1);
  62.   }
  63. }
  64.   void delayms(uint xms)
  65. {
  66.    uint i, j;
  67.    for(i = 0; i < xms; i++)
  68.     for(j = 0; j < 110; j++);
  69. }
  70.   uint Read_AD_Data(uchar moshi)//讀取最終的數字量函數
  71. {
  72.    uint i, ans;
  73.    SPI_Write(moshi);
  74.    for(i = 0; i < 5; i++);
  75.    CLK = 1;
  76.    _nop_();
  77.    _nop_();
  78.    CLK = 0;
  79.    _nop_();
  80.    _nop_();
  81.    ans = GetValue();
  82.    CS = 1;
  83.    return ans;
  84. }
  85.   void SPI_Write(uchar moshi)//寫模式函數
  86. {
  87.    uint i;
  88.    CS = 0;
  89.    for(i = 0; i < 8; i++)
  90. {
  91.     CLK = 0;
  92.     DIN = moshi>>7;
  93.     CLK = 1;
  94.     moshi <<= 1;
  95.    }
  96.    CLK = 0;
  97. }
  98.   uint GetValue()//讀取DOUT管腳,得到最終數字量函數。
  99. {
  100.    uint i, ans = 0;
  101.    for(i = 0; i < 12; i++)
  102. {
  103.     CLK = 0;
  104.     ans <<= 1;
  105.     ans |= DOUT;
  106.     CLK = 1;
  107.    }
  108.    CLK = 0;
  109.    return ans;
  110. }
