無論是零器件采購(gòu),或者是程序有不懂或者不明白的地方都可以回帖找我
單片機(jī)源程序如下:
- #define BLINKER_WIFI
- #define BLINKER_MIOT_OUTLET //小愛師兄
- #include <Blinker.h>
- char auth[] = "daa5bb3f1a9f"; //設(shè)備key
- char ssid[] = "JCG-572D74"; //路由器wifi ssid
- char pswd[] = "tmtmtmtm"; //路由器wifi 密碼
- BlinkerButton Button1("btn-abc"); //定義按鈕鍵名
- bool oState = false;
- int counter = 0;
- void miotPowerState(const String & state)
- BLINKER_LOG("need set power state: ", state);
- if (state == BLINKER_CMD_ON) { //小愛師兄控制開命令 此處修改為點(diǎn)動(dòng)模式,適合按鈕操作,
- digitalWrite(0, LOW);
- BlinkerMIOT.powerState("on");
- BlinkerMIOT.print();
- oState = true;
- else if (state == BLINKER_CMD_OFF) { //小愛師兄控制關(guān)命令 此處修改為點(diǎn)動(dòng)模式,適合按鈕操作,
- digitalWrite(0, HIGH);
- BlinkerMIOT.powerState("off");
- oState = false;
- void miotQuery(int32_t queryCode) //小愛師兄控制
- BLINKER_LOG("MIOT Query codes: ", queryCode);
- switch (queryCode)
- case BLINKER_CMD_QUERY_ALL_NUMBER :
- BLINKER_LOG("MIOT Query All");
- BlinkerMIOT.powerState(oState ? "on" : "off");
- break;
- case BLINKER_CMD_QUERY_POWERSTATE_NUMBER :
- BLINKER_LOG("MIOT Query Power State");
- break;
- default :
- break;
- void dataRead(const String & data) // 如果未綁定的組件被觸發(fā),則會(huì)執(zhí)行其中內(nèi)容
- BLINKER_LOG("Blinker readString: ", data);
- Blinker.vibrate();
- uint32_t BlinkerTime = millis();
- Blinker.print("millis", BlinkerTime);
- void button1_callback(const String & state) //點(diǎn)燈app內(nèi)控制按鍵觸發(fā)
- BLINKER_LOG("get button state: ", state);
- digitalWrite(0,LOW);
- delay(200);
- void setup()
- Serial.begin(115200);
- BLINKER_DEBUG.stream(Serial);
- pinMode(0, OUTPUT); //定義io口為輸出
- digitalWrite(0, HIGH); //定義io默認(rèn)為高電平
- Blinker.begin(auth, ssid, pswd);
- Blinker.attachData(dataRead);
- BlinkerMIOT.attachPowerState(miotPowerState);
- BlinkerMIOT.attachQuery(miotQuery);
- Button1.attach(button1_callback);
- void loop()
- Blinker.run();
小愛-燈泡.zip
(759.29 KB, 下載次數(shù): 10)
2020-3-12 17:55 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
