查看: 1542|回復: 1
快崩潰了compiling led.c... linking... *** WARNING L16: UNCALLED SEGMENT, IGNO...
ID:704178 發表于 2020-3-10 17:16 | 顯示全部樓層 |閱讀模式
  1. #include <AT89X52.h>
  2. typedef unsigned  int  u16;
  3. typedef unsigned  char u8;
  4. sbit LSA=P2^2;
  5. sbit LSB=P2^3;
  6. sbit LSC=P2^4;
  7. u8 code smgduan[17]={0X3f,0X06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};//ÏÔê¾0~FμÄ
  8.
  9.
  10. void mian()
  11. {
  12.         while(1)
  13.         {
  14.                 int i,j;
  15.                 for(i=0;i<16;i++)
  16.                 {
  17.                         P1=smgduan[i];
  18.                         for(j=0;j<=30000;j++);
  19.                         P1=0x00;
  20.                 }
  21.         }
  22. }
ID:275826 發表于 2020-3-10 19:24 | 顯示全部樓層
你太粗心了,程序沒有主程序,把mian()改成main()吧
