電路
2020-3-10 13:40 上傳
2020-3-10 13:42 上傳
主程序
- #include < reg51.h >
- #include < intrins.h >
- #define uchar unsigned char
- #define uint unsigned int
- sbit DQ = P3^3 ; //定義DS18B20端口DQ
- sbit BEEP=P3^6 ; //蜂鳴器驅(qū)動線
- bit presence ; //檢測18b20是否插好
- sbit LCD_RS = P2^0 ;
- sbit LCD_RW = P2^1 ;
- sbit LCD_EN = P2^2 ;
- uchar code cdis1[ ] = {" Zhu Ban Wen Du "} ;
- uchar code cdis2[ ] = {" WENDU: . C "} ;
- uchar code cdis3[ ] = {" DS18B20 ERR0R "} ;
- uchar code cdis4[ ] = {" PLEASE CHECK "} ;
- unsigned char data temp_data[2] = {0x00,0x00} ;
- unsigned char data display[5] = {0x00,0x00,0x00,0x00,0x00} ;
- unsigned char code ditab[16] = {0x00,0x01,0x01,0x02,0x03,0x03,0x04,0x04,
- 0x05,0x06,0x06,0x07,0x08,0x08,0x09,0x09} ;
- void beep() ;
- unsigned char code mytab[8] = {0x0C,0x12,0x12,0x0C,0x00,0x00,0x00,0x00} ;
- #define delayNOP() ; {_nop_() ;_nop_() ;_nop_() ;_nop_() ;} ;
- void delay1(int ms)
- unsigned char y ;
- while(ms--)
- for(y = 0 ; y<250 ; y++)
- _nop_() ;
- _nop_() ;
- _nop_() ;
- _nop_() ;
- /*檢查LCD忙狀態(tài) */
- /*lcd_busy為1時,忙,等待。lcd-busy為0時,閑,可寫指令與數(shù)據(jù)。 */
- bit lcd_busy()
- bit result ;
- LCD_RS = 0 ;
- LCD_RW = 1 ;
- LCD_EN = 1 ;
- delayNOP() ;
- result = (bit)(P0&0x80) ;
- LCD_EN = 0 ;
- return(result) ;
- /*寫指令數(shù)據(jù)到LCD */
- /*RS=L,RW=L,E=高脈沖,D0-D7=指令碼。 */
- void lcd_wcmd(uchar cmd)
- while(lcd_busy()) ;
- LCD_RS = 0 ;
- LCD_RW = 0 ;
- LCD_EN = 0 ;
- _nop_() ;
- _nop_() ;
- P0 = cmd ;
- delayNOP() ;
- LCD_EN = 1 ;
- delayNOP() ;
- LCD_EN = 0 ;
- /*寫顯示數(shù)據(jù)到LCD */
- /*RS=H,RW=L,E=高脈沖,D0-D7=數(shù)據(jù)。 */
- void lcd_wdat(uchar dat)
- LCD_RS = 1 ;
- LCD_RW = 0 ;
- LCD_EN = 0 ;
- P0 = dat ;
- delayNOP() ;
- LCD_EN = 1 ;
- delayNOP() ;
- LCD_EN = 0 ;
- /* LCD初始化設(shè)定 */
- void lcd_init()
- delay1(15) ;
- lcd_wcmd(0x01) ; //清除LCD的顯示內(nèi)容
- lcd_wcmd(0x38) ; //16*2顯示,5*7點(diǎn)陣,8位數(shù)據(jù)
- delay1(5) ;
- lcd_wcmd(0x38) ;
- delay1(5) ;
- lcd_wcmd(0x38) ;
- delay1(5) ;
- lcd_wcmd(0x0c) ; //顯示開,關(guān)光標(biāo)
- delay1(5) ;
- lcd_wcmd(0x06) ; //移動光標(biāo)
- delay1(5) ;
- delay1(5) ;
- /* 設(shè)定顯示位置 */
- void lcd_pos(uchar pos)
- lcd_wcmd(pos | 0x80) ; //數(shù)據(jù)指針=80+地址變量
- /*自定義字符寫入CGRAM */
- void writetab()
- unsigned char i ;
- lcd_wcmd(0x40) ; //寫CGRAM
- for (i = 0 ; i< 8 ; i++)
- lcd_wdat(mytab[ i ]) ;
- /*us級延時函數(shù) */
- void Delay(unsigned int num)
- while( --num ) ;
- /*初始化ds1820 */
- Init_DS18B20(void)
- DQ = 1 ; //DQ復(fù)位
- Delay(8) ; //稍做延時
- DQ = 0 ; //單片機(jī)將DQ拉低
- Delay(90) ; //精確延時 大于 480us
- DQ = 1 ; //拉高總線
- Delay(8) ;
- presence = DQ ; //如果=0則初始化成功 =1則初始化失敗
- Delay(100) ;
- DQ = 1 ;
- return(presence) ; //返回信號,0=presence,1= no presence
- /* 讀一個字節(jié) */
- ReadOneChar(void)
- unsigned char i = 0 ;
- unsigned char dat = 0 ;
- for (i = 8 ; i > 0 ; i--)
- DQ = 0 ; // 給脈沖信號
- dat >>= 1 ;
- DQ = 1 ; // 給脈沖信號
- if(DQ)
- dat |= 0x80 ;
- Delay(4) ;
- return (dat) ;
- /* 寫一個字節(jié) */
- WriteOneChar(unsigned char dat)
- DQ = 0 ;
- DQ = dat&0x01 ;
- Delay(5) ;
- DQ = 1 ;
- dat>>=1 ;
- /* 讀取溫度 */
- Read_Temperature(void)
- Init_DS18B20() ;
- WriteOneChar(0xCC) ; // 跳過讀序號列號的操作
- WriteOneChar(0x44) ; // 啟動溫度轉(zhuǎn)換
- Init_DS18B20() ;
- WriteOneChar(0xCC) ; //跳過讀序號列號的操作
- WriteOneChar(0xBE) ; //讀取溫度寄存器
- temp_data[0] = ReadOneChar() ; //溫度低8位
- temp_data[1] = ReadOneChar() ; //溫度高8位
- /* 數(shù)據(jù)轉(zhuǎn)換與溫度顯示 */
- Disp_Temperature()
- display[4]=temp_data[0]&0x0f ;
- display[0]=ditab[display[4]]+0x30 ;//查表得小數(shù)位的值
- display[4]=((temp_data[0]&0xf0)>>4)|((temp_data[1]&0x0f)<<4) ;
- display[3]=display[4]/100+0x30 ;
- display[1]=display[4]%100 ;
- display[2]=display[1]/10+0x30 ;
- display[1]=display[1]%10+0x30 ;
- if(display[3]==0x30) //高位為0,不顯示
- display[3]=0x20 ;
- if(display[2]==0x30) //次高位為0,不顯示
- display[2]=0x20 ;
- lcd_pos(0x48) ;
- lcd_wdat(display[3]) ; //百位數(shù)顯示
- lcd_pos(0x49) ;
- lcd_wdat(display[2]) ; //十位數(shù)顯示
- lcd_pos(0x4a) ;
- lcd_wdat(display[1]) ; //個位數(shù)顯示
- lcd_pos(0x4c) ;
- lcd_wdat(display[0]) ; //小數(shù)位數(shù)顯示
- /* 蜂鳴器響一聲 */
- void beep()
- unsigned char y ;
- for (y=0 ;y<100 ;y++)
- Delay(60) ;
- BEEP=!BEEP ; //BEEP取反
- BEEP=1 ; //關(guān)閉蜂鳴器
- Delay(40000) ;
- /* DS18B20 OK 顯示菜單 */
- void Ok_Menu ()
- uchar m ;
- lcd_init() ; //初始化LCD
- lcd_pos(0) ; //設(shè)置顯示位置為第一行的第1個字符
- m = 0 ;
- while(cdis1[m] != '\0')
- { //顯示字符
- lcd_wdat(cdis1[m]) ;
- m++ ;
- lcd_pos(0x40) ; //設(shè)置顯示位置為第二行第1個字符
- m = 0 ;
- while(cdis2[m] != '\0')
- lcd_wdat(cdis2[m]) ; //顯示字符
- m++ ;
- writetab() ; //自定義字符寫入CGRAM
- delay1(5) ;
- lcd_pos(0x4d) ;
- lcd_wdat(0x00) ; //顯示自定義字符
- /* DS18B20 ERROR 顯示菜單 */
- void Error_Menu ()
- uchar m ;
- m = 0 ;
- while(cdis3[m] != '\0')
- { //顯示字符
- lcd_wdat(cdis3[m]) ;
- m++ ;
- m = 0 ;
- while(cdis4[m] != '\0')
- lcd_wdat(cdis4[m]) ; //顯示字符
- m++ ;
- /* 主函數(shù) */
- void main()
- Ok_Menu () ;
- do
- Read_Temperature() ; //讀取溫度
- Disp_Temperature() ; //顯示溫度
- while(!presence) ;
- Error_Menu () ;
- do
- Init_DS18B20() ;
- beep() ;
- while(presence) ;
復(fù)制代碼 INTRINS.H
- INTRINS.H
- Intrinsic functions for C51.
- Copyright (c) 1988-2010 Keil Elektronik GmbH and ARM Germany GmbH
- All rights reserved.
- #ifndef __INTRINS_H__
- #define __INTRINS_H__
- #pragma SAVE
- #if defined (__CX2__)
- #pragma FUNCTIONS(STATIC)
- /* intrinsic functions are reentrant, but need static attribute */
- #endif
- extern void _nop_ (void);
- extern bit _testbit_ (bit);
- extern unsigned char _cror_ (unsigned char, unsigned char);
- extern unsigned int _iror_ (unsigned int, unsigned char);
- extern unsigned long _lror_ (unsigned long, unsigned char);
- extern unsigned char _crol_ (unsigned char, unsigned char);
- extern unsigned int _irol_ (unsigned int, unsigned char);
- extern unsigned long _lrol_ (unsigned long, unsigned char);
- extern unsigned char _chkfloat_(float);
- extern int abs (int);
- extern void _illop_ (void);
- #endif
- #if !defined (__CX2__)
- extern void _push_ (unsigned char _sfr);
- extern void _pop_ (unsigned char _sfr);
- #endif
- #pragma RESTORE
- #endif
全部資料51hei下載地址:
18B20 1602LCD溫度實驗.zip
(35.52 KB, 下載次數(shù): 13)
2020-3-10 13:42 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
