查看: 2137|回復(fù): 1
為什么經(jīng)過ADC0808轉(zhuǎn)換后的,lcd1602沒有變化一直顯示0,求大神解答
ID:688824 發(fā)表于 2020-3-9 14:50 | 顯示全部樓層 |閱讀模式
單片機(jī)源程序如下:
  1. #include<reg51.h>
  3. #define uint unsigned int
  4. sbit rs=P2^0;
  5. sbit rw=P2^1;
  6. sbit en=P2^2;
  7. sbit START=P2^3;
  8. sbit ALE=P2^3;
  9. sbit CLK=P2^4;
  10. sbit OE=P2^5;
  11. sbit EOC=P2^6;
  12. uchar code table[]="Digital Ohmmeter";
  13. uchar code bby[]="(R)=";
  14. //uchar code abc[]={0,1,2,3,4,5,6,7,8,9};
  15. uchar num=0;
  16. uint  temp,getdata;
  17. uchar qian, bai, shi, ge;
  18. void delay(uint z)
  19.           {
  20.         uint x,y;
  21.           for(z=x;x>0;x--)
  22.           for(y=110;y>0;y--);
  23.           }
  24. bit lcd_busy_check()                                                        //1602狀態(tài)檢測是否忙碌
  25.         {
  26.           bit  result;
  27.           rs=0;
  28.           rw=1;
  29.           en=1;
  30.           delay(10);
  31.           result=(bit)(P0&0x80);
  32.           en=0;
  33.           return  result;
  34.         }
  35. void write_comd(uchar command)                                            //寫LCD命令
  36.         {
  37.           while(lcd_busy_check());
  38.           rw=0;
  39.           rs=0;
  40.           en=0;
  41.           P0=command;
  42.           delay(5);
  43.           en=1;
  44.           delay(5);
  45.           en=0;
  46.         }
  47. void  write_data(uchar dat)                                             //向1602發(fā)送數(shù)據(jù)
  48.         {
  49.           while(lcd_busy_check());
  50.           rs=1;
  51.           rw=0;
  52.           en=0;
  53.           P0=dat;
  54.           delay(5);
  55.           en=1;
  56.           delay(5);
  57.           en=0;
  58.         }
  59. lcd_init()        //LCD1602初始化
  60.         {
  61.           write_comd(0x38);          //顯示模式設(shè)置為16X2顯示
  62.           write_comd(0x0c);   //開顯示屏,關(guān)光標(biāo)
  63.           write_comd(0x06);    //字符進(jìn)入模式:屏幕不動(dòng),字符后移
  64.           write_comd(0x01);  //清屏
  65.           write_comd(0x80);
  66.         }
  67. lcd_display()
  68.         {
  69.         uint a,b;
  70.           for(a=0;a<16;a++)
  71.                           {
  72.                           write_data(table[a]);
  73.                           }
  74.                   //delay(200);
  75.                   write_comd(0x80+0x40+2);
  76.                   for(b=0;b<4;b++)
  77.                           {
  78.                           write_data(bby[b]);
  79.                           }
  80.                   //delay(200);
  81.                   write_comd(0x80+0x40+13);
  82.
  83.                           write_data(0xF4);//顯示歐姆符號
  84.
  85.                  // delay(200);
  86.
  87.         }
  88.   adc0808_tra()      // AD轉(zhuǎn)換
  89.                 {
  90.                    uint getdata;
  91.
  92.                   START=0;
  93.                   START=1;
  94.                   delay(1);
  95.                   START=0;
  96.                   delay(5);
  97.                   EOC=1;
  98.                   while(EOC==0);
  99.                   OE=1;
  100.
  101.                   getdata=P1;
  102.                   OE=0;
  103.                   return getdata;
  104.
  105.                   }
  106.
  107.
  108. void data_display()
  109.                 {
  110.                            temp=getdata*1.0/255*500;
  111.                     qian=temp/1000;
  112.            bai=temp%1000/100;
  113.                shi=temp%100/10;
  114.                   ge=temp%10;
  115.
  116.                 write_comd(0x80+0x40+7);
  117.                 write_data(qian+0x30);        //千位
  118.                 delay(5);
  119.                 write_comd(0x80+0x40+8);
  120.                 write_data(bai+0x30);//百位
  121.                 delay(5);
  122.                 write_comd(0x80+0x40+9);
  123.                 write_data(shi+0x30);        //十位
  124.                 delay(5);
  125.                 write_comd(0x80+0x40+10);
  126.                 write_data('.');
  127.                 delay(5);
  128.                 //write_comd(0x80+0x40+11);
  129.           write_data(ge+0x30);         //小數(shù)一位
  130.                 }
  131. void T0init()
  132.    {
  133.    TMOD=0x01;
  134.    TH0=(65536-200)/256;
  135.    TL0=(65536-200)%256;
  136.    EA=1;
  137.    ET0=1;
  138.    TR0=1;
  139.    //delay(20);
  140.    }
  141. void main()
  142.          {
  143.
  144.           T0init();
  145.           lcd_init();
  146.             lcd_display();
  147.            while(1)
  148.            {
  149.                       adc0808_tra();
  150.               data_display();
  151.          }
  152.          }
  153.    void timer() interrupt 1
  154.            {
  155.           TH0=(65536-200)/256;
  156.       TL0=(65536-200)%256;
  157.           CLK=~CLK;
  158.         }
ID:704545 發(fā)表于 2020-3-10 16:28 | 顯示全部樓層
假如把仿真的圖文件和程序打包放上來可能會有人幫你跑一下查找原因(前提是不要下載就扣黑幣啊),這樣找出問題的所在更準(zhǔn)確更少花時(shí)間。
