查看: 1675|回復: 0
python+opencv識別紅燈
ID:704010 發表于 2020-3-7 13:13 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
# -*- coding: utf-8 -*-
#width = 256, 192
#YSU1100W fast-straight
#YSU1000W fast-left
#YSU0100W fast-right
#YSU1101W slow-s
#YSU1001W s-l
#YSU0101W s-r
#YSU0010W find
import numpy as np
import cv2
import serial
import time
#設定紅色閾值,HSV空間
redLower = np.array([0, 0, 230])
redUpper = np.array([10, 255, 237])
#初始化質心
center = 0
#初始化串口
ser = serial.Serial("/dev/ttyUSB0",9600)
# s = 0
#打開攝像頭
camera = cv2.VideoCapture(0)
camera.set(3, 320)
camera.set(4, 240)
#遍歷每一幀,檢測信標燈
while True:
    # s = ser.read(8)
    # # 如果讀到單片機傳過來的信號,倒車
    # if s:
    #     ser.write("YSU0000W".encode())
    #     print("back")
    #     time.sleep(3)
    #     s = 0
    #讀取幀
    (ret, frame) = camera.read()
    #判斷是否成功打開攝像頭
    if not ret:
        # print ('No Camera')
        break
    #轉到HSV空間
    hsv = cv2.cvtColor(frame, cv2.COLOR_BGR2HSV)
    #根據閾值構建掩膜 黑白 亮的為閾值內區域
    mask = cv2.inRange(hsv, redLower, redUpper)
    #腐蝕操作  iterations:迭代次數
    mask = cv2.erode(mask, None, iterations=1)
    #膨脹操作,其實先腐蝕再膨脹的效果是開運算,去除噪點
    mask = cv2.dilate(mask, None, iterations=14)
    #根據灰度值化為二值圖
    # GrayImage=cv2.cvtColor(frame, cv2.COLOR_BGR2GRAY)
    # ret, gray=cv2.threshold(GrayImage, 230, 255, cv2.THRESH_BINARY)
    #把紅色分的二值圖和灰度二值圖疊加
    # andout = cv2.bitwise_and(mask, gray)
    #檢測尋找輪廓 cv2.RETR_EXTERNAL 只得到最外面的輪廓
    #cv2.findContours()  opencv3會返回三個值,分別是img, countours, hierarchy
    cnts = cv2.findContours(mask.copy(), cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_SIMPLE)[-2]
    #初始化圓形輪廓質心
    center = None
    #如果存在輪廓
    if len(cnts) > 0:
        #找到面積最大的輪廓
        c = max(cnts, key = cv2.contourArea)
        #確定面積最大的輪廓的最小外接圓
        ((x, y), radius) = cv2.minEnclosingCircle(c)
        #計算輪廓的矩
        M = cv2.moments(c)
        #計算質心
        try:
            center = (int(M["m10"]/M["m00"]), int(M["m01"]/M["m00"]))
        except:
            continue
        #只有當半徑大于1時,才執行
        if radius >= 1:
            #畫輪廓圓:img,center,radius,color 厚度:負值就是實心
            cv2.circle(frame, (int(x), int(y)), int(radius), (0, 255, 255), 1)
            #在質心中間畫半徑為5的點
            cv2.circle(frame, center, 5, (0, 0, 255), -1)
            #最關鍵的值pos,相對于畫面中心的x方向像素差
            pos = center[0]-160
            # print("x=%s"%pos)
            # print(radius)
            try:
                #通過x坐標控制串口
                # if radius >= 60:
                #     t = 0
                #     while True:
                #         t += 0.05
                #         if t >= 0.4:
                #             break
                #         ser.write("YSU1101W".encode())
                #         time.sleep(0.05)
                #減速 拐角大
                if radius >= 100:
                    #向左轉
                    if pos < -50:
                        ser.write("YSU1001W".encode())
                    #直線
                    elif -50 <= pos <= 50:
                    #向右轉
                    else:
                        ser.write("YSU0101W".encode())
                # 正常速度,拐角大
                elif 50 <= radius < 100:
                    if pos < -45:
                        ser.write("YSU0001W".encode())
                    elif -45 <= pos <= 45:
                        ser.write("YSU1100W".encode())
                    else:
                        ser.write("YSU0110W".encode())
                #正常速度,拐角小
                else:
                     #向左轉
                    if pos < -30:
                        ser.write("YSU1000W".encode())
                    #直線
                    elif - 30<= pos <= 30:
                    #向右轉
                    else:
                        ser.write("YSU0100W".encode())
            except:
                continue
        else:
           ser.write("YSU0010W".encode())
    else:
    #cv2.imshow('Frame', frame)
    #鍵盤檢測,檢測到esc鍵退出
    k = cv2.waitKey(1)&0xFF
    if k == 27:
        break
#攝像頭釋放
camera.release()
#銷毀所有窗口
# cv2.destroyAllWindows()
#關閉串口
ser.close()
