- #include <reg52.h> //調(diào)用單片機(jī)頭文件
- #define uchar unsigned char //無符號(hào)字符型 宏定義 變量范圍0~255
- #define uint unsigned int //無符號(hào)整型 宏定義 變量范圍0~65535
- #include <intrins.h>
- #include "eeprom52.h"
- //數(shù)碼管段選定義 0 1 2 3 4 5 6 7 8 9
- uchar code smg_du[]={0x28,0xee,0x32,0xa2,0xe4,0xa1,0x21,0xea,0x20,0xa0,
- 0x60,0x25,0x39,0x26,0x31,0x71,0xff}; //斷碼
- uchar dis_smg[8] ={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8};
- //數(shù)碼管位選定義
- sbit smg_we1 = P3^4; //數(shù)碼管位選定義
- sbit smg_we2 = P3^5;
- sbit smg_we3 = P3^6;
- sbit smg_we4 = P3^7;
- sbit c_send = P3^2; //超聲波發(fā)射
- sbit c_recive = P3^3; //超聲波接收
- sbit beep = P2^3; //蜂鳴器IO口定義
- uchar smg_i = 3; //顯示數(shù)碼管的個(gè)位數(shù)
- bit flag_300ms ;
- long distance; //距離
- uint set_d; //距離
- uchar flag_csb_juli; //超聲波超出量程
- uint flag_time0; //用來保存定時(shí)器0的時(shí)候的
- uchar menu_1; //菜單設(shè)計(jì)的變量
- /***********************1ms延時(shí)函數(shù)*****************************/
- void delay_1ms(uint q)
- uint i,j;
- for(i=0;i<q;i++)
- for(j=0;j<120;j++);
- /***********************處理距離函數(shù)****************************/
- void smg_display()
- dis_smg[0] = smg_du[distance % 10];
- dis_smg[1] = smg_du[distance / 10 % 10];
- dis_smg[2] = smg_du[distance / 100 % 10] & 0xdf; ;
- /******************把數(shù)據(jù)保存到單片機(jī)內(nèi)部eeprom中******************/
- void write_eeprom()
- SectorErase(0x2000);
- byte_write(0x2000, set_d % 256);
- byte_write(0x2001, set_d / 256);
- byte_write(0x2058, a_a);
- /******************把數(shù)據(jù)從單片機(jī)內(nèi)部eeprom中讀出來*****************/
- void read_eeprom()
- set_d = byte_read(0x2001);
- set_d <<= 8;
- set_d |= byte_read(0x2000);
- a_a = byte_read(0x2058);
- /**************開機(jī)自檢eeprom初始化*****************/
- void init_eeprom()
- read_eeprom(); //先讀
- if(a_a != 1) //新的單片機(jī)初始單片機(jī)內(nèi)問eeprom
- set_d = 50;
- a_a = 1;
- write_eeprom(); //保存數(shù)據(jù)
- /********************獨(dú)立按鍵程序*****************/
- uchar key_can; //按鍵值
- void key() //獨(dú)立按鍵程序
- static uchar key_new;
- key_can = 20; //按鍵值還原
- P2 |= 0x07;
- if((P2 & 0x07) != 0x07) //按鍵按下
- delay_1ms(1); //按鍵消抖動(dòng)
- if(((P2 & 0x07) != 0x07) && (key_new == 1))
- { //確認(rèn)是按鍵按下
- key_new = 0;
- switch(P2 & 0x07)
- case 0x06: key_can = 3; break; //得到k2鍵值
- case 0x05: key_can = 2; break; //得到k3鍵值
- case 0x03: key_can = 1; break; //得到k4鍵值
- else
- key_new = 1;
- /****************按鍵處理顯示函數(shù)***************/
- void key_with()
- if(key_can == 1) //設(shè)置鍵
- menu_1 ++;
- if(menu_1 >= 2)
- menu_1 = 0;
- smg_i = 3; //只顯示3位數(shù)碼管
- if(menu_1 == 1)
- smg_i = 4; //只顯示4位數(shù)碼管
- if(menu_1 == 1) //設(shè)置報(bào)警
- if(key_can == 2)
- set_d ++ ; //加1
- if(set_d > 400)
- set_d = 400;
- if(key_can == 3)
- set_d -- ; //減1
- if(set_d <= 1)
- set_d = 1;
- dis_smg[0] = smg_du[set_d % 10]; //取小數(shù)顯示
- dis_smg[1] = smg_du[set_d / 10 % 10] ; //取個(gè)位顯示
- dis_smg[2] = smg_du[set_d / 100 % 10] & 0xdf ; //取十位顯示
- dis_smg[3] = 0x60; //a
- /****************報(bào)警函數(shù)***************/
- void clock_h_l()
- static uchar value;
- if(distance <= set_d)
- value ++; //消除實(shí)際距離在設(shè)定距離左右變化時(shí)的干擾
- if(value >= 2)
- beep = ~beep; //蜂鳴器報(bào)警
- else
- value = 0;
- beep = 1; //取消報(bào)警
- /***********************數(shù)碼位選函數(shù)*****************************/
- void smg_we_switch(uchar i)
- switch(i)
- case 0: smg_we1 = 0; smg_we2 = 1; smg_we3 = 1; smg_we4 = 1; break;
- case 1: smg_we1 = 1; smg_we2 = 0; smg_we3 = 1; smg_we4 = 1; break;
- case 2: smg_we1 = 1; smg_we2 = 1; smg_we3 = 0; smg_we4 = 1; break;
- case 3: smg_we1 = 1; smg_we2 = 1; smg_we3 = 1; smg_we4 = 0; break;
- /***********************數(shù)碼顯示函數(shù)*****************************/
- void display()
- static uchar i;
- i++;
- if(i >= smg_i)
- i = 0;
- smg_we_switch(i); //位選
- P1 = dis_smg[i]; //段選
- /******************小延時(shí)函數(shù)*****************/
- void delay()
- _nop_(); //執(zhí)行一條_nop_()指令就是1us
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- /*********************超聲波測(cè)距程序*****************************/
- void send_wave()
- c_send = 1; //10us的高電平觸發(fā)
- delay();
- c_send = 0;
- TH0 = 0; //給定時(shí)器0清零
- TL0 = 0;
- TR0 = 0; //關(guān)定時(shí)器0定時(shí)
- while(!c_recive); //當(dāng)c_recive為零時(shí)等待
- TR0=1;
- while(c_recive) //當(dāng)c_recive為1計(jì)數(shù)并等待
- flag_time0 = TH0 * 256 + TL0;
- if((flag_time0 > 40000)) //當(dāng)超聲波超過測(cè)量范圍時(shí),顯示3個(gè)888
- TR0 = 0;
- flag_csb_juli = 2;
- distance = 888;
- break ;
- else
- flag_csb_juli = 1;
- if(flag_csb_juli == 1)
- TR0=0; //關(guān)定時(shí)器0定時(shí)
- distance =flag_time0; //讀出定時(shí)器0的時(shí)間
- distance *= 0.017; // 0.017 = 340M / 2 = 170M = 0.017M 算出來是米
- if((distance > 500)) //距離 = 速度 * 時(shí)間
- distance = 888; //如果大于3.8m就超出超聲波的量程
- /*********************定時(shí)器0、定時(shí)器1初始化******************/
- void time_init()
- EA = 1; //開總中斷
- TMOD = 0X11; //定時(shí)器0、定時(shí)器1工作方式1
- ET0 = 0; //關(guān)定時(shí)器0中斷
- TR0 = 1; //允許定時(shí)器0定時(shí)
- ET1 = 1; //開定時(shí)器1中斷
- TR1 = 1; //允許定時(shí)器1定時(shí)
- /***************主函數(shù)*****************/
- void main()
- beep = 0; //開機(jī)叫一聲
- delay_1ms(150);
- P0 = P1 = P2 = P3 = 0xff; //初始化單片機(jī)IO口為高電平
- send_wave(); //測(cè)距離函數(shù)
- smg_display(); //處理距離顯示函數(shù)
- time_init(); //定時(shí)器初始化程序
- init_eeprom(); //開始初始化保存的數(shù)據(jù)
- while(1)
- if(flag_300ms == 1)
- flag_300ms = 0;
- clock_h_l(); //報(bào)警函數(shù)
- if(beep == 1)
- if(menu_1 == 0)
- key(); //按鍵函數(shù)
- if(key_can < 10)
- key_with(); //按鍵處理函數(shù)
- /*********************定時(shí)器1中斷服務(wù)程序************************/
- void time1_int() interrupt 3
- static uchar value; //定時(shí)2ms中斷一次
- TH1 = 0xf8;
- TL1 = 0x30; //2ms
- display(); //數(shù)碼管顯示函數(shù)
- value++;
- if(value >= 150)
- value = 0;
- flag_300ms = 1;
