查看: 3745|回復: 2
單片機8位競賽搶答器調研,模塊劃分與接口定義文檔+Proteus仿真程序
ID:701488 發表于 2020-3-3 12:01 | 顯示全部樓層 |閱讀模式
使用at89c51實現功能
單片機源程序:
#include<reg51.h>
#include<lcd1602.h>
sbit sjjia=P1^0;         //定義時間加按鈕
sbit sjjian=P1^1;                  //定義時間減按鈕
sbit kaishi=P1^2;                  //定義開始按鈕
sbit fuwei=P1^3;                  //定義復位按鈕
sbit soud=P1^4;                          //報警按鈕
sbit led_r=P1^5;                  //定義搶答成功指示
sbit led_y=P1^6;                   //定義闡述時間到指示
unsigned char num[]={'0','1','2','3','4','5','6','7','8','9'},num2;
unsigned char model,time,temp;
void init()        //初始化函數
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        ET0=1;
        TR0=0;
        EA=1;
        P1=0x0f;
        model=0;
        time=30;
void delay(unsigned char i)        //延時函數
        unsigned char j,k;
        while(i--)
                for(j=100;j>0;j--)
                        for(k=100;k>0;k--);
void star() //啟動
        lcd_xml(0x80);lcd_xsj("     welcome    ");
        delay(100);
        lcd_xml(0xc0);lcd_xsj(" 8 Way Responder");
        delay(80);
void led_num() //刷新倒計時
        lcd_xml(0x80);lcd_xsj(" Countdown :    ");
        lcd_xml(0x8d);lcd_xsj2(num[time/10]);
        lcd_xml(0x8e);lcd_xsj2(num[time%10]);
void reset()        //復位
        TR0=0;
        P1=0x0f;
        led_r=0;
        led_y=0;
        P2=0xff;
        model=0;
        time=10;
        led_num();
        lcd_xml(0xc0);lcd_xsj("   Not started  ");
void Not_started()
        if(sjjia==0)
                delay(10);
                if(sjjia==0)
                        time++;
                        if(time==100) time=0;
                        led_num();
        if(sjjian==0)
                delay(10);
                if(sjjian==0)
                        time--;
                        if(time==0) time=99;
                        led_num();
        if(kaishi==0)
                delay(10);
                if(kaishi==0)
                        model=1;
                        TR0=1;
                        lcd_xml(0xc0);lcd_xsj(" Start Responder");
                        soud=1;delay(10);soud=0;
void anjian()
        if(P2 != 0xff)
                delay(5);
                if(P2 != 0xff)
                        temp=~P2;
                        model=3;
                        led_r=1;
                        switch(temp)
                                case 0x01:num2=1;break;
                                case 0x02:num2=2;break;
                                case 0x04:num2=3;break;
                                case 0x08:num2=4;break;
                                case 0x10:num2=5;break;
                                case 0x20:num2=6;break;
                                case 0x40:num2=7;break;
                                case 0x80:num2=8;break;
                        lcd_xml(0xc0);lcd_xsj(" Competitor:   ");
                        lcd_xml(0xce);lcd_xsj2(num[num2]);
                        time=60;
                        P2=temp;
void finish()
        if(!time)
                led_y=1;
                lcd_xml(0xc0);lcd_xsj("      End       ");
        init();
        lcd_init();
        star();
        reset();
                if(fuwei==0)        //復位鍵檢測
                        delay(1);
                        if(fuwei==0)
                                reset();
                switch(model)
                        case 0:Not_started();break;
                        case 1:anjian();break;
                        case 2:finish();break;
                        case 3:break;
                        default : model=0;break;
void timee() interrupt 1        //1s函數中斷
        unsigned char a;
        a++;        //是否滿1s
        if(a==24)
                a=0;
                if(model==1 || model==3)
                        time--;
                        led_num();
                        if(time==0)
                                model=2;
                                soud=1;delay(20);soud=0;
全部資料51hei下載地址:
電子綜合設計.7z (811.36 KB, 下載次數: 161)
ID:890070 發表于 2021-10-18 10:54 | 顯示全部樓層
剛好需要 很棒
ID:977459 發表于 2021-11-23 13:23 | 顯示全部樓層
有顯示得分的程序嗎?
