- #include<reg52.h>
- #include<Temp.h>
- sbit LSA=P2^2;
- sbit LSC=P2^3;
- sbit LSB=P2^4;
- uchar code smgduan[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- uchar Display[8];
- float tp;
- void delay(uint i)
- while(i--);
- void datapros(int temp)
- if (temp<0)
- Display[0]=0x40;
- temp=temp-1;
- temp=~temp;
- tp=temp;
- temp=tp*0.0625*100+0.5;
- else
- Display[0]=0x00;
- tp=temp;
- Display[1]= smgduan[temp/10000];
- Display[2]= smgduan[temp%10000/1000];
- Display[3]= smgduan[temp%10000%1000/100] | 0x80;
- Display[4]= smgduan[temp%100/10];
- Display[5]= smgduan[temp%10];
- void dianliang()
- uchar i;
- for(i=0;i<=5;i++)
- switch(i)
- case(0):LSA=1;LSB=1;LSC=1;break;
- case(1):LSA=0;LSB=1;LSC=1;break;
- case(2):LSA=1;LSB=0;LSC=1;break;
- case(3):LSA=0;LSB=0;LSC=1;break;
- case(4):LSA=1;LSB=1;LSC=0;break;
- case(5):LSA=0;LSB=1;LSC=0;break;
- P0=Display[i];
- delay(100);
- P0=0x00;
- void main()
- while(1)
- datapros(Ds18b20_ReadTemp());
- dianliang();
- #include"Temp.h"
- void Delay_ms(uint y)
- uint x;
- for( ; y>0; y--)
- for(x=110; x>0; x--);
- uchar Ds18b20_Init()
- uchar i;
- DQ = 0;
- i = 70;
- while(i--);
- DQ = 1;
- i = 0;
- while(DQ)
- Delay_ms(1);
- i++;
- if(i>5)
- return 0;
- return 1;
- void Ds18b20_WriteByte(uchar dat)
- uint i;
- for(i=0;i<8;i++)
- DQ=0;
- i++;
- DQ=dat&0x01;
- i=6;
- while(i--);
- DQ=1;
- dat=dat>>1;
- uchar Ds18b20_ReadByte()
- uchar bi,Byte;
- uint i,j;
- for(i=0;i<8;i++)
- DQ=0;
- j=0;
- DQ=1;
- j++;
- j++;
- bi=DQ;
- Byte =(Byte>>1)|(bi<<7);
- i=4;
- while(i--);
- return Byte;
- void Ds18b20_ConvertTemp()
- Ds18b20_Init();
- Delay_ms(1);
- Ds18b20_WriteByte(0xcc);
- Ds18b20_WriteByte(0x44);
- void Ds18b20_ReadTempCom()
- Ds18b20_Init();
- Delay_ms(1);
- Ds18b20_WriteByte(0xbe);
- int Ds18b20_ReadTemp()
- int temp=0;
- uchar tmh,tml;
- Ds18b20_ConvertTemp();
- Ds18b20_ReadTempCom();
- tml=Ds18b20_ReadByte();
- tmh=Ds18b20_ReadByte();
- temp=tmh;
- temp<<=8;
- temp|=tml;
- return temp;
- #ifndef _temp_H
- #define _temp_H
- #include<reg52.h>
- sbit DQ=P3^7;
- #ifndef uchar
- #define uchar unsigned char
- #endif
- #ifndef uint
- #define uint unsigned int
- #endif
- int Ds18b20Read_Temp();
- #endif
復(fù)制代碼 |
