#include <reg52.h>
#include <intrins.h>
//定義Max7219端口
sbit Max7219_pinCLK = P2^2;//CLK
sbit Max7219_pinCS = P2^1;//CS
sbit Max7219_pinDIN = P2^0;//DIN
uchar code disp1[8]=
{0x66,0x99,0x81,0x81,0x42,0x24,0x18,0x00};//愛心
void Delay_xms(uint x)
uint i,j;
for(i=0;i<x;i++)
for(j=0;j<112;j++);
//功能:向MAX7219(U3)寫入字節(jié)
//入口參數(shù):DATA
//出口參數(shù):無
//說明:
void Write_Max7219_byte(uchar DATA)
uchar i;
Max7219_pinCS=0;
for(i=8;i>=1;i--)
Max7219_pinCLK=0;
Max7219_pinDIN=DATA&0x80;
DATA=DATA<<1;
Max7219_pinCLK=1;
//功能:向MAX7219寫入數(shù)據(jù)
//入口參數(shù):address、dat
//出口參數(shù):無
//說明:
void Write_Max7219(uchar address,uchar dat)
Max7219_pinCS=0;
Write_Max7219_byte(address); //寫入地址,即數(shù)碼管編號
Write_Max7219_byte(dat); //寫入數(shù)據(jù),即數(shù)碼管顯示數(shù)字
Max7219_pinCS=1;
void Init_MAX7219(void)
Write_Max7219(0x09, 0x00); //譯碼方式:BCD碼
Write_Max7219(0x0a, 0x03); //亮度
Write_Max7219(0x0b, 0x07); //掃描界限;8個數(shù)碼管顯示
Write_Max7219(0x0c, 0x01); //掉電模式:0,普通模式:1
Write_Max7219(0x0f, 0x00); //顯示測試:1;測試結(jié)束,正常顯示:0
void main(void)
uchar i;
Delay_xms(50);
Init_MAX7219();
for(i=1;i<9;i++)
Write_Max7219(i,disp1[i-1]);
