ADC2應該是開了,我配置的不同引腳,其實在引腳配置上,沒什么用,只是這句改ADC線路就可以在對應的引腳檢測了
ADC_RegularChannelConfig(ADC2, ADC_Channel_2, 1, ADC_SampleTime_55Cycles5);
現在是這句ADC地址改成,ADC1+0X4C。就可以在對應的引腳上檢測到,問題是__IO uint32_t ADC_ConvertedValue;這個
內存上數據,只能看一個,不能同時看,左右移16也不行,我總在開個函數,檢測哪個開哪個ADC吧,想同時工作
找了資料都是配置,就是沒這個數據怎么取,我左右移16都不行,這個誰能幫我一下???????????????
2020-2-21 13:41 上傳
DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)ADC2+0x4c; //ADC地址
/*********************下是代碼
#include "adc.h"
#include "delay.h"
#include "sys.h"
//初始化ADC
//這里我們僅以規則通道為例
//我們默認將開啟通道0~3
//#define ADC1_DR_Address ((u32)ADC1+0x4c)
void My_Adc_Init(void)
/*+++++++++++++++++ADC初始化++++++++++++++++*/
DMA_InitTypeDef DMA_InitStructure;
ADC_InitTypeDef ADC_InitStructure;
/* Enable DMA clock */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
/* Enable ADC1 and GPIOC clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_ADC2 | RCC_APB2Periph_GPIOA, ENABLE);
/* Configure PC.01 as analog input */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 |GPIO_Pin_4;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
GPIO_Init(GPIOA, &GPIO_InitStructure); // PC1,輸入時不用設置速率
/* DMA channel1 configuration */
DMA_DeInit(DMA1_Channel1);
/****************************這里改成ADC1***************************
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue;//內存地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
DMA_InitStructure.DMA_BufferSize = 2;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//外設地址固定
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable; //內存地址固定
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //半字
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //循環傳輸
DMA_InitStructure.DMA_Priority = DMA_Priority_High;zZ
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //內存到內存
DMA_Init(DMA1_Channel1, &DMA_InitStructure);
/* Enable DMA channel1 */
DMA_Cmd(DMA1_Channel1, ENABLE);
/* ADC3 configuration */
ADC_InitStructure.ADC_Mode = ADC_Mode_RegSimult; //,同步規則ADC模式
ADC_InitStructure.ADC_ScanConvMode = DISABLE ; //禁止掃描模式,掃描模式用于多通道采集
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //開啟連續轉換模式,即不停地進行ADC轉換
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //不使用外部觸發轉換
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //采集數據右對齊
ADC_InitStructure.ADC_NbrOfChannel = 1; //要轉換的通道數目1
ADC_Init(ADC2, &ADC_InitStructure);
ADC_Init(ADC1, &ADC_InitStructure);
/*配置ADC時鐘,為PCLK2的8分頻,即9Hz*/
RCC_ADCCLKConfig(RCC_PCLK2_Div8);
/*配置ADC3的通道11為55. 5個采樣周期,序列為1 */
ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 1, ADC_SampleTime_55Cycles5);
/* Enable ADC3 DMA */
ADC_DMACmd(ADC2, ENABLE);
ADC_DMACmd(ADC1, ENABLE);
/* Enable ADC3 */
ADC_Cmd(ADC2, ENABLE);
ADC_Cmd(ADC1, ENABLE);
/*復位校準寄存器 */
ADC_ResetCalibration(ADC2);
/*等待校準寄存器復位完成 */
while(ADC_GetResetCalibrationStatus(ADC2));
/* ADC校準 */
ADC_StartCalibration(ADC2);
/* 等待校準完成*/
while(ADC_GetCalibrationStatus(ADC2));
/*復位校準寄存器 */
ADC_ResetCalibration(ADC1);
/*等待校準寄存器復位完成 */
while(ADC_GetResetCalibrationStatus(ADC1));
/* ADC校準 */
ADC_StartCalibration(ADC1);
/* 等待校準完成*/
while(ADC_GetCalibrationStatus(ADC1));
/* 由于沒有采用外部觸發,所以使用軟件觸發ADC轉換 */
ADC_SoftwareStartConvCmd(ADC2, ENABLE);
ADC_SoftwareStartConvCmd(ADC1, ENABLE);
void My_Dma_Adc_Init(u32 Adc1)
{ delay_us(200);
//獲得ADC值
float Get_Adc1_Average(u8 times)
u32 temp_val=0;
u8 t;
//void My_Dma_Adc_Init(u32 Adc1)
for(t=0;t<times;t++)
temp_val+=ADC_ConvertedValue<<16;
delay_us(200);
return temp_val/times;
float Get_Adc2_Average(u8 times)
u32 temp_val=0;
u8 t;
temp_val+=ADC_ConvertedValue;
delay_us(200);
