查看: 7768|回復(fù): 7
分享基于STM32F103實(shí)現(xiàn)驅(qū)動LCD1602的代碼
ID:695711 發(fā)表于 2020-2-20 16:37 | 顯示全部樓層 |閱讀模式
注:
     此貼僅供提供項目(以正點(diǎn)原子的框架撰寫)(已測試),不提供LCD1602的資料(資料可以網(wǎng)上搜索,很容易就找到),如有對代碼有任何問題可以評論,我會不定期回復(fù)!
此貼所提供文件僅供學(xué)習(xí),謝謝。
單片機(jī)源程序如下:
  1. #include "lcd1602.h"
  2. void GPIO_Configuration(void)
  3. {
  4.         GPIO_InitTypeDef  GPIO_InitStructure;
  5.
  6.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOF, ENABLE);         //時鐘使能
  7.
  8.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_2|GPIO_Pin_4;
  9.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  10.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  11.   GPIO_Init(GPIOC, &GPIO_InitStructure);
  12.
  13.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  14.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  15.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  16.   GPIO_Init(GPIOF, &GPIO_InitStructure);
  17. }
  18.
  19. void LCD1602_Wait_Ready(void) //判忙
  20. {
  21.         u8 sta;
  22.         //DATAOUT(0xff);
  23.   LCD_RS_Clr();
  24.         LCD_RW_Set();
  25.         do
  26.         {
  27.     LCD_EN_Set();
  28.           delay_ms(5);
  29.           sta = GPIO_ReadInputDataBit(GPIOF, GPIO_Pin_7);
  30.           LCD_EN_Clr();
  31.         }while(sta & 0x80);
  32. }
  33. void LCD1602_Write_Cmd(uint8_t cmd) //寫入指令
  34. {
  35.         LCD1602_Wait_Ready();
  36.         LCD_RS_Clr();
  37.         LCD_RW_Clr();
  38.         DATAOUT(cmd);
  39.         LCD_EN_Set();
  40.         LCD_EN_Clr();
  41. }
  42.
  43. void LCD1602_Write_Dat(uint8_t dat) //寫入數(shù)據(jù)
  44. {
  45.   LCD1602_Wait_Ready();
  46.   LCD_RS_Set();
  47.         LCD_RW_Clr();
  48.   DATAOUT(dat);
  49.         LCD_EN_Set();
  50.         LCD_EN_Clr();
  51. }
  52. void LCD1602_ClearScreen(void) //清屏
  53. {
  54.   LCD1602_Write_Cmd(Cmd_Clear);
  55. }
  56. void LCD1602_Set_Cursor(uint8_t x, uint8_t y) //設(shè)置光標(biāo),字符顯示的地址(x是列,y是行)
  57. {
  58.   u8 addr; //地址變量
  59.         if (y == 0)
  60.         {
  61.           addr = 0x00 + x;
  62.         }
  63.         else
  64.         {
  65.                 addr = 0x40 + x;
  66.         }
  67.         LCD1602_Write_Cmd(addr | 0x80); //這里|上0x80是因為在寫入顯示地址時LCD的D7位必須恒定為1
  68. }
  69. void LCD1602_Show_Str(uint8_t x, uint8_t y, uint8_t *str)
  70. {
  71.   LCD1602_Set_Cursor(x, y);
  72.         while(*str != '\0')
  73.         {
  74.     LCD1602_Write_Dat(*str++);
  75.         }
  76. }
  77. void LCD1602_Init(void)
  78. {
  79.                 GPIO_Configuration();
  80.                 LCD1602_Write_Cmd(0x38);                //LCD初始化設(shè)置(下同)
  81.                 LCD1602_Write_Cmd(0x0c);
  82.                 LCD1602_Write_Cmd(0x06);
  83.                 LCD1602_Write_Cmd(0x01);
  84. }
代碼見附件 Roy_STM32F103_LCD1602.7z (177.22 KB, 下載次數(shù): 213)
參與人數(shù) 1黑幣 +50 收起 理由
ID:705222 發(fā)表于 2020-3-30 17:31 來自觸屏版 | 顯示全部樓層
我的為什么亂碼了,和v0腳接地有關(guān)嗎
ID:707140 發(fā)表于 2020-3-31 18:23 | 顯示全部樓層
小新呀 發(fā)表于 2020-3-30 17:31
你是f103c8t6的嘛????
ID:251662 發(fā)表于 2020-8-7 14:03 | 顯示全部樓層
你好樓主,這個 D0-D7為什么沒有宏定義,不能更改IO嗎??
ID:251662 發(fā)表于 2020-8-7 14:05 | 顯示全部樓層
?????D0-D7宏定義呢?????
ID:251662 發(fā)表于 2020-8-7 14:08 | 顯示全部樓層
huzheng11 發(fā)表于 2020-3-31 18:23
你是f103c8t6的嘛????
你試過了嗎。我看了一下程序D0-D7沒有定義,要瘋了
ID:695711 發(fā)表于 2020-11-2 17:48 | 顯示全部樓層
海子的孩子333 發(fā)表于 2020-8-7 14:08
抱歉,學(xué)業(yè)繁忙,一直沒有時間來論壇,D0-D7確實(shí)沒有宏定義,但也確實(shí)有,只是因為我接的是GPIOF的0-7腳,所以并沒有用宏定義單個進(jìn)行定義,而是用了GPIO_Write()這個庫函數(shù)直接對GPIOF0-7腳進(jìn)行操作,你可以看一下LCD1602.h 的頭文件里有一個宏定義:#define        DATAOUT(x)          GPIO_Write(GPIOF, x) //對D0-D7進(jìn)行操作
參與人數(shù) 1黑幣 +20 收起 理由
admin + 20 回帖助人的獎勵!
ID:831898 發(fā)表于 2020-11-2 21:32 | 顯示全部樓層
報錯,C程序里面怎么有匯編語言
