查看: 2119|回復: 2
利用ds302的時候,用數碼管顯示,數碼管顯示不正常
以下為源程序:
#include<reg52.h>
#include<intrins.h>
sbit SCK=P1^7;
sbit SDA=P2^3;
sbit RST=P1^3;
unsigned char we[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
unsigned char duan[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};
/*單字節寫入一字節數據*/
void Write_Ds1302_Byte(unsigned char dat)
unsigned char i;
SCK = 0;
for (i=0;i<8;i++)
  if (dat & 0x01)  // 等價于if((addr & 0x01) ==1)
   SDA=1;
   SDA=0;
  SCK=1;
  SCK=0;
  dat = dat >> 1;
/*單字節讀出一字節數據*/
unsigned char Read_Ds1302_Byte(void)
unsigned char i, dat=0;
for (i=0;i<8;i++)
  dat = dat >> 1;
  if (SDA)
   dat |= 0x80;
   dat &= 0x7F;
  SCK=1;
  SCK=0;
return dat;
/*向DS1302 單字節寫入一字節數據*/
void Ds1302_Single_Byte_Write(unsigned char addr, unsigned char dat)
RST=0;   /*RST腳置低,實現DS1302的初始化*/
SCK=0;   /*SCK腳置低,實現DS1302的初始化*/
RST=1;   /*啟動DS1302總線,RST=1電平置高 */
Write_Ds1302_Byte(addr); /*寫入目標地址:addr,保證是寫操作,寫之前將最低位置零*/
Write_Ds1302_Byte(dat);  /*寫入數據:dat*/
RST=0;     /*停止DS1302總線*/
/*從DS1302單字節讀出一字節數據*/
unsigned char Ds1302_Single_Byte_Read(unsigned char addr)
unsigned char temp;
Write_Ds1302_Byte(addr); /*寫入目標地址:addr,保證是讀操作,寫之前將最低位置高*/
temp=Read_Ds1302_Byte(); /*從DS1302中讀出一個字節的數據*/
return temp;
unsigned char dat_bcd(date)
unsigned char dat1,dat2;
dat1=date/10;
dat2=date%10;
dat2=dat2+dat1*16;
return dat2;
unsigned char bcd_dat(date)
dat1=date/16;
dat2=date%16;
dat2=dat2+dat1*10;
return dat2;
void Delay1ms()  //@11.0592MHz
unsigned char i, j;
_nop_();
i = 2;
j = 199;
do
  while (--j);
} while (--i);
void display(unsigned char sec,unsigned char min,unsigned char hour)
P2=0xc0;P0=we[0];P2=0x00;P2=0xe0;P0=~duan[hour/10];P2=0x00;Delay1ms();
P2=0xc0;P0=we[1];P2=0x00;P2=0xe0;P0=~duan[hour%10];P2=0x00;Delay1ms();
P2=0xc0;P0=we[2];P2=0x00;P2=0xe0;P0=0xff;P2=0x00;Delay1ms();
P2=0xc0;P0=we[3];P2=0x00;P0 = 0xff;P2=0xe0;P0=~duan[min/10];P2=0x00;Delay1ms();
P2=0xc0;P0=we[4];P2=0x00;P0 = 0xff;P2=0xe0;P0=~duan[min%10];P2=0x00;Delay1ms();
P2=0xc0;P0=we[5];P2=0x00;P2=0xe0;P0=0xff;P2=0x00;Delay1ms();
P2=0xc0;P0=we[6];P2=0x00;P0 = 0xff;P2=0xe0;P0=~duan[sec/10];P2=0x00;Delay1ms();
P2=0xc0;P0=we[7];P2=0x00;P0 = 0xff;P2=0xe0;P0=~duan[sec%10];P2=0x00;Delay1ms();
unsigned char sec,min,hour;
Ds1302_Single_Byte_Write(0x8e,0x00);
Ds1302_Single_Byte_Write(0x80,dat_bcd(45));//秒
Ds1302_Single_Byte_Write(0x82,dat_bcd(49));//分
Ds1302_Single_Byte_Write(0x84,dat_bcd(16));//時
Ds1302_Single_Byte_Write(0x8e,0x80);
  sec=bcd_dat(Ds1302_Single_Byte_Read(0x81));
  min=bcd_dat(Ds1302_Single_Byte_Read(0x83));
  hour=bcd_dat(Ds1302_Single_Byte_Read(0x85));
  display(sec,min,hour);
ID:213173 發表于 2020-2-20 07:10 | 只看該作者
樓主沒有提供硬件電路,不易準確判斷問題所在,但有一點可以看出ds1302的SDA使用了P2.3,數碼管段碼和位碼鎖存器的使能端使用了P2的某兩個端口。在顯示程序中明顯看出樓主對P2操作不當。
ID:627807 發表于 2020-2-20 10:43 | 只看該作者
wulin 發表于 2020-2-20 07:10
樓主沒有提供硬件電路,不易準確判斷問題所在,但有一點可以看出ds1302的SDA使用了P2.3,數碼管段碼和位碼 ...
請問能和否告訴我哪里錯了呢,百思不得其解
