查看: 6823|回復: 4
proteus仿真stm32 pwm出現unclocked peripheral的錯誤
ID:402264 發表于 2020-2-17 18:01 | 顯示全部樓層 |閱讀模式
想使用Proteus仿真Stm32 PWM實現呼吸燈的效果,結果提示外設沒有開啟時鐘的錯誤,不知道怎么回事。下面時PWM_Init的代碼:
void PWM_Init(Int16U arr,Int16U psc)
        GPIO_InitTypeDef GPIO_InitStructure;//??GPIO???
        TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; //??TIMx??????
        TIM_OCInitTypeDef TIM_OCInitStructure;//????????????
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1,ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
        GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3,ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOB,&GPIO_InitStructure);
        TIM_TimeBaseStructure.TIM_Period = arr;
        TIM_TimeBaseStructure.TIM_Prescaler = psc;
        TIM_TimeBaseStructure.TIM_ClockDivision = 0;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM3,&TIM_TimeBaseStructure);
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
        TIM_OC2Init(TIM3,&TIM_OCInitStructure);
        TIM_OC2PreloadConfig(TIM3,TIM_OCPreload_Enable);
        TIM_Cmd(TIM3, ENABLE);
Proteus的提示:
Access to register of unclocked peripheral at 0x40000400 cause BUS_FAULT [U1_CM3CORE]
Proteus的圖;
ID:402264 發表于 2020-2-17 18:13 | 顯示全部樓層
如果把C組端口的APB2時鐘也打開的話,就不會出現這個問題了,只是還沒搞懂為什么
ID:402264 發表于 2020-2-18 11:53 | 顯示全部樓層
如果是在Proteus上仿真要把TIM1的APB2時鐘也要打開,不然會出現下面這樣的錯誤提示
ID:737501 發表于 2020-4-27 17:52 | 顯示全部樓層
設置單片機的晶振頻率8.0M或者12.0M就可以實現了,也不用開啟時鐘了,我覺的開啟時鐘就是相當于設置晶振吧。
ID:1065911 發表于 2023-3-13 16:57 | 顯示全部樓層
為什么我C組端口的APB2時鐘打開了,TIM1的APB2時鐘也開了,晶振頻率也試了8M和12M,但還是這樣報錯
