查看: 4058|回復: 1
arduino小型體重稱hx711程序
ID:431677 發表于 2020-2-16 15:57 | 顯示全部樓層 |閱讀模式
ardino制作,簡單體重計,使用壓力傳感器,通過公式轉換,串口顯示數據。
  1. #include "hx711.h"
  2. #define ValueGap 630
  3. //該數值可用砝碼校準
  4. long HX711_Buffer = 0;
  5. long Weight_Maopi = 0,Weight_Shiwu = 0;
  6. //****************************************************
  7. //初始化HX711
  8. //****************************************************
  9. void Init_Hx711()
  10. {
  11.         pinMode(HX711_SCK, OUTPUT);
  12.         pinMode(HX711_DT, INPUT);
  13. }
  14. //****************************************************
  15. //獲取毛皮重量
  16. //****************************************************
  17. void Get_Maopi()
  18. {
  19.         Weight_Maopi = HX711_Read();
  20. }
  21. //****************************************************
  22. //稱重
  23. //****************************************************
  24. unsigned int Get_Weight()
  25. {
  26.         HX711_Buffer = HX711_Read();
  27.         Weight_Shiwu = HX711_Buffer;
  28.         Weight_Shiwu = Weight_Shiwu - Weight_Maopi;                                //獲取實物的AD采樣數值。
  29.
  30.         Weight_Shiwu = (int)((float)Weight_Shiwu/ValueGap+0.05);
  31.         return Weight_Shiwu;
  32. }
  33. //****************************************************
  34. //讀取HX711
  35. //****************************************************
  36. unsigned long HX711_Read(void)        //增益128
  37. {
  38.         unsigned long count;
  39.         unsigned char i;
  40.         bool Flag = 0;
  41.         digitalWrite(HX711_DT, HIGH);
  42.         delayMicroseconds(1);
  43.         digitalWrite(HX711_SCK, LOW);
  44.         delayMicroseconds(1);
  45.           count=0;
  46.           while(digitalRead(HX711_DT));
  47.           for(i=0;i<24;i++)
  48.         {
  49.                   digitalWrite(HX711_SCK, HIGH);
  50.                 delayMicroseconds(1);
  51.                   count=count<<1;
  52.                 digitalWrite(HX711_SCK, LOW);
  53.                 delayMicroseconds(1);
  54.                   if(digitalRead(HX711_DT))
  55.                         count++;
  56.         }
  57.         digitalWrite(HX711_SCK, HIGH);
  58.         delayMicroseconds(1);
  59.         digitalWrite(HX711_SCK, LOW);
  60.         delayMicroseconds(1);
  61.         count ^= 0x800000;
  62.         return(count);
  63. }
體重秤.zip
4.28 KB, 下載次數: 18, 下載積分: 黑幣 -5
ID:356403 發表于 2020-5-11 20:26 | 顯示全部樓層
怎么校準
