查看: 2253|回復: 2
STC單片機怎樣才能進行動態內存申請?
我今天做一個STC12C5A60S2單片機的動態內存申請程序:
#include"STC12C5A60S2.H"
#include"STDLIB.H"
#include"STRING.H"
#define ON_LCD 0x0C
#define OFF_LCD 0x08
#define CLEAR_LCD 0x01
#define INPUT_MODE 0x06
#define TEXT_SIZE 0x38     //8位,2行,5*7點陣
sbit RS=P2^5;
sbit RW=P2^6;
sbit E=P2^7;
sbit Back_Light=P4^5;
sbit feleer=P2^0;              //探針
unsigned char code Text[]="DRAM_ASK_TEST";
unsigned char code Date[]="2020-02-11";
void Init_LCD();
void Display(unsigned char *ptr,unsigned char x,unsigned char y);
void Set_xy(unsigned char  x,unsigned char y);
void Wcom(unsigned char com);
void WDat(unsigned char Dat);
void Ready();
   unsigned char xdata *Area;
   P4SW=0xFF;
   Back_Light=0;
   Init_LCD();
   init_mempool(0x200,14);
   Area=(unsigned char *)malloc(14*sizeof(unsigned char));
   if(Area==NULL)
      feleer=0;
      while(1);
   strcpy(Area,Text);
   Display(Area,2,1);
   Display(Date,3,2);
   free(Area);
   while(1);
void Init_LCD()
   Wcom(OFF_LCD);
   Wcom(CLEAR_LCD);
   Wcom(INPUT_MODE);
   Wcom(ON_LCD);
   Wcom(TEXT_SIZE);
   Set_xy(x,y);
   while(*ptr!=0)
      WDat(*ptr);
          ptr++;
   if(y==1)
      Wcom(0x80|x);
   if(y==2)
      Wcom(0xC0|x);
   Ready();
   RS=0;
   RW=0;
   E=1;
   P0=com;
   E=0;
   Ready();
   RS=1;
   RW=0;
   E=1;
   P0=Dat;
   E=0;
void Ready()
   unsigned char sta;
   P0=0xFF;
   RS=0;
   RW=1;
   do
      E=1;
      sta=P0;
      E=0;
   while(sta&0x80);
調試了一下午好多問題都解決了,就是下面這個警告還在,1602沒顯示,我的書本沒有initreg()這個庫函數的說明,網上也沒見有,(有都是說C++的),想問一下用過這種功能的師傅,怎樣才能消除這個警告?
收藏收藏2 分享淘帖 頂 踩
ID:258566 發表于 2020-2-12 13:50 | 只看該作者
沒警告啊,9.59 測試過。
ID:113199 發表于 2020-2-12 17:29 | 只看該作者
刪掉啟動文件后我也通過了
