查看: 2994|回復(fù): 3
51單片機+K9F2080U0A制作MP3電路圖與源程序
ID:691549 發(fā)表于 2020-2-10 01:31 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
51單片機作MP3
步驟很詳細(xì)奧
PLAY鍵播放音樂
FUNC用于在樂取選擇、音量控制、音效控制間切換
PREVIOUS,選取時下一首,音量控制時為減小音量,音效控制時為下一音效
PREVIOUS,選取時上一首,音量控制時為增大音量,音效控制時為上一音效
電路原理圖如下:
  1. /*C**************************************************************************
  2. * NAME:         main.c
  3. *----------------------------------------------------------------------------
  4. * Copyright (c) 2003 Atmel.
  5. *----------------------------------------------------------------------------
  6. * RELEASE:      snd1c-refd-nf-4_0_3
  7. * REVISION:     1.6
  8. *----------------------------------------------------------------------------
  9. * PURPOSE:
  10. * This is the demonstration software for T8xC51SND1
  11. *****************************************************************************/
  12. /*_____ I N C L U D E S ____________________________________________________*/
  13. #include "config.h"                         /* system definition */
  14. #include "lib_mcu\c51_drv.h"                /* c51 driver definition */
  15. #include "scheduler.h"                      /* scheduler definition */
  16. /*_____ M A C R O S ________________________________________________________*/
  17. /*_____ D E F I N I T I O N ________________________________________________*/
  18. Byte code __FIRMWARE_VERSION_STRING[]="@(#) Firmware snd1c-refd-nf-4_0_3 - Atmel Chejudo Player Reference Design\15\12\0$Id: main.c,v 1.6 2002/12/20 12:51:12 ffosse Exp $";
  19. /*_____ D E C L A R A T I O N ______________________________________________*/
  20. extern  void    in_system_prog (void);
  21. static  void    main (void);
  22. /*F**************************************************************************
  23. * NAME: main
  24. *----------------------------------------------------------------------------
  25. * PARAMS:
  26. *
  27. * return:
  28. *----------------------------------------------------------------------------
  29. * PURPOSE:
  30. *   Main user routine
  31. *----------------------------------------------------------------------------
  32. * EXAMPLE:
  33. *----------------------------------------------------------------------------
  34. * NOTE:
  35. *----------------------------------------------------------------------------
  36. * REQUIREMENTS:
  37. *****************************************************************************/
  38. void main (void)
  39. {
  40.   in_system_prog();                         /* check ISP execution request */
  41.   Enable_interrupt();                       /* global enable */
  42.   #ifdef X2_MODE
  43.   Set_x2_mode();
  44.   #endif
  45.   sch_scheduler_init();
  46.
  47.   sch_scheduler();                          /* endless scheduler execution */
  48. }
51單片機作MP3.rar (1.22 MB, 下載次數(shù): 31)
參與人數(shù) 1黑幣 +50 收起 理由
收藏收藏2 分享淘帖 頂 踩
ID:284488 發(fā)表于 2020-2-10 09:22 | 只看該作者
謝謝樓主分享
ID:298008 發(fā)表于 2020-2-10 10:54 | 只看該作者
謝謝樓主分享!!!
ID:336378 發(fā)表于 2021-4-2 18:13 | 只看該作者
     這資料牛逼,可是我還是看不懂是什么原理。
