宅在家里仿個(gè)VFD數(shù)字時(shí)鐘,程序運(yùn)行后,秒滿六十進(jìn)位到時(shí)位,中間間隔分為始終為零。源程序就是這個(gè)論壇里的,修改步驟詳見注釋。請(qǐng)走過路過的幫忙看看,是哪不對(duì)?(原程序vfd_wrtime ()里就是秒位進(jìn)時(shí)位)
20200209 修改來自51hei http://m.raoushi.com/bbs/dpj-43390-1.html "基于89S52的16312VFD顯示程序"
本人硬件:MCU:STC12C5616AD、
修改:1.STB、CLK、DIN;
2.按VFD重新編碼0~9;
3.按PT6312這是顯示模式、數(shù)據(jù)模式設(shè)置;
4.按VFD實(shí)際屏蔽G6(是VFD屏下部分漢字,如:多謝惠顧等);
5.10_8_VFD的G1在右側(cè)端頭,G5是左側(cè)端頭,在void vfd_wrtime ()里調(diào)過來
6.去掉秒、分個(gè)位、十位之間的空格,在分秒之間加一橫0x08
7.屏蔽vfd_wrdata ( g11[ i] );vfd_wrdata ( g12[ ] );
增加vfd_wrdata ( vfdbuf[2] ); vfd_wrdata ( vfdbuf[3] );
- #include"reg51.h"
- #include "stdio.h"
- #define uint unsigned int
- #define uchar unsigned char
- sbit DIN = P1^4;
- sbit CLK = P3^1;
- sbit STB = P1^7;
- void vfd_cmd (unsigned char vfd_cmd0); /* 寫命令*/
- void vfd_wrdata (unsigned char vfd_wrdata0); /* 寫數(shù)據(jù) */
- void vfd_init (void); /* PT6312初始化 */
- unsigned char vfdbuf[]={0,0,0,0,21,8};
- code unsigned char vfdmap[]=
- 0x77,0x60,0x5d,0x7c,0x6a,0x3e,0x3f,0x70,0x7f,0x7e
- }; //原程序:0xf7, 0xa4, 0xeb,0xed, 0xbc, 0xdd, 0xdf, 0xe4, 0xff, 0xfd
- unsigned char
- g11[]={0x64,0x89,0x32,0x64,0xa9,0x32,0x64,0xa9,0x32};
- unsigned char
- g12[]={0x26,0x48,0x91,0x26,0x48,0x01,0x02,0x00,0x91};
- //unsigned char g21[]={0xff,0x13,0x13,0x13,0x13,0x13,0x13,0x13,0x00};
- //unsigned char g22[]={0xff,0x40,0x00,0x00,0x80,0x00,0x00,0x00,0x00};
- //unsigned char g31[]={0xff,0x77,0x77,0x77,0x77,0x77,0x77,0x77,0x00};
- //unsigned char g32[]={0xff,0x10,0x00,0x10,0x00,0x10,0x00,0x10,0x10};
- //unsigned char g41[]={0xff,0x7e,0x7e,0x7e,0x7e,0x7e,0x7e,0x7e,0x00};
- //unsigned char g42[]={0xff,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
- //unsigned char g51[]={0xff,0x2f,0x2f,0x2f,0x2f,0x2f,0x2f,0x2f,0x00};
- //unsigned char g52[]={0xff,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
- /***********屏蔽G6****
- unsigned char
- g61[]={0xff,0x02,0x04,0x08,0x10,0x00,0x00,0x00,0x00};
- unsigned char
- g62[]={0xff,0x00,0x00,0x00,0x00,0x10,0x20,0x40,0x80};
- void delay(unsigned char cnt)
- unsigned char i;
- while(cnt--!=0)
- for(i=100;i!=0;i--);
- #define tick 7554
- #define T100us (256-134)
- unsigned char hour, minute, second;
- unsigned int c100us;
- void vfd_cmd ( unsigned char vfd_cmd0 ) /* 寫控制命令子程序 */
- unsigned char i;
- STB=1;
- CLK=1;
- for ( i=0;i<8;i++ )
- STB=0;
- CLK=0;
- DIN = vfd_cmd0&0x01;
- CLK=1;
- vfd_cmd0>>=1;
- STB=1;
- CLK=1;
- void vfd_wrdata ( unsigned char vfd_wrdata0 ) /* 寫數(shù)據(jù)子程序 */
- unsigned char i;
- for(i=0;i<8;i++)
- CLK=1;
- STB=0;
- CLK=0;
- DIN=vfd_wrdata0&0x01;
- CLK=1;
- vfd_wrdata0>>=1;
- STB=0;
- CLK=1;
- void vfd_init(void)
- vfd_cmd ( 0x02 ); /* 6digits,16segments顯示模式 原程序0x3a */
- vfd_cmd ( 0x40 ); /* 顯示正常模式,數(shù)據(jù)地址遞增 原程序0x70*/
- vfd_wrdata ( 0xc0 ); /* 設(shè)置地址從00H開始 */
- void timer0() interrupt 1
- c100us--;
- if(c100us==0)
- c100us=tick;
- second++;
- if(second==60)
- second=0;
- minute++;
- if(minute==60);
- minute=0;
- hour++;
- if(hour==24)
- hour=0;
- void vfd_wrtime ()
- unsigned int i;
- vfdbuf[0]=vfdmap[second%10]; //原程序hour/10
- vfdbuf[1]=vfdmap[second/10]; //原程序hour%10
- vfdbuf[2]=vfdmap[minute%10]; //原程序minute/10
- vfdbuf[3]=vfdmap[minute/10]; //原程序minute%10
- vfdbuf[4]=vfdmap[hour%10]; //原程序second/10
- vfdbuf[5]=vfdmap[hour/10]; //原程序second%10
- vfd_init( );
- i=0;
- //vfd_wrdata ( g11[i] ); //原程序0x64
- //vfd_wrdata ( g12[i] ); //原程序0x26
- vfd_wrdata ( vfdbuf[0] ); //2G 秒的十位
- //vfd_wrdata ( 0x00 );
- vfd_wrdata ( vfdbuf[1] ); //3G 秒的個(gè)位
- vfd_wrdata ( 0x08 ); //新增分秒之間一杠
- vfd_wrdata ( vfdbuf[2] ); //一下三句新增
- vfd_wrdata ( vfdbuf[3] );
- vfd_wrdata ( vfdbuf[4] ); //4G 時(shí)的個(gè)位
- vfd_wrdata ( vfdbuf[5] ); //5G 時(shí)的十位
- //vfd_wrdata ( g61[i] ); //6G 屏蔽G6
- //vfd_wrdata ( g62[i] );
- i++;
- STB=1;
- delay(1000);
- vfd_cmd ( 0x89 ); /* 顯示開,14/16脈寬*/
