查看: 2168|回復: 5
求助,寫的單片機按鍵矩陣不能實現功能
      寫的是用定時器掃描矩陣按鍵,然后在數碼管顯示,可是代碼不能實現功能,檢查了幾遍也沒想明白哪里出錯了,單片機小白,求助
  1. #include "reg52.h"
  2. #include "intrins.h"
  3. void anjian();
  4. unsigned int a,b;
  5. sbit KEY_IN1 = P3^7;
  6. sbit KEY_IN2 = P3^6;
  7. sbit KEY_IN3 = P3^5;
  8. sbit KEY_IN4 = P3^4;
  9. sbit KEY_OUT1 = P3^0;
  10. sbit KEY_OUT2 = P3^1;
  11. sbit KEY_OUT3 = P3^2;
  12. sbit KEY_OUT4 = P3^3;
  13. unsigned char code pucseg_code[] = {
  14.         0xc0, 0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8,
  15.         0x80, 0x90, 0x88, 0x83, 0xc6, 0xa1, 0x86, 0x8e
  16. };  //數碼管顯示段碼
  17. /*unsigned char ledbuff[8] = {
  18.         0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff
  19. };*/
  20. unsigned char keysta[4][4] = {
  21.         {1, 1, 1, 1}, {1, 1, 1, 1}, {1, 1, 1, 1}, {1, 1, 1, 1}
  22. };   //矩陣按鍵當前狀態
  23. void Delay1ms()                //@12.000MHz
  24. {
  25.         unsigned char i, j;
  26.         i = 12;
  27.         j = 169;
  28.         do
  29.         {
  30.                 while (--j);
  31.         } while (--i);
  32. }
  33. void Delay300us()                //@12.000MHz
  34. {
  35.         unsigned char i, j;
  36.         i = 4;
  37.         j = 125;
  38.         do
  39.         {
  40.                 while (--j);
  41.         } while (--i);
  42. }
  43. void cls_periphercal(void)                //系統初始化
  44. {
  45.         P0 = 0xff;
  46.         P2 = P2 & 0x1f | 0x80;
  47.         P2 = 0x1f;
  48.         P0 = 0;
  49.         P2 = P2 & 0x1f | 0xa0;
  50.         P2 = 0x1f;
  51.
  52.
  53. }
  54. void seg_disp(unsigned char pu, unsigned char ucseg_pos)   //數碼管段選
  55. {
  56.         P0 = 0xff;
  57.         P2 = P2 & 0x1f | 0xe0;
  58.         P2 &= 0x1f;
  59.         Delay300us();
  60.
  61.         P0 = 0x80 >> ucseg_pos;
  62.         P2 = P2 & 0x1f | 0xc0;
  63.         P2 &= 0x1f;
  64.         Delay300us();
  65.
  66.         P0 = pu;
  67.         P2 = P2 & 0x1f | 0xe0;
  68.         P2 &= 0x1f;
  69.         Delay300us();
  70. }
  71. void saomiao(unsigned char i)   //數碼管循環刷新顯示
  72. {
  73.         switch(i)
  74.         {
  75.                 case 0: seg_disp(pucseg_code[0], 0); break;
  76.                 case 1: seg_disp(pucseg_code[1], 1); break;
  77.                 case 2: seg_disp(pucseg_code[2], 2); break;
  78.                 case 3: seg_disp(pucseg_code[3], 3); break;
  79.                 case 4: seg_disp(pucseg_code[4], 4); break;
  80.                 case 5: seg_disp(pucseg_code[5], 5); break;
  81.                 case 6: seg_disp(pucseg_code[6], 6); break;
  82.                 case 7: seg_disp(pucseg_code[7], 7); break;
  83.         }
  84.
  85. }
  86. /*void Timer0Init(void)                //2??@12.000MHz   //定時器定時2ms
  87. {
  88.         AUXR |= 0x80;                //?????1T??
  89.         TMOD &= 0xF0;                //???????
  90.         TL0 = 0x40;                //??????
  91.         TH0 = 0xA2;                //??????
  92.         TF0 = 0;                //??TF0??
  93.         TR0 = 1;                //???0????
  94.         ET0 = 1;
  95.         EA = 1;
  96. }*/
  97. void InterruptTimer0() interrupt 1
  98. {
  99.         unsigned char i;
  100.         static unsigned char keyout = 0;       //輸出索引值
  101.         static unsigned char keybuf[4][4] = {  //掃描緩沖數組
  102.         {0xff, 0xff, 0xff, 0xff}, {0xff, 0xff, 0xff, 0xff},
  103.         {0xff, 0xff, 0xff, 0xff}, {0xff, 0xff, 0xff, 0xff}
  104.         };
  105.         TH0 = 0XFC;
  106.         TL0 = 0X67;
  107.
  108.
  109.         keybuf[keyout][0] = (keybuf[keyout][0] << 1) | P3^7;
  110.         keybuf[keyout][0] = (keybuf[keyout][0] << 1) | P3^6;
  111.         keybuf[keyout][0] = (keybuf[keyout][0] << 1) | P3^5;
  112.         keybuf[keyout][0] = (keybuf[keyout][0] << 1) | P3^4;
  113.
  114.         for(i=0; i<4; i++)
  115.         {
  116.                 if((keybuf[keyout][i] & 0x0f) == 0x00)
  117.                         keysta[keyout][i] = 0;      //連續掃描四次4值為0,可以認為按鍵已經穩定按下或彈起
  118.                 else if((keybuf[keyout][i] & 0x0f) == 0x0f)
  119.                         keysta[keyout][i] = 1;
  120.         }
  121.
  122.         keyout++;                     //索引值遞增
  123.         keyout = keyout & 0x03;       //當索引值到4時歸零
  124.         switch(keyout)          //根據索引值,釋放當前輸出引腳,拉低下次輸出引腳
  125.         {
  126.                 case 0 : KEY_OUT4 = 1; KEY_OUT1 = 0; break;
  127.                 case 1 : KEY_OUT1 = 1; KEY_OUT2 = 0; break;
  128.                 case 2 : KEY_OUT2 = 1; KEY_OUT3 = 0; break;
  129.                 case 3 : KEY_OUT3 = 1; KEY_OUT4 = 0; break;
  130.                 default: break;
  131.         }
  132. }
  133. void anjian(void)                //判斷按鍵按下的是哪一位
  134. {
  135.                                         if(b == 0 & a == 0)
  136.                                                 {
  137.                                                         saomiao(0);
  138.                                                         Delay1ms();
  139.                                                 }
  140.                                                 else if(b == 1 & a == 0)
  141.                                                 {
  142.                                                         saomiao(1);
  143.                                                         Delay1ms();
  144.                                                 }
  145.                                                 else if(b == 2 & a == 0)
  146.                                                 {
  147.                                                         saomiao(2);
  148.                                                         Delay1ms();
  149.                                                 }
  150.                                                 else if(b == 3 & a == 0)
  151.                                                 {
  152.                                                         saomiao(3);
  153.                                                         Delay1ms();
  154.                                                 }
  155.                                                 else if(b == 0 & a == 1)
  156.                                                 {
  157.                                                         saomiao(4);
  158.                                                         Delay1ms();
  159.                                                 }
  160.                                                 else if(b == 1 & a == 1)
  161.                                                 {
  162.                                                         saomiao(5);
  163.                                                         Delay1ms();
  164.                                                 }
  165.                                                 else if(b == 2 & a == 1)
  166.                                                 {
  167.                                                         saomiao(6);
  168.                                                         Delay1ms();
  169.                                                 }
  170.                                                 else if(b == 3 & a == 1)
  171.                                                 {
  172.                                                         saomiao(7);
  173.                                                         Delay1ms();
  174.                                                 }
  175.                                                 else if(b == 0 & a == 2)
  176.                                                 {
  177.                                                         saomiao(8);
  178.                                                         Delay1ms();
  179.                                                 }
  180.                                                 else if(b == 1 & a == 2)
  181.                                                 {
  182.                                                         saomiao(9);
  183.                                                         Delay1ms();
  184.                                                 }
  185. }
  186. void main(void)
  187. {
  188.         unsigned char backup[4][4] = {
  189.         {1, 1, 1, 1}, {1, 1, 1, 1}, {1, 1, 1, 1}, {1, 1, 1, 1}
  190.         };   //按鍵掃描值備份
  191.
  192.         EA = 1;
  193.         //ENLED = 0;
  194.         TMOD = 0X01;
  195.         TH0 = 0XFC;
  196.         TL0 = 0X67;
  197.         ET0 = 1;
  198.         TR0 = 1;
  199.         saomiao(0);
  200.
  201.         cls_periphercal();
  202.         Timer0Init();
  203.         while(1)
  204.         {
  205.                 for(a=0; a<4; a++)
  206.                 {
  207.                         for(b=0; b<4; b++)
  208.                         {
  209.                                 if(backup[a][b] != keysta[a][b])
  210.                                 {
  211.                                         if(backup[a][b] != 0)
  212.                                         {
  213.                                                 //anjian();
  214.                                                 saomiao(7);
  215.                                                 Delay1ms();
  216.                                                 Delay1ms();
  217.                                                 Delay1ms();
  218.                                                 Delay1ms();
  219.                                                 Delay1ms();
  220.                                                 Delay1ms();
  221.                                         }
  222.                                         backup[a][b] = keysta[a][b];
  223.                                 }
  224.                         }
  225.                 }
  226.         }
  227. }
ID:376790 發表于 2020-1-17 16:44 | 只看該作者
求助
ID:473159 發表于 2020-1-17 20:08 | 只看該作者
一個一個按鍵的調試,屏蔽其他按鍵,先調通一個,后面就會照做就OK!
ID:213173 發表于 2020-1-17 22:12 | 只看該作者
樓主這是從哪里東拼西湊來的代碼,只是用數碼管顯示矩陣按鍵鍵值的簡單程序,竟然洋洋灑灑幾百條代碼。給你簡化一下經仿真無誤。
  3. #define uint unsigned int
  5. uchar code pucseg_code[] = {//段碼
  6.         0xc0, 0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8,
  7.         0x80, 0x90, 0x88, 0x83, 0xc6, 0xa1, 0x86, 0x8e};
  8. uchar code weia[] = {0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};//位碼
  9. uchar data dis_buf[8];//顯示緩存
  10. uchar key=0;                                        //定義鍵值全局變量
  11. void anjian()                                        //按鍵掃描程序
  12. {
  13.         static bit sign=0;                        //按鍵有效標志
  14.         static uchar count=0;                //消抖計數變量
  15.         uchar num=0;                                //臨時變量
  16.         P3=0xf0;                                        //賦值P3 1111 0000
  17.         if(P3!=0xf0)                                //檢測有按鍵按下
  18.         {
  19.                 count++;                                //消抖計數
  20.                 if((count>=10)&&(sign==0))
  21.                 {
  22.                         sign=1;                                //按鍵有效標志置1
  23.                         num=P3;                                //保存P3值xxxx 0000,x為0或1
  24.                         num|=0x0f;                        //保存num按位或0x0f值xxxx 1111
  25.                         P3=num;                                //賦值P3 xxxx 1111
  26.                         switch(P3)
  27.                         {
  28.                                 case 0xee: key= 1; break;
  29.                                 case 0xde: key= 2; break;
  30.                                 case 0xbe: key= 3; break;
  31.                                 case 0x7e: key= 4; break;
  32.                                 case 0xed: key= 5; break;
  33.                                 case 0xdd: key= 6; break;
  34.                                 case 0xbd: key= 7; break;
  35.                                 case 0x7d: key= 8; break;
  36.                                 case 0xeb: key= 9; break;
  37.                                 case 0xdb: key=10; break;
  38.                                 case 0xbb: key=11; break;
  39.                                 case 0x7b: key=12; break;
  40.                                 case 0xe7: key=13; break;
  41.                                 case 0xd7: key=14; break;
  42.                                 case 0xb7: key=15; break;
  43.                                 case 0x77: key=16; break;
  44.                         }
  45.                 }
  46.         }
  47.         else                                                //鍵抬起
  48.         {
  49.                 sign=0;                                        //按鍵有效標志清0
  50.                 count=0;                                //消抖計數清0
  51.         }
  52. }
  53. void saomiao()//共陽數碼管循環刷新顯示
  54. {
  55.         static bit i=0;
  56.         if(i)
  57.                 dis_buf[0]=pucseg_code[key%10];
  58.         else
  59.                 dis_buf[1]=pucseg_code[key/10];
  60.         P0=0xff;//消隱
  61.         P2=weia[i];
  62.         P0=dis_buf[i];
  63.         i=~i;
  64. }
  65. void main()                                                //主函數
  66. {
  67.         TMOD = 0X01;//1ms
  68.         TH0 = 0XFC;
  69.         TL0 = 0X67;
  70.         EA = 1;
  71.         ET0 = 1;
  72.         TR0 = 1;
  73.         while(1);
  74. }
  75. void InterruptTimer0() interrupt 1
  76. {
  77.         TH0 = 0XFC;
  78.         TL0 = 0X67;
  79.         anjian();        //按鍵掃描程序
  80.         saomiao();  //共陽數碼管顯示程序
  81. }
ID:376790 發表于 2020-1-18 14:22 | 只看該作者
wulin 發表于 2020-1-17 22:12
樓主這是從哪里東拼西湊來的代碼,只是用數碼管顯示矩陣按鍵鍵值的簡單程序,竟然洋洋灑灑幾百條代碼。給 ...
自己參考書里改的,感謝大佬, 我參考
ID:376790 發表于 2020-1-18 14:23 | 只看該作者
yoxi 發表于 2020-1-17 20:08
好的,感謝解答
