只需一步,快速開(kāi)始
查看: 3833|回復(fù): 2
關(guān)于IIC 寫(xiě)入EEPOM的問(wèn)題
ID:48335 發(fā)表于 2013-2-28 15:34 | 顯示全部樓層 |閱讀模式
我做一個(gè)軟件時(shí)鐘,要的結(jié)果是當(dāng)板子斷電時(shí)吧時(shí)鐘存入EEProm 里,當(dāng)上電時(shí)要讀取EEprom的數(shù)據(jù),繼續(xù)斷電前的時(shí)鐘。 我的時(shí)鐘程序做好,沒(méi)有問(wèn)題測(cè)試正常,我又寫(xiě)了一個(gè)IIC的驅(qū)動(dòng),我測(cè)試后也沒(méi)有問(wèn)題,EEPROM的數(shù)據(jù)可以正常讀寫(xiě), 但是我把iic程序加入時(shí)鐘里面,程序運(yùn)行就達(dá)不到我要的效果。 下面是iic 程序 #include #include "delay.h" #define uchar unsigned char #define uint unsigned int sbit scl=P2^1 ; sbit sda=P2^0 ; uchar shu,dat; void start() { sda=1; delay(5); scl=1; delay(5); sda=0; delay(5); } void stop() { sda=0; delay(5); scl=1; delay(5); sda=1; delay(5); } void ask() { unsigned char i; scl=1; delay(5); if(sda==1&&i<200) i++; scl=0; //delay(5) } void write_i2c(uchar date1) { uchar temp, x; temp=date1; for(x=0;x<8;x++) { scl=0; temp=temp<<1; sda=CY; scl=1; delay(5); } scl=0; delay(5); sda=1; delay(5); } uchar read_i2c() { uchar m,dat; scl=0; delay(5); sda=1; delay(5); for(m=0;m<8;m++) { scl=1; delay(5); dat=(dat<<1)|sda; scl=0; delay(5); } return dat; } void write_datei2c(unsigned char address,unsigned char date) { start(); write_i2c(0xa0); ask(); write_i2c(address); ask(); write_i2c(date); ask(); stop(); } uchar read_datei2c(uchar address) { start(); write_i2c(0xa0); ask(); write_i2c(address); ask(); start(); write_i2c(0xa1); ask(); read_i2c(); stop(); shu=dat; return shu; } 下面是時(shí)鐘程序的調(diào)用 void main() { init(); // write_sfm(5,30,20); // delay(20); shi=23; fen=59; miao=50; shi=read_datei2c(0x20); //fen=read_datei2c(0x21); //miao=read_datei2c(0x22); while(1) { delay(5); if(t==20) { t=0; miao++; if(miao==60) { miao=0; fen++; if(fen==60) { fen=0; shi++; if(shi==24) { shi=0; } write_sfm(shi,fen,miao); } write_sfm(shi,fen, miao); } write_sfm(shi,fen,miao); } keyscan(); write_datei2c(0x20,shi); // write_datei2c(0x21,fen); // write_datei2c(0x22,miao); naoling(); guannaozhong(); } }
ID:7485 發(fā)表于 2013-2-28 17:13 | 顯示全部樓層
這怎么看啊?
ID:119642 發(fā)表于 2016-10-21 07:02 | 顯示全部樓層
寫(xiě)得什么啊?亂七八糟的
