查看: 3845|回復: 0
基于51單片機音樂播放仿真 樂譜制作軟件 音樂資料
#include <REG52.H>
#include "MusicBox.h"
/*********************代碼說明**************************
獻給師妹黃銀盛-------希望你快樂幸福每一天
音樂驅動參考部分網上代碼,感謝原作者
T0,T1用于翁鳴器頻率計時和控制
使用P1.0口控制翁鳴器,高電平導通
使用外部中斷0,實現曲目控制。設置中斷0為最高優先級
在開發板上調試使用STC89C51芯片,4K flash
在手工焊板上使用STC89C52芯片,8K flash,能放置更多歌曲文件
#define  MSC_NUM  5                             //總曲目數
unsigned char play_num = 0;                     //當前播放曲目號
unsigned char play_state = 1;
unsigned char code Music_SummerNut[];        //盛夏的果實
unsigned char code Music_leftTrouble[];      //忘憂草
unsigned char code Music_moonHeart[];        //月亮代表我的心
unsigned char code Music_JiXiang[];          //吉祥三寶
unsigned char code Music_twoButterFly[];     //兩只蝴蝶
//定義歌曲播放指針數組
unsigned char* pMusic[] = {Music_SummerNut, Music_leftTrouble, Music_twoButterFly, Music_moonHeart, Music_JiXiang};
void main(void)
   unsigned char degree = 3;          //設定播放音調,升八度
   unsigned int play_speed = 300;     //設定播放速度,默認為300
        InitialSound();
           //調用歌曲播放函數
                Play(pMusic[play_num], 0, degree, play_speed);
                //單曲完畢后,延時1S
                Delay1ms(1000);
                //重設播放狀態為1
      play_state = 1;
void Delay1ms(unsigned int count)  //延時,ms級
        unsigned int i,j;
        for(i=0; i<count; i++)
        for(j=0; j<120; j++);
void Int_1(void) interrupt 2  //中斷1,累加全局變量,暫停當前歌曲播放,曲目跳轉
   EA = 0;
        //設置為不播放狀態
        play_state = 0;
        P0 = 0x80;
        //曲目號累加
   play_num++;
        if(play_num >= MSC_NUM){  //若當前播放曲目為最后一條,則回零播放
          play_num = 0;
   EA = 1;
//***********************************Music files**************************************************
//吉祥三寶,一遍,后段轉換不成功,未加入
unsigned char code Music_JiXiang[] = { 0x17,0x03, 0x19,0x17, 0x19,0x16, 0x19,0x02, 0x19,0x0D,
                                       0x19,0x03, 0x19,0x0D, 0x19,0x03, 0x17,0x03, 0x16,0x03,
                                       0x17,0x03, 0x19,0x17, 0x19,0x02, 0x19,0x0D, 0x19,0x03,
                                       0x19,0x0D, 0x19,0x03, 0x17,0x03, 0x16,0x03, 0x17,0x03,
                                       0x16,0x17, 0x15,0x02, 0x15,0x0D, 0x15,0x03, 0x15,0x0D,
                                       0x15,0x03, 0x10,0x03, 0x0F,0x03, 0x17,0x03, 0x16,0x17,
                                       0x16,0x03, 0x16,0x03, 0x16,0x03, 0x17,0x03, 0x16,0x0D,
                                       0x15,0x03, 0x10,0x0D, 0x0F,0x03, 0x19,0x01, 0x18,0x01,
                                       0x17,0x01, 0x17,0x01, 0x00,0x00 };
//盛夏的果實
unsigned char code Music_SummerNut[] = { 0x17,0x02, 0x17,0x03, 0x16,0x03, 0x16,0x16, 0x10,0x03,
                                  0x15,0x02, 0x15,0x03, 0x16,0x03, 0x16,0x02, 0x15,0x03,
                                  0x11,0x03, 0x10,0x02, 0x15,0x02, 0x16,0x03, 0x16,0x03,
                                  0x15,0x03, 0x16,0x03, 0x17,0x02, 0x17,0x03, 0x16,0x03,
                                  0x16,0x01, 0x17,0x03, 0x17,0x03, 0x17,0x03, 0x19,0x03,
                                  0x19,0x16, 0x19,0x03, 0x1A,0x03, 0x17,0x03, 0x17,0x03,
                                  0x16,0x03, 0x17,0x01, 0x17,0x03, 0x17,0x03, 0x17,0x03,
                                  0x19,0x03, 0x19,0x03, 0x19,0x03, 0x19,0x03, 0x1A,0x03,
                                  0x17,0x03, 0x17,0x03, 0x17,0x16, 0x17,0x03, 0x16,0x03,
                                  0x15,0x03, 0x10,0x03, 0x15,0x03, 0x17,0x04, 0x16,0x04,
                                  0x16,0x02, 0x15,0x03, 0x16,0x03, 0x17,0x02, 0x19,0x67,
                                  0x1A,0x04, 0x1A,0x02, 0x17,0x03, 0x16,0x03, 0x15,0x02,
                                  0x15,0x03, 0x17,0x03, 0x16,0x02, 0x15,0x03, 0x10,0x03,
                                  0x10,0x14, 0x16,0x66, 0x16,0x03, 0x15,0x66, 0x17,0x03,
                                  0x19,0x03, 0x17,0x03, 0x17,0x15, 0x16,0x15, 0x15,0x03,
                                  0x11,0x03, 0x10,0x03, 0x10,0x14, 0x16,0x66, 0x16,0x03,
                                  0x15,0x02, 0x16,0x02, 0x17,0x02, 0x19,0x67, 0x1A,0x04,
                                  0x1A,0x16, 0x1F,0x03, 0x1F,0x66, 0x1B,0x03, 0x1B,0x66,
                                  0x1F,0x03, 0x1B,0x03, 0x1A,0x03, 0x1A,0x02, 0x17,0x02,
                                  0x17,0x03, 0x16,0x03, 0x16,0x16, 0x10,0x03, 0x15,0x02,
                                  0x15,0x03, 0x16,0x03, 0x16,0x02, 0x15,0x03, 0x11,0x03,
                                  0x10,0x02, 0x15,0x02, 0x16,0x03, 0x16,0x03, 0x15,0x03,
                                  0x16,0x03, 0x17,0x02, 0x17,0x03, 0x16,0x03, 0x16,0x01,
                                  0x17,0x03, 0x17,0x03, 0x17,0x03, 0x19,0x03, 0x19,0x16,
                                  0x19,0x03, 0x1A,0x03, 0x17,0x03, 0x17,0x03, 0x16,0x03,
                                  0x17,0x01, 0x17,0x03, 0x17,0x03, 0x17,0x03, 0x19,0x03,
                                  0x19,0x03, 0x19,0x03, 0x19,0x03, 0x1A,0x03, 0x17,0x03,
                                  0x17,0x03, 0x17,0x16, 0x17,0x03, 0x16,0x03, 0x15,0x03,
                                  0x10,0x03, 0x15,0x03, 0x17,0x04, 0x16,0x04, 0x16,0x02,
                                  0x15,0x03, 0x16,0x03, 0x17,0x02, 0x19,0x67, 0x1A,0x04,
                                  0x1A,0x02, 0x17,0x03, 0x16,0x03, 0x15,0x02, 0x15,0x03,
                                  0x17,0x03, 0x16,0x02, 0x15,0x03, 0x11,0x03, 0x10,0x14,
                                  0x16,0x66, 0x15,0x66, 0x17,0x03, 0x19,0x03, 0x17,0x03,
                                  0x17,0x15, 0x16,0x15, 0x15,0x03, 0x11,0x03, 0x10,0x03,
                                  0x10,0x14, 0x16,0x66, 0x16,0x03, 0x15,0x02, 0x16,0x02,
                                  0x17,0x02, 0x19,0x03, 0x1A,0x03, 0x1A,0x16, 0x1A,0x03,
                                  0x1F,0x01, 0x1B,0x66, 0x1F,0x03, 0x1A,0x03, 0x1A,0x03,
                                  0x1A,0x00, 0x00,0x00 };
//忘憂草
unsigned char code Music_leftTrouble[] = { 0x15,0x66, 0x16,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x02,
                                  0x17,0x03, 0x19,0x02, 0x1A,0x03, 0x19,0x16, 0x1A,0x66,
                                  0x1F,0x03, 0x1A,0x03, 0x19,0x03, 0x17,0x03, 0x1A,0x03,
                                  0x19,0x03, 0x19,0x02, 0x17,0x03, 0x16,0x16, 0x17,0x66,
                                  0x19,0x03, 0x1A,0x0D, 0x19,0x03, 0x17,0x03, 0x16,0x03,
                                  0x16,0x03, 0x16,0x02, 0x15,0x03, 0x15,0x16, 0x10,0x66,
                                  0x15,0x03, 0x16,0x03, 0x17,0x02, 0x16,0x04, 0x15,0x0E,
                                  0x15,0x04, 0x15,0x71, 0x15,0x01, 0x15,0x03, 0x16,0x03,
                                  0x17,0x66, 0x19,0x03, 0x1A,0x03, 0x19,0x03, 0x17,0x02,
                                  0x1A,0x03, 0x19,0x03, 0x17,0x03, 0x1A,0x03, 0x19,0x16,
                                  0x1A,0x66, 0x1F,0x03, 0x1A,0x03, 0x19,0x03, 0x17,0x03,
                                  0x1A,0x0D, 0x19,0x03, 0x19,0x0D, 0x19,0x16, 0x17,0x66,
                                  0x16,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x15,0x02,
                                  0x10,0x03, 0x0F,0x03, 0x15,0x02, 0x16,0x03, 0x17,0x03,
                                  0x16,0x03, 0x15,0x0D, 0x15,0x17, 0x10,0x04, 0x15,0x03,
                                  0x15,0x0D, 0x15,0x16, 0x17,0x03, 0x19,0x03, 0x19,0x66,
                                  0x17,0x03, 0x19,0x16, 0x19,0x03, 0x1A,0x66, 0x1F,0x03,
                                  0x1F,0x0D, 0x1A,0x0D, 0x1A,0x02, 0x1A,0x66, 0x1F,0x03,
                                  0x20,0x03, 0x1F,0x03, 0x1A,0x03, 0x19,0x03, 0x19,0x66,
                                  0x1A,0x04, 0x19,0x04, 0x17,0x0D, 0x16,0x03, 0x16,0x02,
                                  0x17,0x66, 0x19,0x03, 0x19,0x02, 0x17,0x03, 0x16,0x03,
                                  0x16,0x02, 0x16,0x03, 0x15,0x03, 0x15,0x02, 0x10,0x03,
                                  0x0F,0x03, 0x15,0x02, 0x16,0x03, 0x17,0x03, 0x16,0x03,
                                  0x15,0x03, 0x10,0x03, 0x15,0x03, 0x15,0x01, 0x17,0x02,
                                  0x19,0x02, 0x1A,0x15, 0x1A,0x03, 0x1F,0x66, 0x1A,0x03,
                                  0x19,0x16, 0x1A,0x66, 0x1F,0x03, 0x20,0x66, 0x21,0x0D,
                                  0x20,0x03, 0x20,0x0D, 0x20,0x16, 0x1F,0x03, 0x20,0x03,
                                  0x21,0x66, 0x23,0x03, 0x21,0x66, 0x21,0x03, 0x20,0x66,
                                  0x1F,0x03, 0x1F,0x16, 0x1A,0x66, 0x1F,0x03, 0x20,0x03,
                                  0x1F,0x03, 0x1A,0x03, 0x19,0x03, 0x19,0x66, 0x1A,0x04,
                                  0x19,0x04, 0x17,0x0D, 0x16,0x03, 0x16,0x02, 0x15,0x66,
                                  0x16,0x03, 0x17,0x02, 0x1F,0x0D, 0x1A,0x03, 0x1A,0x15,
                                  0x19,0x03, 0x1A,0x16, 0x1F,0x03, 0x20,0x02, 0x20,0x03,
                                  0x1F,0x0D, 0x1F,0x17, 0x1F,0x16, 0x00,0x00 };
//兩只蝴蝶
unsigned char code Music_twoButterFly[] = { 0x17,0x03, 0x16,0x03, 0x17,0x0C, 0x17,0x03, 0x16,0x03,
                                  0x17,0x03, 0x16,0x03, 0x15,0x01, 0x10,0x03, 0x15,0x03,
                                  0x16,0x02, 0x16,0x0D, 0x17,0x03, 0x16,0x03, 0x15,0x03,
                                  0x10,0x03, 0x15,0x03, 0x0F,0x01, 0x17,0x03, 0x16,0x03,
                                  0x17,0x0B, 0x17,0x03, 0x16,0x03, 0x17,0x03, 0x16,0x03,
                                  0x15,0x01, 0x10,0x03, 0x15,0x03, 0x16,0x02, 0x16,0x0D,
                                  0x17,0x03, 0x16,0x03, 0x15,0x03, 0x10,0x03, 0x15,0x03,
                                  0x16,0x01, 0x17,0x03, 0x16,0x03, 0x17,0x0B, 0x17,0x03,
                                  0x16,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x01, 0x10,0x03,
                                  0x15,0x03, 0x16,0x02, 0x16,0x0D, 0x17,0x03, 0x16,0x03,
                                  0x15,0x03, 0x10,0x03, 0x15,0x03, 0x19,0x01, 0x17,0x03,
                                  0x19,0x03, 0x19,0x0B, 0x19,0x03, 0x19,0x03, 0x1A,0x03,
                                  0x19,0x03, 0x17,0x01, 0x16,0x03, 0x17,0x03, 0x16,0x02,
                                  0x16,0x0D, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x10,0x03,
                                  0x10,0x0E, 0x15,0x0E, 0x15,0x03, 0x15,0x0D, 0x15,0x79,
                                  0x19,0x03, 0x19,0x03, 0x1A,0x03, 0x1F,0x03, 0x1B,0x03,
                                  0x1B,0x03, 0x1A,0x03, 0x17,0x03, 0x16,0x0D, 0x16,0x03,
                                  0x17,0x0D, 0x17,0x15, 0x17,0x03, 0x17,0x03, 0x19,0x03,
                                  0x1A,0x02, 0x1A,0x66, 0x10,0x03, 0x17,0x0D, 0x16,0x03,
                                  0x16,0x01, 0x17,0x03, 0x19,0x03, 0x19,0x03, 0x17,0x03,
                                  0x19,0x16, 0x1F,0x02, 0x1B,0x03, 0x1A,0x03, 0x1B,0x03,
                                  0x17,0x16, 0x1A,0x03, 0x1A,0x03, 0x1B,0x03, 0x1A,0x03,
                                  0x19,0x03, 0x17,0x03, 0x16,0x02, 0x17,0x0D, 0x16,0x03,
                                  0x17,0x03, 0x19,0x02, 0x00,0x00 };
//月亮代表我的心
unsigned char code Music_moonHeart[] ={ 0x0F,0x03, 0x15,0x66, 0x17,0x03, 0x19,0x66, 0x15,0x03,
                                  0x11,0x66, 0x17,0x03, 0x19,0x16, 0x19,0x03, 0x1A,0x03,
                                  0x1B,0x02, 0x1F,0x66, 0x1A,0x03, 0x1A,0x03, 0x19,0x0D,
                                  0x19,0x02, 0x17,0x03, 0x16,0x03, 0x15,0x66, 0x15,0x03,
                                  0x15,0x02, 0x17,0x03, 0x16,0x03, 0x15,0x66, 0x15,0x03,
                                  0x15,0x02, 0x16,0x03, 0x17,0x03, 0x16,0x02, 0x15,0x03,
                                  0x10,0x02, 0x16,0x0D, 0x17,0x03, 0x16,0x15, 0x0F,0x03,
                                  0x17,0x0D, 0x19,0x03, 0x17,0x66, 0x16,0x03, 0x15,0x02,
                                  0x19,0x02, 0x11,0x01, 0x10,0x03, 0x11,0x03, 0x10,0x02,
                                  0x11,0x03, 0x10,0x02, 0x0F,0x02, 0x17,0x01, 0x19,0x02,
                                  0x17,0x66, 0x16,0x03, 0x15,0x02, 0x19,0x02, 0x11,0x01,
                                  0x10,0x03, 0x11,0x03, 0x15,0x66, 0x15,0x03, 0x15,0x02,
                                  0x16,0x0D, 0x17,0x03, 0x16,0x15, 0x0F,0x03, 0x15,0x66,
                                  0x17,0x03, 0x19,0x66, 0x15,0x03, 0x11,0x66, 0x17,0x03,
                                  0x19,0x66, 0x19,0x03, 0x1A,0x66, 0x1B,0x03, 0x1F,0x66,
                                  0x1A,0x03, 0x1A,0x03, 0x19,0x0D, 0x19,0x02, 0x17,0x03,
                                  0x16,0x03, 0x15,0x66, 0x15,0x03, 0x15,0x02, 0x17,0x03,
                                  0x16,0x03, 0x15,0x66, 0x15,0x03, 0x15,0x02, 0x16,0x03,
                                  0x17,0x03, 0x16,0x66, 0x10,0x03, 0x11,0x02, 0x15,0x0D,
                                  0x16,0x03, 0x15,0x15, 0x00,0x00 };
全部資料51hei下載地址:
基于51單片機音樂播放仿真 樂譜制作軟件 音樂資料.rar (668.85 KB, 下載次數: 90)
收藏收藏3 分享淘帖 頂 踩
