查看: 5418|回復: 5
STC8A單片機串口通訊官方代碼
ID:140644 發表于 2020-1-7 22:18 | 顯示全部樓層 |閱讀模式
    這是官方代碼,把兩段例程合并起來,明天測試雙串口通訊。
            串口1切換
            #include "reg51.h"
            sfr      P_SW1=0xa2;
            void     main()
             P_SW1=0x00;                 //RXD/P3.0, TXD/P3.1
             //P_SW1=0x40;               //RXD_2/P3.6, TXD_2/P3.7
             //P_SW1=0x80;               //RXD_3/P1.6, TXD_3/P1.7
             //P_SW1=0xc0;               //RXD_4/P4.3, TXD_4/P4.4
             while (1);
            串口2切換
            #include "reg51.h"
            sfr      P_SW2       =   0xba;
            void      main()
             P_SW2=0x00;                 //RXD2/P1.0, TXD2/P1.1
             //P_SW2=0x01;               //RXD2_2/P4.0, TXD2_2/P4.2
             while (1);
            串口3切換
            #include "reg51.h"
            sfr      P_SW2=0xba;
            void     main()
             P_SW2=0x00;                 // RXD3/P0.0, TXD3/P0.1
             //P_SW2=x02;                // RXD3_2/P5.0, TXD3_2/P5.1
             while (1);
             串口4切換
             #include "reg51.h"
             sfr      P_SW2       =   0xba;
             void     main()
             P_SW2=0x00;                 //RXD4/P0.2, TXD4/P0.3
             //P_SW2=0x04;               //RXD4_2/P5.2, TXD4_2/P5.3
             while (1);
             UART 1 中斷
             #include "reg51.h"
             #include "intrins.h"
//測試工作頻率為11.0592MHz
             sfr    T2L=0xd7;
             sfr    T2H=0xd6;
             sfr    AUXR=0x8e;
             sbit   P10=P1^0;
             sbit   P11=P1^1;
             void   UART1_Isr() interrupt 4
              if (TI)
              TI = 0;                    //清中斷標志
              P10 = !P10;                //測試端口
              if (RI)
              RI = 0;                    //清中斷標志
              P11 = !P11;                //測試端口
              SCON=0x50;
              T2L=0xe8;                  //65536-11059200/115200/4=0FFE8H
              T2H=0xff;
              AUXR=0x15;                 //啟動定時器
              ES = 1;                    //使能串口中斷
              EA = 1;
              SBUF = 0x5a;               //發送測試數據
              while (1);
             UART 2 中斷
             #include  "reg51.h"
//測試工作頻率為11.0592MHz
             sfr      T2L=0xd7;
             sfr      T2H=0xd6;
             sfr      AUXR=0x8e;
             sfr      S2CON=0x9a;
             sfr      S2BUF=0x9b;
             sfr      IE2=0xaf;
             #define  ES2   0x01
             sbit     P12=P1^2;
             sbit     P13=P1^3;
             void     UART2_Isr() interrupt 8
              if (S2CON & 0x02)
               S2CON &= ~0x02;           //清中斷標志
               P12 = !P12;               //測試端口
              if (S2CON & 0x01)
              S2CON &= ~0x01;            //清中斷標志
              P13 = !P13;                //測試端口
            S2CON=0x10;
            T2H=0xff;
            AUXR=0x14;                   //啟動定時器
            IE2=ES2;                     //使能串口中斷
            EA=1;
            S2BUF=0x5a;                  //發送測試數據
            while(1);
            UART 3 中斷
            #include "reg51.h"
//測試工作頻率為11.0592MHz
            sfr     T2L=0xd7;
            sfr     T2H=0xd6;
            sfr     AUXR=0x8e;
            sfr     S3CON=0xac;
            sfr     S3BUF=0xad;
            sfr     IE2=0xaf;
            #define ES3  0x08
            sbit    P10         =   P1^0;
            sbit    P11         =   P1^1;
            void UART3_Isr() interrupt 17
             if (S3CON & 0x02)
              S3CON&=~0x02;              //清中斷標志
              P10=!P10;                  //測試端口
             if(S3CON&0x01)
             S3CON&=~0x01;               //清中斷標志
             P11=!P11;                   //測試端口
            S3CON = 0x10;
            T2L = 0xe8;                  //65536-11059200/115200/4=0FFE8H
            T2H = 0xff;
            AUXR = 0x14;                 //啟動定時器
            IE2 = ES3;                   //使能串口中斷
            EA = 1;
            S3BUF = 0x5a;                //發送測試數據
            while (1);
           UART 4 中斷
           #include "reg51.h"
//測試工作頻率為11.0592MHz
           sfr     T2L=0xd7;
           sfr     T2H=0xd6;
           sfr     AUXR=0x8e;
           sfr     S4CON=0x84;
           sfr     S4BUF=0x85;
           sfr     IE2=0xaf;
           #define ES4  0x10
           sbit    P10=P1^0;
           sbit    P11=P1^1;
           void UART4_Isr() interrupt 18
            if (S4CON & 0x02)
             S4CON &= ~0x02;            //清中斷標志
             P10 = !P10;                //測試端口
            if (S4CON & 0x01)
            S4CON &= ~0x01;             //清中斷標志
            P11 = !P11;                 //測試端口
          S4CON = 0x10;
          T2H = 0xff;
          IE2 = ES4;                    //使能串口中斷
          EA = 1;
          S4BUF = 0x5a;                 //發送測試數據
          while (1);
ID:140644 發表于 2020-1-8 10:13 | 顯示全部樓層
給力,搞單片機要靠平時資料整理和積累的
ID:170318 發表于 2020-1-8 10:26 | 顯示全部樓層
等待樓主匯報測試結果
ID:140644 發表于 2020-1-8 13:49 | 顯示全部樓層
串口轉換到P3.6 P3.7驅動TTS語音模塊測試成功,
這樣符合我的要求了,我用P3.0 3.1接收數據,
P3.6 P3.7驅動語音模塊。播放結束再切換返回到P3.0 3.1。
時間緊張,下一步再摸索兩個串口通訊
/*無線通訊語言模塊測試·PAST 2020 1  8 L72 CODE1413**/
              #include     <REG52.H>
              #include     <intrins.H>
              #include     "stdio.h"
              #define      uint unsigned int
              #define      uchar unsigned char
              sbit         OUT1=P3^2;            /****輸出***/
              sbit         OUT2=P3^4;            /****輸出***/
              sbit         MD0MD1=P3^2;
              uchar        DAT2=0;
              bit           Receive_Flag;
/*---------------延時子程序----------------*/
              void delay1 (uint ms)
              uint i,j;
              for(i=0;i<ms;i++)
              for(j=0;j<200;j++)
/*------------初始化串口---------------------*/
              void InitUart()
              SCON=0X50;                         //8位數據,可變波特率
              AUXR|=0x01;                        //串口1選擇定時器2為波特率發生器
              AUXR|=0X04;                        //定時器2時鐘為Fosc,即1T
              T2L=0XE0;                          //設置定時器處置  110592》9600
              T2H=0XFE;                          //設置定時器處置  110592》9600
              AUXR|=0X10;                        //啟動定時器2
              TI=1;
              EA=1;
/*--------UART 中斷服務程序----Buff=SBUF---------------*/
              void Uart() interrupt 4 using 1
               if(RI)
               DAT2=SBUF;                        //數組下標位置的數據等于j
               RI=0;                             //
               Receive_Flag=1;                     //接收數據標志置一
/*------------------主循環程序----------------*/
              void   main( )                     /*主程序開始*/
              {                                  /**加一**/
              AUXR=0X80;                         //STC系列的1T 設置
              TMOD=0X01;
              InitUart();                        //初始化串口
              ES=1;
              Receive_Flag=0;                     //接收到數據標志置零
              MD0MD1=0;                             //
              //Warning=0;                         //報警標志等于0
             // Counter=0;                         //報警計數器等于0
              //    printf("報警標志");
              printf("<Z>5");         //
              printf("<V>2");         //
              printf("<S>3");         //
                   printf("不喝酒就沒得朋友可是只要偶一喝酒就喝倒一代朋友人生真的很矛盾");
               // printf("Please input up,dowm,high:\r\n");
                OUT1=0;
                OUT2=1;
                delay1(2000);
                delay1(2000);
                OUT1=1;
                OUT2=0;
                delay1(2000);
                delay1(2000);
ID:79874 發表于 2020-4-16 10:00 | 顯示全部樓層
驗證過嗎
ID:476652 發表于 2022-2-4 19:24 | 顯示全部樓層
實踐是檢驗真理的唯一標準!
