查看: 1696|回復: 0
單片機密碼門Proteus仿真程序
密碼門
  1.       ORG 0000H
  2.       JMP  START
  3. START:
  4.       MOV  R0, #7
  5.       CLR  P1.6
  6.       MOV  P2, #01111110B
  7. LOOP:
  8.       MOV  A, P1
  9.       MOV  B, A
  10.       ORL  A, #01000000B
  11.       CPL  A
  12.       JZ LOOP
  13.       CALL DL20MS
  14.       MOV  A, P1
  15.       CJNE A, B, LOOP
  16.       MOV  C, ACC.7
  17.        CPL  C
  18.       RL A
  19.       MOV  ACC.7, C
  20.       CLR  ACC.0
  21.       MOV  P2, A
  22. LOP2:
  23.       MOV  A, P1
  24.       ORL  A, #01000000B
  25.       CPL  A
  26.       JNZ  LOP2
  27.       MOV  P2, #01111110B
  28.       JNB  B.0, KEY0
  29.       JNB  B.1, KEY1
  30.       JNB  B.2, KEY2
  31.       JNB  B.3, KEY3
  32.       JNB  B.4, KEY4
  33.       JNB  B.5, KEY5
  34.       JNB  B.7, KEY7
  35.       JMP  LOOP
  36. KEY0:
  37.       CJNE R0, #7, LOOP
  38.       DEC  R0
  39.       JMP  LOOP
  40. KEY1:
  41.       CJNE R0, #6, LOOP
  42.       DEC  R0
  43.        JMP  LOOP
  44. KEY2:
  45.        CJNE R0, #5, LOOP
  46.         DEC  R0
  47.        JMP  LOOP
  48. KEY3:
  49.       CJNE R0, #4, LOOP
  50.        DEC  R0
  51.        JMP  LOOP
  52. KEY4:
  53.         CJNE R0, #3, LOOP
  54.        DEC  R0
  55.        JMP  LOOP
  56. KEY5:
  57.        CJNE R0, #2, LOOP
  58.        DEC  R0
  59.        JMP  LOOP
  60. KEY7:
  61.        CJNE R0, #1, ERROR
  62.        MOV  P2, #0
  63.        SETB P1.6
  64.        SJMP $
  65. ERROR:
  66.        MOV  P2, #0
  67.        SETB P2.0
  68.         SJMP $
  69. DL20MS:
  70.        MOV  R6, #40
  71.        DJNZ R7, $
  72.        DJNZ R6, $ - 2
  73.        RET
  74.
  75. END
密碼門.rar (22.23 KB, 下載次數: 4)
