查看: 2772|回復(fù): 0
一種判斷AT命令應(yīng)答的技巧(原創(chuàng))
ID:130230 發(fā)表于 2020-1-3 16:36 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
//串口中斷服務(wù)函數(shù)
void UART5_IRQHandler(void)
    unsigned char ch;
    //接收中斷
if ( USART_GetITStatus(UART5, USART_IT_RXNE) != RESET )
        USART_ClearITPendingBit(UART5, USART_IT_RXNE);
        ch = UART5->DR;
                switch (g_uart5_ctrl.recv_stau)
                           case PENETRATE_MODE: //當(dāng)前是透?jìng)髂J?br />                                         {
                                                PassThroughRecv(ch, &g_uart5_ctrl);
                                        break ;
                            //以下分支均為命令響應(yīng)判斷
                                case WAIT_AT :
                                                match_cmd_at(ch, &g_uart5_ctrl);
                                        break ;
                                case WAIT_SETMODE:  //設(shè)置為sta
                                                match_cmd_setmode(ch, &g_uart5_ctrl);
                                        break ;
                                case WAIT_SETWIFI:   //加入wifi
                                                match_cmd_setwifi(ch, &g_uart5_ctrl);
                                        break ;
                                case CHECK_IDADR:
                                                match_cmd_check_ipadr(ch, &g_uart5_ctrl);
                                        break;
                                case WAIT_SETTCPINFO: //鏈接tcp
                                                match_cmd_settcpinfo(ch, &g_uart5_ctrl);
                                        break ;
                                case WAIT_SETTCPMODE://設(shè)置透?jìng)?br />                                         {
                                                match_cmd_settcpmode(ch, &g_uart5_ctrl);
                                        break ;
                                case WAIT_ANSTOPENETRATE: //等待進(jìn)入透?jìng)鲾?shù)據(jù)命令結(jié)果
                                                match_cmd_cipsend(ch, &g_uart5_ctrl);
                                        break ;
                                #if 0  //直接硬復(fù)位
                                case WAIT_EXITTOPENETRATE: //退出透?jìng)?br />                                         {
                                        break ;
                                case WAIT_GORST: //重啟模塊
                                        break ;
                                case WAIT_GORST:
                                        break ;
                                #endif
                                default :
                                        break ;
    /* 空閑中斷 */
        if ( USART_GetITStatus(UART5, USART_IT_IDLE) != RESET )
            USART_ClearITPendingBit(UART5, USART_IT_IDLE);
                g_uart5_ctrl.send_flag = 0;
    /* 串口發(fā)送完成中斷 */
        if ( USART_GetITStatus(UART5, USART_IT_TC) != RESET )
            /* 清中斷 */
                USART_ClearITPendingBit(UART5, USART_IT_TC);
                USART_ITConfig(USART1, USART_IT_TXE, DISABLE);
        /* 允許再次發(fā)送 */
//回傳處理技巧
功能:set wifi命令響應(yīng)判斷(AT+CWJAP+DEF = XXXXXX)
入口:
作者:jzb2019年11月8日
備注:該命令正確響應(yīng)是 :‘O’‘K’ 掩碼2位0x0003
          錯(cuò)誤響應(yīng)       FAIL     掩碼4位 0xf000
     wifi名稱和密碼是固定死的
void match_cmd_setwifi(unsigned char ch,USART5_CTRL_ST * p )
        if('O' == ch ||'C' == ch)
                { p->current_mask |= 0x0001; }
        else if('K' == ch ||'N' == ch)
                { p->current_mask |= 0x0002; }
        if(0x0003 == p->current_mask & 0x0003 ) //響應(yīng)成功
                {p->at_cmd_res = AT_CMD_YES;}
        #if 0
        //錯(cuò)誤響應(yīng)
    if ('F' == ch)
                {p->current_mask |= 0x8000; }
        else if ('A' == ch)
                {p->current_mask |= 0x4000; }
        else if ('I' == ch)
                {p->current_mask |= 0x2000; }
        else if ('L' == ch)
                {p->current_mask |= 0x1000; }
        if(0xf000 == p->current_mask &0xf000  )//響應(yīng)失敗
                {p->at_cmd_res = AT_CMD_FAIL;}
        #endif
