#include<reg51.h>
#include<intrins.h>
sbit P37=P3^7;
sbit P07=P0^7;
sbit P06=P0^6;
uchar m,a,b,c,i,k,s,r=0;
uint j,sum,d1=0,d2=0,d3=0,d4=0,d5=0,d6=0;
uchar code tab1[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; //倒計(jì)時(shí)字符表
uchar code tab[6]={0x06,0x5b,0x4f,0x66,0x6d,0x7d}; //編號(hào)字符表
//頭文件及參數(shù)定義
main() //主函數(shù)
//中斷服務(wù)程序~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
EA=1; //開中斷總開關(guān)
EX0=1; //開外部中斷INT0
IT0=1; //選擇下降沿觸發(fā)方式
TMOD=0x01; //定時(shí)器T0選擇方式一
while(1) //等待中斷
//跑馬程序~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
{ for(k=0;k<6;k++)
P1=0x40; //P1口位選
for(i=0;i<6;i++)
if(P0==0xff) //無違規(guī)操作
P2=tab[k]; //P2對(duì)應(yīng)輸出字符
for(j=0;j<=25000;j++); //延時(shí)
P1=_cror_(P1,1); //左移一位
else //有違規(guī)操作
P1=0x02; //對(duì)應(yīng)位數(shù)碼管被選中
P2=0x6d;
for(j=0;j<=1000;j++);
P1=0x04;
P2=0x78;
P1=0x08;
P2=0x3f;
P1=0x10;
P2=0x73;
while(r==3) //3輪答題結(jié)束后顯示對(duì)應(yīng)位得分結(jié)果
P1=0x01;P2=tab1[d1];for(j=0;j<50;j++);
P1=0x02;P2=tab1[d2];for(j=0;j<50;j++);
P1=0x04;P2=tab1[d3];for(j=0;j<50;j++);
P1=0x08;P2=tab1[d4];for(j=0;j<50;j++);
P1=0x10;P2=tab1[d5];for(j=0;j<50;j++);
P1=0x20;P2=tab1[d6];for(j=0;j<50;j++);
int0() interrupt 0 //進(jìn)入中斷(開始搶答)
P0=0xff; //初始化P0口開關(guān)無人撥開
for(m=9;m>=0;m--)
P1=0xff;
P2=0x00;
TR0=1; TMOD=0x01;
for(s=1;s<=20;) //定時(shí)器定時(shí)一秒
if(P0!=0xff)
switch(P0) //判開關(guān)
case 0xfe:{P2=0x06;sum=1;}break;
case 0xfd:{P2=0x5b;sum=2;}break;
case 0xfb:{P2=0x4f;sum=3;}break;
case 0xf7:{P2=0x66;sum=4;}break;
case 0xef:{P2=0x6d;sum=5;}break;
case 0xdf:{P2=0x7d;sum=6;}break;
if(P0!=0xff) goto ap1;
TH0=15536/256;
TL0=15536%256;
do{}while(!TF0);
s++;
TF0=0;
if(m==0) goto ap2;
ap1:
P1=~P0;
b=P2; //把P2口字符賦值給參數(shù)b
if(P0!=0xff)
{ r++; //搶答次數(shù)
//鳴笛程序 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
for(a=0;a<sum;a++)
for(i=1;i<200;i++)
P37=~P37; //P37為喇叭開關(guān)控制
for(j=0;j<=100;j++);
for(i=1;i<200;i++)
//對(duì)應(yīng)位亮閃編號(hào)5次 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
for(c=0;c<6;c++)
{ for(j=0;j<=25000;j++);
P1=0x01;
P1=0x00;
P1=~P0;
//答題倒計(jì)時(shí) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
for(m=9;m>=0;m--)
P2=tab1[m];
TR0=1; TMOD=0x01;
for(s=1;s<=20; s++)
while(P07==0) //撥P07答題正確 顯示PASS
{ P1=0x01;P2=0x73;for(j=0;j<50;j++);
P1=0x02;P2=0x77;for(j=0;j<50;j++);
P1=0x04;P2=0x6d;for(j=0;j<50;j++);
P1=0x08;P2=0x6d;for(j=0;j<50;j++);
if(P07==1) //答題正確對(duì)應(yīng)位加一分
{ if(sum==1) d1=d1+1;
if(sum==2) d2=d2+1;
if(sum==3) d3=d3+1;
if(sum==4) d4=d4+1;
if(sum==5) d5=d5+1;
if(sum==6) d6=d6+1;
goto ap2;
while(P06==0) //撥P06答題錯(cuò)誤 顯示ff
{ P1=0xff;P2=0x71;for(j=0;j<50;j++);
if(P06==1) goto ap2;
TH0=15536/256;
TL0=15536%256; //定時(shí)器初值
do{}while(!TF0); //查詢等待定時(shí)
TF0=0;
if(P0==0xff) goto ap2; //開關(guān)撥回跳到判復(fù)位程序
//判開關(guān)復(fù)位程序 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
ap2:
while(P0!=0xff)
{ P1=~P0; //位選對(duì)應(yīng)選手?jǐn)?shù)碼管
P2=b; //P2口輸出顯示對(duì)應(yīng)編號(hào)
if(P0==0xff) goto ap2; //開關(guān)復(fù)位 返回主程序中斷點(diǎn)
這個(gè)搶答器有跑馬,鳴笛,判違規(guī),倒計(jì)時(shí)等功能,
需要的芯片有AT89c51/52,和一個(gè)74ls573(可選擇別的代替)
僅供大家參考,也歡迎各位指出程序中的不足,我也好改正。
