查看: 1890|回復(fù): 0
單片機百米賽跑計時器程序
ID:679247 發(fā)表于 2020-1-1 23:26 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
ORG 0000H
START:MOV R1,#20
           MOV R2,#10
           MOV R3,#6
           MOV R4,#00H
LOOP1:MOV R2,#10
LOOP:MOV A,R4
          MOV B,#0AH
          DIV AB
          MOV DPTR,#TAB
          MOVC A,@A+DPTR
          MOV P1,A
          MOV A,B
          MOVC A,@A+DPTR
          MOV P2,A
          LCALL DEL
          INC R4
          DJNZ R2,LOOP
          DJNZ R3,LOOP1
          MOV P1,#00
          MOV P2,#00
          LJMP START
DEL:MOV R7,#12
DEL1:MOV R6,#123
         NOP
DEL2:DJNZ R6,DEL2
         DJNZ R7,DEL1
         DJNZ R1,DEL
         RET
TAB:DB 3FE,06H,5BH,4FH,66H,6DH,7DH,07H,7FH,6FH
       END
